Mazda Protege Idling Issues
I bought a 2000 protege (auto) and has only 34 K miles. It runs fine but when I stop on a traffic light or the car is stationary it makes an audible rattling sound. This sound is not their when I am not stationary. Not sure why it's there. Is it typical of Protege's to make such a sound. I also have a 03 Camry and don't hear that. Any info would be much appreciated.
You might get some ideas if you go to the Mazda Protege Owners: Problems & Solutions discussion and search for "idling". I turned up quite a few posts about rough idle doing that.
The Search This Discussion box is on the right just above the first post and just below the last post on the page.
Meanwhile, I've given this discussion a bit more of a generic name so that others can join in here if they'd like.
Stuck EGR valve (remove and de-carbonize or replace)
Vacuum leak (this was my problem. these cars are very sensitive to vacuum leaks)
Dirty MAF sensor (clean with electrical cleaner spray DO NOT TOUCH WIRES)
Defective MAF sensor (recall on some model years)
Carboned Idle Intake Valve (try Seafoam)
Bad plugs
Bad plug wires
Bad coils
I bought my '98 mazda protege with 50,000 miles on it about a year ago. Right now I am at 60,000 and have been having this same problem for about 6 months. When I am idling, my car will start by making a soft sound. The longer I idle, the louder it gets, with some mild shaking.. So far, I have had my spark plugs replaced, some wiring replaced, and my fuel injectors cleaned.
The other day my check engine light came on, and the code was for my wiring, and for the coil number 4. It went away when I got the wiring fixed.
Also my gas mileage has goign downhill lately...
Any help would be appreciated
drop 900rpm any advice.
Could be a number of things. Any other symptoms? Have you had regular maintenance performed on the car? Have you had the throttle body cleaned?
My 2002 Protege5 normally idles between 1000 and 1200 for the first half minute or so and then settles down under a 1000.
Replacing the air filter will not hurt but I wonder if it's not a dirty throttle body or a mass air flow sensor. Either one will make the car feel as if it's gasping for air. It would also lead to a richer mixture which means higher fuel bills, not a good thing these days.
Any help and advice would be great
mike
This is a known issues with Proteges. Are you dealing with a Mazda garage?
p.s. The "cadillac converter" is actually a catalytic converter, but cadillac converter has an interesting ring to it.
PS: Try to keep the engine from backfiring. Don't let the engine putter down, let of the gas, and floor it again in an attempt to get it going, because each time you do, the engine will backfire once or twice.
Hope this helps.
PS: Your radio died first because it takes the most power, besides the engine and headlights.
i own a mazda protege 97 1.5,recently i had so many issue ,i havea thread already in the mazda protege forum,if you read you can understande what i went trough,just to give a follow up,after i had all the inspections done my car first time yhe engine died ,i took back to the meccanic and they replace the battery the egr valve light come on again,i since then replace the egr valve check all the hose and maf aitr filter atc everything seems fine,after i replace the egr valve the car run great,but after few hours i start up again and the car as the symptoms again,actually it gasp ,trottle when take off or stop in gear, the meccanic could not find anything else,but i let the engine run a little and listen where the noise is coming from when i give gas,and that schriekin sound is comin from the alternator.
my question to you is ;is possible that the alternator is causing the gasping,and drain my battery before?and mabye it was nothing wrong with the egr r valve in the first place. I will have the alternator tested altough the car never as a problem when i ride on highways.
THANKS
Could be a few things ... When my EGR valve failed, it caused the car to rev wildly as if it was gasping for air. The EGR valve is part of the emissions control system. You may want to have a diagnostic test done to determine the exact problem.
I've similar idling problems to many others; mine is a '96 with 100,000. Mechanic said "Idle air control valve", and also the torn intake air hose (bad engine mounts let the engine shift and it has pulled this hose to pieces). Ordered the hose on ebay; meanwhile, it's taped. Replaced the IAC valve (ebay, also). No change: rough, variable RPM while in gear and stopped, okay when driving or in P or N. Question: manual says resistance on the IAC valve terminals ranges from 1070-1230 ohms; both the old and the ebay replacement measure 880 ohms. Curious that they're both 880 (unless, of course, they're both 100,000 miles old!). Is the manual accurate?
Thanks, Matt
Yes, that does sound a bit high to me.
Could be a bunch of things: cold, not driven frequently, throttle body/fuel system dirty ...
My 2002 starts at 1100 before dropping to 800..
Next time you bring it to a garage, mention it to your mechanic to hear what he says.
Sounds like you might need to bite the bullet and bring it into a Mazda garage to get the diagnostic and their suggested cure. Otherwise, you may end up spending even more money replacing parts that are not the problem. Good luck!
1996 mazda protege
1. replace your air filter if bad
2. get some cfc maf cleaner only clean maf sensor (located in top of air filter cover 15 shots of spray through the screen side only and wait 15min til dry)
3.remove air hose between maf sensor and throttle body in the accordian section check for rips any cracks replace remember when replacing air filter to remove this hose or you will crack it.(this also can be caused by a bad motor mount)
4.egr valve located on backside of intake remove intake hose, 2 12mm bolts and label the two vacuum hoses on egr. with brakekleen spray into 2 holes with carbon build up clean shaft well oil then press diaphram up and put your finger on vacuum hole if diaphram doesn't hold and move freely replace.
5.check catalytic converter basically go to tail pipe and check for good flow of exhaust
6. battery /alternator clean teminals, load test battery,with multimeter in dc check voltage you should be getting atleast 13.8 volts @idle
7. Iac sensor i leave this for last because its pricey so far my check list has cost you a bottle of cfc maf cleaner and your time at this point head to mazda
hope this helps
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Still, if you have a half-decent dealership in your area, it would only take them a minute or two to look it up by VIN. I've never had a dealership charge me to do so.
I had a '96 Protege that was very kind to me.
