More than likely, the computer thinks a bulb is failing or has failed... I had a fender bender in my 05 dually a couple of years ago, and the right front turn signal was broken in the collision - when I pulled over and turned on the hazard lights, EVERY exterior light except for the white ones took over hazard duty - this included all the roof, rear fender, and tailgate clearance lights.
kcram - Pickups/Wagons Host
I would start by disconnecting everything that you added for those lights, disconnect it at the power source.
Now see how your original system is working. If there is still a problem see if dissconecting the battery for 15 minutes will work for you too...
Good Luck
The company that made the LEDs should be aware of this issue, and they should be your first call for help.
I traded fuses with the right side and no help.
I checked the right side power in to fuse was12 volts. Power in for the left side light fuse is only 3.3 volts.
Does anyone have any ideas.
Thanks in advance
thank you
monty
when you get to 2000 RPM the bright lights flicker on and stay on till you let off the fuel ? the head lights are not on when this happens and it dose not have daytime running lights.
any suggestions ?
Thaks for the help
i can be emailed at laas99@sbcglobal.net
Jerry
Corkscrew
