Good luck with your case.
But to reply to your post DO NOT TRY TO DO ANYTHING TO YOUR CAR.
Only thing I have had success chaning is the headlights and wiper blades.
The oil is impossible for me change. If I had the arms of a 6 yr old I might be able to get to the filter. The enormous skid plate is in the way of everything.
The brakes are without a doubt a dealership job. Here is my story.
50k miles and my breaks are squelling like there is a hog getting its hoofs removed behind the wheels. I get the car up on the jack, remove the tires, remove the caliper and the S#!+ hits the fan. The calipers are electronically controlled to retract, the old C-Clamp trick to squeeze em back in will not work. DONT TRY IT.
Secondly, since i had the caliper off I tried to remove the caliper carrier since I was going to have to change the rotor. I thought it was very weird only one side was chewed up but oh well I was determined to fix it. Next problem is that the caliper carrier requires a TRIPLE SQUARE to remove it from the arm. ( I cant remember off the top of my head what mm size the thing is) Good luck finding a triple square anywhere close to where you live. I bought mine off the internet.
Now assuming you have the all the tools to get this far, you will need to hook up your laptop to your car. Then you need the software to communicate with your car to open the caliper piston so you can put the new pads in. OMG what a debacle
1) Yes, the defacto "Industry Standard" for oil consumption is in fact one quart per thousand miles. I think that's wrong, but the auto companies don't give a darn what I think. :mad:
2) The 2.0T FSI engine in your car is notorious for oil consumption, that's the bad news; the good news is that there is a relatively inexpensive and easy fix for the problem. Going from memory here, the FSI engine (as opposed to the newer 2.0T TSI) has a funky crank-case breather system (kind of a high-tech PCV system) that is failure prone, and when it fails, oil starts finding its way into the intake plenum of the engine. VW has redesigned the parts involved a couple of times and you should have no problem having your dealer replace the parts under warranty, that and there are a number of aftermarket companies that make even more robust parts (the drawback with aftermarket parts is that you have to pony up for them yourself instead of having them covered under warranty).
Keep us posted.
Best regards,
Shipo
Is it a good or even appropriate standard? I don't believe so.
Best regards,
Shipo
Thanks again!!
Keep us posted.
Best regards,
Shipo
Does the 2010's 2.0s(i.e., Passat, CC) suffer from oil consumption or has this been sorted out on the current models?
Best regards,
Shipo
http://img.photobucket.com/albums/v220/Altair4/502Supplement1.jpg
http://img.photobucket.com/albums/v220/Altair4/502Supplement2.jpg
Best regards,
Shipo
Best regards,
Shipo
After reading some of the war stories here, I was ready for just about anything, but was really impressed with how professionally the situation was handled. Don't know if its an attempt to improve service, image, etc., but they really stepped up and did the right thing. Good way to keep customers.
Bad move. Now my low pressure oil indicator light is coming on and I'm told that I needed to be using a special grade european oil and special oil filter to keep the oil from turning to sludge. I owned this car from new and the only info I received was a potential for sludging and recommended prompt oil changes. I was just told to use the full synthetic oil from my last garage visit.
Well it looks like I'm taking my receipts to the various garages and asking for the spec's on the oil they used and if it does not meet what VW insists is to be used, I'm asking for a full refund or they can pay a portion of my engine cleaning bill.
Ok, back to reality.............I've been taken by all the garages and shame on me for not having Masters Degree in chemistry and relying on people that do this for a living to supply the right product for the cars that they work on.
I was hoping someone could tell me what the correct oil change interval is for an 07 2.0T Passat is. Begining 2010 I use the car sparingly (once a week for about 100 miles). I had my last oil change at 34,500 miles in January '10 and am currently at 36,500 miles in July '10. When I would use the car on a daily basis I would always get oil changes done every 5,000 miles. However, given my limited use starting this year, I am not sure if sticking to the 5,000 mile rule is the way to go. Since it would take me 1 year to log 5,000 miles, I am bit sceptical to having the oil changed only once a year. Does anyone have any thoughts on if I should stick to the 5,000 mile rule or is it advisable to get an oil change done every 3 or 6 months irrespective of miles.
SN
Best regards,
Shipo
Just an opinion.
Krzys
I have an 02 Passat v6 2.8L manual, with about 78K miles. This is my wifes car, and we've been keeping up with the standard maintenance at a nearby shop (not a dealer). Recently, wife claimed 2x instances of loss of power. No check engine light. One instance happened in parking structure, with dash screaming "STOP".... Mechanic looked at it both times and said that there were no error codes but that oil was very low and engine gas was near E. I've driven car for few weeks with no issue, but have noticed that it is starting to consume a lot of oil. Read something on earlier post about an oil consumption test @ a dealer and rings being replaced.... Any ideas of what might be going on? :confuse: I'd appreciate any pointers!
Hardeep
I have some more news on my 2007 Passat 2.0T.
On Aug. 2nd, my "STOP" low oil pressure light came on again. I called the dealership and they advised me to have my car towed to the shop. I have to have my Husband go into the dealership to insist that they contact VW to see what they were going to do, since this was the 2nd time this has happened and the would only run the consumption test, as we all know that was .7 qts per 1000 miles, UNACCEPTABLE TO ME!!!!! THIS IS A 2007 PASSAT WITH NOW 37k MILES.......anyway, they were given the okay to remove the valve cover from the motor and found that there was a crack in it, in a seam, so they have replaced that. They insist that this is the cure to the problem, however they want me to keep checking the oil about every 1000 miles and report any low levels. Also, they have informed me that this is a problem that is JUST NOW coming to light, whatever, I have been complaining of this issue for MONTHS! So, hopefully this is the cure all and I won't have any other issues, time will tell.
From memory I can count nearly ten different and distinct engines since the Passat first reached our shores in the mid 1990s.
Krzys
- What do you call "Correct oil?"
- Where did you have the oil changed?
- Do you have the receipts?
If you had your dealership or a reputable shop change your oil then you should have receipts that show a 502.00 certified oil was used at least every 10,000 miles (after the first 5,000 mile oil change). Assuming you have said receipts, then there is no need to go to all of the trouble of starting a class (probably wouldn't get you much anyway); simply confront the dealership with the evidence and demand they spell out in writing why they're denying your warranty coverage.
Keep us posted,
Where can I find the info on how to proceed here ? Thank you
My question to mckauto is: Who performed the oil changes over the time you owned the car? Do you have the receipts for all of the changes? See what spec oil was used. If the dealer did the changes, and used incorrect oil, I think you still have something to talk about with both the dealer and with VWoA.
It broke while I was on the highway. STOP light came on. Towed to a dealer. Engine was fried. Engine replacement costs were higher than the car was worth (plus they offered only 3-6 month warranty on the replacement engine and no warranty on the labor). So I sold it to a used junkcar dealer.
Don't make the same mistake -- get it fixed right away! Good luck!!
My pre-owned warranty is in question..So, service manager says he is "going to bat for me", in discussions with VW, and I should know by the end of today. They have not taken the car apart, so I don't even know what is wrong with the engine.
I do know that the cam shaft failed last year and was replaced. I am freaking out, obviously this will be a huge expense if I have to pay.
