Honda Accord Coupe Exterior Problems
I broke my driver's side mirror glass. Everything else is fine. Can I just buy an adheasive glass to fit the frame> I don't need or want the whole unit. Thanks, Greg
Very nice car, but it dents very easily. I guesss Honda saved a little weight by making the metal thin.
Be very very careful if you don't want dents.
Cheers,
MidCow
Good Luck,
MidCow
You're talking about the black strip with the slots that are only on the driver's side? I should check that to make sure they are not plugged up, right? I don't think they are. I think that the water is collecting somewhere in that general area but I can't figure out where. The dealer told me it's normal, even though they could not recreate it. I'm assuming that no other coupe owner is having the same issue?
If this area is not plugged up, what do you recommend I do? Also, when I use the spray and windshield wiper, I keep having to use the wipers because water keeps splattering on the windshield. I am used to spraying and wiping once and having a clean windshield.
Thanks for your help.
Use a liquid clay bar- that should clean it up nice- and put a good coat of wax on afterwards...
I also had a paint chipping/peeling issue around the edge of the hood, corners of the front fenders, and the A pillars... Do you have this issue as well ?
Edmund's.com, the auto info site, says the 2006 Accord Coupes were Redondo Red Pearl. The salesman told me it is San Marino Red. The paperwork he gave me says Bordeaux Red.
Which one might it be?
Thank You All
