A navigation system with touch-screen functionality provides real-time mapping, directions, points-of-interest, trip information as well as control and display of audio and climate control functions.
Can someone confirm?
Firestone won't warranty it in their "roadside hazard" package so I thought we would be able to order one... I've searched all my local distributors, and even online but am told that they are on "national backorder" and I will be notified when they are available.
They are size P245/50R20- stock tires and rims
I find it hard to believe that even the local Mazda dealership can't get them and are trying to sell him a new set of 18 in. rims and tires at full cost.
Any advise? What do you tell a customer when it takes over a week to find a tire?
and to top it off it comes with a compact spare. what are they thinking?
We took it into Bommorito Mazda in St. Louis. They ran a diagnostic and said everything was fine. They told us to get new tires and try it again during the next snow.
So we were out of town when it snowed next and we had the new tires. Same response. Only the front tires spun out in the snow.
The dealer says the car is fine. We think otherwise and are out $100 for the diagnostic.
Would a transfer case issue show up on diagnostic? Also now I hear this high pitched squealing noise (although low in volume) most of the time when I drive the car.
Help.
Rich
I am also having one other issue, we have no control over the rear AC/heater, has anyone else seen this, bad fuse, bad switch, any ideas here?
I loved this car when we bought, but the more I have to drive it with these issues, the less I like and the more I just want to get rid of it. This July it will be 4 years old with 63000 miles.
Thanks for any help,
Nathan
You may want to take a few days to get over the shock and soreness before heading for the dealer. People tend to rush out and buy a replacement car quickly after a wreck and you may spend more than you need to if you don't take your time. At least make sure any deposit you put down is refundable. Or get a rental and shop two or three quotes around.
TCS light randomly coming on....I cannot help you, mine doesnt do it but mine is a FWD. I thought I had read a while back of someone having this TCS light coming on and it ended up being a transfer case (obviously a 4WD model). It was replaced under warranty but out of pocket could be very costly. So if yours is a 4WD model that may be the problem...I dont know for sure...if yours is FWD then I definately dont know what it could be...sorry!
The random front end noises....
Squeek = bumps stops not gliding over the shock rod. Fix...lubricate bump stops with a heavy grease so they slide up and down with out any noise.
Click-Click noise = axle splines have a little play. Fix...pack the axle splines with axle grease to minimize play.
Rear blower coming on after turning off vehicle = bad relays. Fix...there is a TSB for that, research it better. Replace both relays under the hood. Part# G115-67-730
Hope this helps!
Any suggestions on what to do ? I used to own a Toyota so I was spoiled with GREAT service ...MAZDA is the opposite ....
HELP ! thx :lemon:
Good Luck !
Tirerack has info about it.
Now, if the tire size simply isn't available, that's another story.
