Ford Freestyle climate control
I have the 2006 Freestyle Limited AWD. With the auto climate system the a/c light will light above the external temp. This happens when it is cold out as well. If I hit the a/c button it will go out. Why is this on if it is cold outside? What function does it serve when it is on if ac is not needed?
Don.
Don.
You can, of course, elect to turn off the A/C manually after setting the auto-climate mode. You'll have to do this each time you start the car, though.
The AC not only cools the air but also retains a lot of moisture and provides breathing air through the dash vents. The heat comes through the lower pipes.
The compressor will actually disengage if the CFC temperature reaches a certain low (not sure exactly how low).
In the beginning it bothered me too, but I noticed the air becomes more breathable (less stuffy) if I let it do it's own thing. You will notice that the dash vents put out a low quantity of cold air.
The $640 option is the Aux climate control, which is the one used for the rear passengers (my kids love it). Automatic dual-zone climate control on the front panel is standard on the Limited and SEL.
If you don't like it, why not just use the manual controls? Select where you want the air to come out, what fan setting you want, and how hot you want, then let it rip! If you want it to work like a fully manual system, you can set the unit such that the driver's side temperature sets both driver and passenger temp, over-riding the dual climate controls.
I often keep mine in vent (air out of the upper vents) with low fan... but I leave the dual controls on, as my wife likes a hotter vehicle than I do.
You do not have to use the automatic controls. :shades:
Both my 2005 Freestyle Limited and other vehicle have auto climate controls. I don't like the auto mode so I use it in the manual sense; I set the temp, fan speed and recirculate/vent as I see fit when running the AC or heat. Works fine for me and I only adjust the temp as conditions warrant. Having the REAR/auxiliary climate controls helps to cool or heat the rear area of the Freestyle much quicker than just the front vents.
Making initial climate control settings before getting underway will certainly allow ones attention to remain on driving in a safe and prudent manner. Temp adjustments while driving can be made with very little distraction while in motion.
Driving comfortably and safely is the only way to travel!
Regards -
M. J. McCloskey - 2005 AWD Limited
"When you turn the climate control system to OFF, all of the vents close up."
When I turn the ACC system off and the vents close up I get an annoying whistle when driving at highway speeds. If the ACC is on and the vents are open there is no such noise. Does anyone else have this problem?
- Chad
My 2001 Rx300 has two c-best settings that when set correctly result in the A/C being disabled indefinitely by simply turning it off one time.
Modern day automotive A/C systems can be hazardous, oftentimes resulting in sudden and complete fogging over of the windshield during cold weather operation.
The FS keeps the fan off until the engine warms up, if the system is in AUTO mode.
I have a ford freestyle limited 2006. I wanted the side airbags, but misunderstood that all limiteds have standard side airbags (2007 onwards)
Is there a way to retrofit my car with side airbags ?
I also wanted the rear seat climate control, dont have it so thinking of getting a 12v fan. Comments ??
regards
Odd that the Ford website does not agree with this statement - it is show as optional.
I've tried every combination I could think of to try to get the whistling to stop at highway speed (System On/Off, Recirculation On/Of, Auto On/Of, rear on/off), but it still whistles. I've been meaning to take it to the dealer (I bought it used this past October with 19k) but I haven't had the time to take a day off work. Now I'm thinking it's a cold weather related thing because now that it's warmed up a bit here in NJ, the whistling sound in not nearly as loud as a couple a weeks ago. I'm sure when I finally get around to taking it to the dealer, the whistle will go away completely :confuse: Does your whistle sound only come on when you have the A/C system off? Is this during cold climate?
Rich
The driver's side is blowing cold air; but the passenger and rear are blowing semi-cold, or not cold air although I turn all the temp settings to 60F and the rear to the coldest.
There is a high pitch hiss sound from the driver side's third row panel(is that called the quarter panel, where the fixed windows located, the third row 12v outlet located). If I turn off the a/c but let the fan on, the hiss sound will be gone, but once the a/c on, the sound comes back.
Any ideas, guys? :confuse:
I had it into Ford and they said that the system was working fine........
I did a bunch of research and found some links to the problem on an Air Conditioning site link below:
http://www.autoacforum.com/messageview.cfm?catid=2&threadid=22170
I am placing this info here for those that were like me and trying to find the answer with no help from the Ford dealership. They must have a procedure that does not identify this particular problem but it exists and it seems that LOTS of owners are having it.
The AC compressor is a newer scroll type that uses a control valve located in the rear of the compressor behind a plate with two screws. This valve fails to function properly and most people change the entire compressor and magically, they fix the problem when they could have only replaced the control valve for $30.00 like I did and get the same result!!!
I am not saying that this will work in every instance BUT, with less than 27K miles on my car, the chances of a bad compressor were very low. Also, the system was fully charged as indicated by my gauge and there were no leaks.
Here is a link to the replacement part:
http://www.techchoiceparts.com/ShowItem/116597-Scroll%20Compressor%20Control%20V- alve.aspx
This valve is located on the back side of the compressor and can be changed without getting under the car... YOU MUST EVACUATE THE R-134A FIRST!!! If you remove the retaining plate with the system charged, it will blow all of the refrigerant out on you. I simply evacuated the system first and then replaced the valve. The valve comes as the brass piece with its seal. You must remove the retaining plate from the rear of the compressor which is held in with two 10mm bolts. I have included a link to a photo of the plate below. This view is looking down between the radiator and the engine with the hood open.
http://ejneary.home.comcast.net/~ejneary/images/freestyle.jpg
So, here is the procedure:
1. Evacuate refrigerant
2. Remove two 10mm bolts on rear of compressor
3. Remove old control valve with spring
4. Move spring to new control valve
5. replace spring and control valve in compressor
6. Replace retaining plate with two bolts
7. Tighten bolts
8. re-charge system with refrigerant (Amount needed is listed on the tag that is on the radiator support)
9. cold air will come out of vents at idle.
I hope that this helps some people. I spent HOURS researching this problem and the Ford tech was not able to find this.
JUST THROWING IT OUT THERE, DO YOU KNOW HOW TO FIX:
MY TAIL LIGHTS ARE ON ALL THE TIME.
MY HEADLIGHTS STAY ON ONE SETTING!!!
THIS IS A KILLER ESPECIALLY DRIVING AT NIGHT.
HUBBY SWITCHED ME OUT FROM THE JETTA TO THE "MOMMY CAR"
