Grand Prix Power Window Motor Replacement Guide
I couldn't find a good guide online to replacing the power window motor and regulator in the driver's door of my 2001 Pontiac Grand Prix GTP sedan, so I had my brother help me and I took pictures.
It's actually pretty easy once you know how to do it. We went in blind and had to figure things out.
I hope this picture illustrated guide helps some of you save time and frustration when one of your motors dies.
http://www.paulstravelpictures.com/Grand-Prix-Window-Motor/index.html
I love my 2000 Grand Prix. I just wish everything wasn't happening all at once!
Thanks to everyone for sharing your experiences and help!
Janie
The first window (passenger right) went out and I paid the dealer over $500 to fix/replace. Then second (passenger left) went out a couple of weeks later. I fixed it myself for the cost of part and expedited shipping for $130 bucks. The very next day my friggin' driver side went out. So today I will go back and order BOTH front windows JUST IN CASE the other goes out. It's Murphy's Law I think. Anyway, I was very pleased with the purchase I made online. Check them out.
Also, my boyfriend has a Pontiac Firebird. His driver side window has been acting funky too. Well at least we're prepared for the worse now.
Thanks to everyone for posting such great info. If it wasn't for this site I would have probably paid the dealer again.
You will have to take the screw out of the door by the handle. The other parts of the panel just snap in and out. If you tug on it gently you'll be able to find out where they are connected. Mostly on the sides. If the clips break yo can replace them. I doubt you'll do any real damage to the panel unless you are really aggressive.
For the most part it removes easily.
I know there was an issue putting the srew back into the panel, though. Kept falling out because my screwdriver wasn't magnetic. A little piece of tape attached to screw and tip of screwdriver kept it on and once you turn the screwdriver the tape will break off. Just a little bit of advice.
Janie
link title
The rears however are a bit more expensive but I have been able to find them on ebay for around $60.
Kimmie
Thanks Kimmie for the eBay info. I'll go check them out too.
Janie
My window went down and I could not get it back up. It did make the sound that you are describing, and I think you will have to replace it.
Good luck. My window broke 80 miles from home with a bad storm coming up ... I had to stop and buy plastic wrap and packaging tape to make it home semi-dry.
I received the last window motor/regulator assembly from Dr.Autoparts on eBay. Seemed to be very slow to receive but much cheaper so if you're in a hurry it might pay to get it from somewhere else. I was okay to wait. First part I received from them was wrong but they were quick to send the replacement. All is well now.
Anyone know anything about flashing security light? I just had my transmission rebuilt and now the light won't quit flashing.
::sigh::
If it's not one thing its another. For all of the money I've put into this car the past year I could have taken a really nice vacation.
Anyway....
J
I have a 1999 Pontiac Montana mini-van with a burned out power window motor on the passenger side. I purchased a new window motor and tested it with a 12-volt power source before I installed it....it runs properly for both forward (up) and reverse (down) motions. The motor has two male prongs...the down-motion male prong goes into the brown wire side of the female plug connector, the up-motion male prong goes into the blue wire side of the female plug connector. The motor sits in a plastic plug that does not have a ground. We think that the brown and blue wires act as alternating power / ground, i.e, brown as power and blue as ground (to lower the window), then blue for power and brown as ground (to raise the window). I then plugged the motor into the female plug from the up/down window control switch. Using the window control switches, I tried to lower the window or raise the window....it does not work. Note that the drivers side window switch for the drivers side window works fine, so I doubt that it's a fuse or circuit breaker problem. We ran some more tests; ....down motion via jumpering the brown male motor prong to the brown wire on the female plug, and a ground wire on the blue male motor prong, and depressed the window switch down.....it worked properly. Doing the same test on the up switch with the blue wire did not work. So the switch's down motion works, but the switch's up motion does not work. Through several tests we found that the brown female wire was providing power, but the blue wire is not providing power and is not a good ground.
Here are some possibilities: when the original motor burned out, the window switch circuit board up-function might have fried. I'll check the circuit board for any visual signs damage. Another possibility is the blue wire is broken....which is going to be tough to find.
I'm trying to find a wiring diagram, but no luck so far.
Has anyone had similar problems with this vehicle (or Olds Sillouette or Chevy Lumina APV)?
Any suggestions?
Many thanks,
Jack Hirneisen
Solve all your window motor needs.
Buckjohnsk
I just replaced a window regulator, found a very helpful "how to", detailed with pic's, solved the problem thanks to the guides help. The guy really did a good job.
http://www.fixya.com/support/t735283-power_windows_replacement
What do you think?
Good luck,
Joe.
Help, I read your reply to above subject. I have the exact same problem you
described, can you please tell me what you did to correct? My 12V test proved window motor good, my test light lit up when applied to the prongs of the plug that
goes directly into motor. My switch works in both directions up and down, but when I plug in motor, (2 of them (both already tested)), I get no positive movement whatsoever. anybody reading this that can help please email me at jjmrsf@nctc.com. thanks to all in advance and help please. Ground problem?
plug problem? dont know and need help....
More could be revealed once you remove door panel. There is a tension spring
mounted on window regulator that keeps window in the up position. This could
be bad, the regulator could be bad, the motor could be bad. You will probably have to go through several electrical tests to include motor, switch (both master and individual door). Advise if you are capable of performing such tests. As you test
you eliminate one possibility after another until you arrive at the final definitive problem. Once found, should be simple enough to repair.
Could you direct me to the sources you used? How do you remove the door panel, etc.?
Steve
thanks again
laurie
