Rear brakes/suspension
hashiriyaboi
Member Posts: 1
Just wondering if it was possible to easily change a cars rear drum brakes to disk and a torsion beam suspension to macpherson struts. A couple of hatchbacks i was interested in has rear drum brakes and torsion beam suspension (xA, fit, yaris). Would it be better to change this setup if it's possible anyway?
I'm driving to Subway to get lunch and in my residential neighbourhood for whatever reason, the city has some big hoses running from a fire hydrant to a project a few blocks away (they are digging something up, not sure what) and they are covered in ashphalt. In essence it's a big speed bump for which you have to slow down to a crawl to go over.
Well being so nice today, I had the windows open and the stereo cranking....next thing you know....BANG!!!!! Needless to say I had gone over these stupid hoses with my car. I was going about 60 Km/h (35mph). Shortly after there is a 4 way stop and I went through that no problem...phew. I keep driving a couple of seconds and slow down for a turn and when I apply moderate pressure to my brakes there is this "clunk" sound from what I think is the front of the car (not really sure though).
The car turns fine and there are no noises as far as I can tell when I turn the wheel either way. Also there is nothing leaking under the car, and looking at the undercarriage nothing seems to be hanging/out of place nor is there any sign I bottomed out. So my only problem is this clunking sound whenever I apply moderate pressure to the brakes (no sound when light pressure applied)
Update:
I took it into the shop today and told them my problems. They ended up doing a brake service which consists of inspecting and lubing the brakes. The noise is still there and they told me that they would need 1-2 hours to run diagnostics on the car to get a better idea of what the problem was. They also retorqued the subframe (whatever that means) as this is often a cause of noises after accidents. In addition, they checked underneath the car and according to them absolutely everything looks as it should. I asked if the car was safe to drive as is and he said "I can't guarantee that it is".
I decided to take the car as is and I will try another shop tomorrow to get a second opinion before forking out $160 just to have the car looked at again. Any opinions?
My old Civic right now makes what sounds like the same sound when I hit the breaks and it is because the bushing on the control arm of the right front wheel is missing.
