Honda Fit Care - Interior & Exterior
Want to know how to keep your fit looking shiny & new? Ask here!
What type of protectants?
Zaino?
Zymol?
Turtle?
McGuires?
My Fit is red. I know red fades faster than any other color. So I'm looking for some suggestions to sort through.
Do people have waxing/polishing regimens that they follow?
Thanks for any help.
#1 - Honda spray polish cleaner!!! :shades:
http://hondacuraworld.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=08C25-- P011M&Category_Code=CC
#3: polishing compound
#2: Car wax levels.
#1: no grit at all.
#1 is what you use on a new car. Protects as well as any of the waxes, though it is clear - it won't bring back much shine if the car is faded.
It's generally sold at gaming supply stores and boating stores(since it also works for plastic and fiberglass). $0 is spent on advertizing it - it's marketed at professionals only.
Works fantastic. Also keeps plastic lenses from getting yellow.
Any Comments???
I've noticed that it is impossible to put the dressing on the rubber/vinyl without spillover to the painted surface. (No, I'm not going to tape up my car every time I want to dress the vinyl.) Not only that, it leaves a cloudy residue that has to be buffed off. :mad:
Two questions:
1) Will the ERV harm the painted surface?
2) If I wash the car before applying the dressing, can I just remove the excess dressing when I waxand buff the car after?
BTW: I'll be using Optimum Car Wax when I wax it.
I never really thought about the source, but I figured it would be from the high-traffic freeway driving I do on the quite crowded I-5 in southern California.
Astro Shield
I've always used this. No silicones (promotes oxidation). Not a wax. Petroleum based (which I believe comes from the road to begin with no?)
Polish and glaze not a wax. Probably similar to NuFinish. Non abrasive and works good with the orbital.
I had to take apart the interior plastic which led to scratching and breaking clips. Argh!!!! Oh well I can replace the clips and now I know how the interior plastic comes off. I can live with some of the plastic scrapes too. But I think the plastic is almost too cheap since it scratches so easily. Just me.
This is actually my first post in this forum.
I just bought used Fit which is 2WD (GD1) in Japan. But there is significant scratch on glove cover. So I am planning to replcae it. Yes, I could find the part in auction. But the auction offers the glove cover for GD2 and GD3.
GD1: 1.3L L13A engine 2WD
GD2: 1.3L L13A engine 4WD (Japan only)
GD3: 1.5L L15A engine 2WD
I am wondering if they are using the same glove cover.
I really appreciate your help.
Regards.
The color would be my only concern. From Honda's Japanese Fit site, it appears that there are different upholstery colors/designs on different levels of the Fit, and I don't know if that might extend to the plastics too?
Anyway, as long as you can find one that is the same color as your GD1, I think any JDM Fit glove compartment cover would work. Best of luck!
I will bid that part.
Regards.
Dealership or autobody shop?
Now, this morning I noticed on the hood right next to the left headlight is a noticeable ding. :sick: It looks like it was from a rock so I wonder if the Fit's steep sloped hood is not good at deflecting the uncontrollable debris.
Maybe time for a nose mask? College Hills sells the full nose mask though.
I had a leather bra on a previous Civic which did protect it from the rocks, but caused other problems. It rubbed on the areas where it was attached and damaged the paint. It was also a major pain to take off and put on. When moisture got trapped underneath it caused a different type of paint damage. I finally threw it away.
For my Fit I decided to go with paint protectant film (X-Pel). It was expensive ($800+ for the complete kit installed) but it looks great and does protect the car. I've seen older luxury and sports cars with it, and the paint and glass on their front ends looked like new. It comes with a 5-year warranty. You wash and wax it just like it's not there. After 3 months of this kind of driving I have no dings or chips and the headlights and fogs are perfect. But a stray rock has already shattered my windshield. I had it replaced in July.
Other Fit owners have already lost 1 or more headlights/fogs. Just add up the cost of replacing those and you'll see that this pays for itself. There are many other makes of this film too (ClearBra, etc.) If your car is exposed to a lot of rocks/debris I would highly recommend it.
But it's not like a trunk: you could just go out the back door. So two questions
what is this access hole here for, and
how do I get that plastic cap out of my hatch door?
It's difficult to get the key into the keyhole. Both keys work great on the passenger side, and they also work great in the ignition. However, they both feel like they are grating against something when I insert them in the driver's side door.
Any thoughts on why this might be, and any suggestions for solutions?
MK
~marc
Also, just called Honda and they think there may be a burr issue with lock tumbler, so I'm taking it in to have them look at it. It's free, so might as well!
Is there some quick way to "patch" the plastic?
What is the difference between a wax and a polishing compound? When do I need to use each? Any suggested brands? Thanks!
I'm wondering what I should use to protect the finish. Wax? What kind? How often? I used to use Rain Dance on my old Tercel, the paste kind that you rub on, allow to dry, then buff off. Is this good for the Fit's finish too?
15 minutes? No way. I spend at least twice that just drying it after I wash it. Waxing it is going to take me several hours, no doubt. I read on the FitFreak forum that it took one person five hours, but he sounds like me, someone who will do every nook and cranny, the inside of the doors, etc.
P.S. Get yourself a squeegee (for wiping glass) and a nice, big, fluffy cotton terrycloth towel, and you can dry off your Fit in about five minutes. Ten tops. Like the Men's Wearhouse guy says: "I guarantee it."
I'm sure when I get around to waxing it it will take me several hours, because I am careful and very detail oriented. No slap dash job for me, not with my brand new Fit! It's a car I intend to keep for the next 20 years or more at least (I kept my previous car for 22 years), so I will take great care with it... at least initially.
I'll bet you don't have kids yet, do you? I used to be the same way with my first new car, a '76 Corolla. Waxed it at least once a month, whether it needed it or not. Probably never had a spec of dust on it, or not for long. But even though I did (and still do) a very thorough and careful job washing/drying/waxing my cars, it doesn't take me as long as you take. Enjoy it--while you have that kind of time to spend on your car.
I'm just really paranoid about driving around in a brand new car, and parking a brand new car near other cars, and the elements (you should see me when hail is predicted!) - I'm kind of panicky about something happening to ruin it.
Already a rock bounced up to my windshield while I was doing 70 on the Interstate! Nothing I could do. The windshield is scuffed in several places from this huge rock bouncing all around on it. Luckily it missed the paint, and the windshield is not cracked, but still. It's not pristine anymore.
Yes, I'll make time for the detailing, or pay someone to do it for me. The latter is more likely at my age.
With cars being so technical now adays there is not much work you can do on them aside for changing the oil and filter. making sure the surface of the car is in good shape is one thing I can do. I wash my cars every weekend, and find that the Zaino finish still beeds up for at least 6 months after you apply it.
That was me today. I am hoping that the weatherman's prediction of "possible hail" was just for today (and not storms later this week) because I won't be able to garage it till next week.
So far I have only polished two panels. One I used something to take off paint from someone elses "ding" to my car and had to polish it because the coat had clear spot where it lost it's shine.
The other was getting bugs off front hood yesterday, being sweet to it while I cleaned each bug away and polished it. Ahhh....
And then this morning I promptly hit a bird. lol I am hoping it is not stuck somewhere under my car or something because I did not see it come out.
I guess I gotta get used to it.
I might polish another panel or two tomorrow, even tho the rain is going to screw it all up by the end of the week.
I don't know, but when you've driven an old car for years, and not even washed it, and let everything that's broken stay broken, only adding oil when it spits out, and gas to keep it going, and just fixing the brakes every so often, to suddenly have a BRAND NEW car, all shiny and perfect, well, it's quite the shift. At least that's MY experience. I was honestly worried about it before I gave in and bought my Fit - oh my god, how am I going to function with a brand new car?! But I'm making it, so far. The rock scuffs on my windshield are a bit of "broken in" proof I didn't need, but at least I'm less panicky now.
Don't feel bad for me. I managed to polish a ding that I got the first week I owned it, just to leave me with a panel to polish a time or two to restore it. lol
I know what you mean about new car shock and the concept of "I might own this car for two more decades."
I almost bought base model and thought better of it when I realized I would be in my fifties when I got rid of the car. I thought midlife crisis mobile, this is it!
When I told my child to take better care in back seat etc and told her she might be able to buy the car off me in ten years when she is ready to drive, she said, " yeah right." Little does she know......
I like having the sport because it gives me the perks I will want for another decade or two (hopefully.)
Now that I am not a kid anymore, I feel a strong sense of responsibility to keep her looking at sexy as the day she pulled off the lot.
I will probably baby my baby, at least for the first few years.
Does anyone know the answer to this?
There seems to be some sort of possible opening on the bottom of the door, but I wouldn't know how to open it and not sure I want to try.
I will have to ask my dealer about this.
Anyone else get one out?
I have had occasion to keep it open for extended periods of time but do not wish to have the light running.
I considered trying to make a metal connection of some pliable metal across the plastic trunk lock. If you look close at the lock on the door, there are little metal bars on the white plastic which I think form a connection across the base when trunk is closed.
Any suggestions or thoughts?
Thanks in advance.
