Fitting Instructions
Fitting Stage 1:-
Open the glove box. Disengage the catches that restrict the opening of the glove box. The glove box should now open completely and hang down on its hinges. Look through glove box aperture and locate the plastic filter housing.
Fitting Stage 2:-
On the front on the housing (bottom front edge) is a small clip Pull the clip upwards and remove the cover. Pull the (first) right hand filter carrier out, then slide the left hand tray into the open space and pull that out also.
Fitting Stage 3:-
You may find some flat plastic panels in the base of the carrier. Remove these with a stanley knife just leaving the grid to sit the pollen fitlers on.
Fitting Stage 4:-
Insert the new filters ensuring that the air flow arrows point upwards (same as mark on carrier). Insert one at a time into the housing. Refit the cover to the housing, and close the glove box ensuring the catches are re-engaged to limit opening.
Do any readers have any concerns with their FITS that I should point out for inspection before the Original Warranty expires?
Here's a video for doing the cabin filter a 2012 model:
https://www.youtube.com/watch?v=_BaO1Nw2n4c
Here's a list of video for changing the air filter in the engine compartment for various years of Fit:
https://www.youtube.com/results?search_query=change+air+filter+honda+fit
No reason you can't do this, both jobs.
