Also, the 15" wheels in other markets have 185 tires, and not 195 like the US market. Maybe 10mm could be making a difference?
Next time you fill up for gasoline (the sound is much more pronounced on a full tank), go to a parking lot where you can safely make some quick stops and sharp turns, and you will definitely hear it.
Either that, or the dealership installed the "platinum soundproofing package" for you.
Other things I noticed so far with 3800 miles:
-No rattles yet.
-Sometimes, downshifting gears lets say from 4th to 3rd, the RPM jumps up so much that it feels like the transmission is slipping.
-The engine's racy sound is more noticeable now.
-I find the intermittent wipers to be useless. The speed never jives with the rain - either too slow or too fast. My old Hyundai Accent had variable intermittent wipers and it was perfect.
-The wipers are leaving scratch-like marks. A few times already that I had to wipe the windshield with windex to make sure its not an actual scratch. It also leaves lines when it wipes. Could it be since the driver side wiper is so long that it doesn't have even pressure on the windshield?
-I always avoid high ramps or those concrete parking slabs because of the low Sport bumper.
-Car feels a little sluggish right now. The car doesn't feel as peppy or sprints as well when it was new. Wait... its still new. :confuse:
To me the pressure seems fairly even since I haven't noticed any scratch-like marks or areas where it doesn't wipe. I have never had the luxury of variable intermittent wipers in my two previous cars, so I am not missing much there.
The "racy" sound is more noticeable now, but I haven't noticed anything out of the ordinary with the shifting in the transmission. It might be that you are getting used to the way the car runs?
After trying hard to hear the swishing sound I finally did. I had to go to a quiet area, turn off everything and did abrupt stops and zig zag turns to hear a really really muffled swishing sound. Haha. It sounds like a water bed.
Has anyone had any trouble with the front ground clearance yet?
How about engine noise and lack of power, is it getting intolerable to anyone?
I guess I hope I don't end up using my car as a snowplow! Mostly if the roads aren't clear I stay home.
Trolling?
Turned off the A/C today and the car sprints again. I wonder why the A/C is bogging down the engine now. When I bought the car, I felt the A/C had no effect on the engine's torque response. Hmmm....
With all the new cars I've owned, I think this is just a normal progression. The car won't be as quiet, won't be as peppy and the a/c will make its presence felt.
Actually, first time I washed the car today and found that my right rear tire was only at 10psi and a nail stuck to it. :sick: I'm sure this made the sluggishness more apparent. Brought it back up to 32psi and its a little better but still not the same as when it was new new.
Also while washing the car, I found the plastic guards inside the wheel well facing the headlights were both popped out of place. I got scared at first thinking that the car might have been at a body shop but I think its because the lower part of the plastic is very flimsy.
I don't see how this can be normal "progression" after probably a couple thousand miles. Maybe if you were nearing 100K miles.
Can someone point me to a page number???
I don't drive in the dark much (my other half does), so I'm mostly familiar with the well-lit radio, and HVAC controls. Are the cruise controls on the steering wheel lit? They have raised bumps so you can find them without looking down, but I don't know that they are lit.
As far as mileage goes, our last daily driver vehicle had over 50,000 miles on it the first year we owned it. I don't know if we'll put quite that many miles on the Fit, since our last daily driver (which we still own) was a Wrangler. A Fit Sport just can't go some of the places I've taken the Wrangler, and it will also probably stay home when we get the occasional big snowstorm. For some reason, I don't like messing with chains and snow shovels at 4 in the morning.
Theory 1: There are two access panels on the passenger side of the cargo area that don't fit particularly well. I bought some little foam "dots" and used them to pad the openings. It *seemed* like that fixed it, but then the rattle came back.
Theory 2: The plastic liner on the hatch comes down to two points on the sides, and they're not particulary attached to the metal door at all. More foam dots. Again, for a while it seemed like the rattle was gone, but no such luck. My husband refused to ride in the car for a road trip; the rattle was so bad in the first two blocks that we turned around and took our lower-mpg car instead.
Theory 3: The center rear seatbelt retracts into the ceiling. There are two metal pieces that slide into slots for storage. They don't seem to stay particularly well, though, and I'm wondering if the plastic on the lower clip is rattling against the car ceiling. I also noticed that there is a bracket around the belt where it goes into the car ceiling, and this swivels around very easily. Is it supposed to? Would you mind running out to your garage and checking for me?
However, one of the first places I would be visiting is my dealer - the car is still warranty, and the dealer should be able to fix it.
With all of the rain we've had this past week, it wouldn't surprise me if you had some water carry a few small stones, or some gravel up in there. Try swinging by Pearson Honda's service area, and ask them.
That was probably me. My Fit reminded me its at 15% when it was only around 5500 miles. I got my oil change this morning from the dealer for $26.45. It had 6043 miles (still at 15%) when I brought it in. Thanks.
But it seems that this problem happens on other Honda vehicles as well. A Google searched turned up a bunch of threads about the same issue happening on other Honda vehicles as well (Especially on the Ridgeline).
I'll post on the outcome of the service visit soon...
Honda Fit - Wind Noise TSB - PDF
I can now take the TSB with me to the Honda Service Department and save time.
I hit the underside of the front end while backing out of my friend's driveway too fast. The bumper popped out on the drivers side about a half inch...right at the the wheel well. The plastic hole broke that held the bumper on there...probably by design, as a shock absorber for collisions. I loosened the screw on the underside of the wheel well and put the tab back around the screw, and re-tightened it. Seems ok.
Anyone have this quirk too and is it something to be concerned about?
To the HOST, can you bring back the "problems and solutions" category? These micromanaged subdirectories are too much. You seriously can't categorize each detailed issue or subject. Thanks.
