Toyota RAV4 Maintenance and Repair
tango7ttango7t Member Posts: 1
I've reach the 1600 mile mark and decided to change the oil for the first time. I have looked all over the place but have absolutely no idea where the oil filter is located. Is there anyone who can identify where it is?
«13456716
    lampwalklampwalk Member Posts: 17
    If you have gone 1600 miles, did your RAV 4 use any oil? The owner's manual mentions that it can use up to 1.1 qut/600 miles and wonder if that is only during break-in, or for the life of the vehicle! I have driven 350 miles and do notice the oil level is down to between the high and low mark.
    Also, do we check the oil level with a warm engine or cold? That was a cold check, so maybe with a warm engine, it would be up to the top.
    My dealer could not tell me for sure the brand of oil to use--and, since it could use up to 1.1 qt/600 miles, thought I ought to have an extra quart along--so is the oil that comes from the factory the same as the regular 5W 30 that the dealer would use to do an oil change?
    I am used to, after turning off my vehicle, in Park, taking key out of ignition for the steering wheel to "lock" into position, but my RAV 4 V6 4x4 does not do that--is this normal?
    bob777bob777 Member Posts: 19
    I've had this SUV for about three months now and I'm not at all happy with it. The break fade seems to have gotten better now that it is broken in, but the breaks would fade even during the first hard breaking in warm dry weather. So much so, I thought I would not get the vehicle stopped in a couple of situations. I don't drive fast either and I have not noticed this issue on any of the last few cars I've had or the other cars I have now. Anyone else have this or know what could be causing this?
    The other issues is downshifting. Lack of downshift has happened twice now when I was going about 10 MPH and tried to pull into the next lane. The SUV stays in the higher gear even with my entire strength pressing the accelerator to the floor, even when I slam it to the floor several times. Anyone else have this or know what could be causing this?
    It seems Edmunds won't post my review of the Rav4 outlining this. I'm not sure why, but I can't believe I'm the only one with these issues.
    When did you submit the review? They are reviewed for content (profanity, spam, etc.) so they don't get posted immediately.
    Other owners -- please take a few minutes to write your own review.
    kjtg1kjtg1 Member Posts: 12
    Over 4000 miles and no oil used yet.
    I submitted it a several days ago. There was no profanity or spam. Not sure why it was not posted. I suppose I should try again, perhaps I hit the wrong key.
    Several days isn't long enough for your review to go up; it takes several days just to review a batch, and then a while longer to queue them up for posting. I bet there's at least four or five hundred ones submitted every week.
    I'd give it a couple of weeks before writing another review. Of course you could write reviews for any other cars you own in the meantime. :shades:
    ofeliaofelia Member Posts: 10
    I purchased my rav4 v6 2wd April 24. Everything was going smoothly until last Friday. I put the gear on reverse and hear a humming/droaning noise. I got to work and tested if the sound appears again, and it did. It seems to be intermittent and mostly when driving in slow speed. I took it to the dealer, twice, and they finally figured it was the fuel tank/pump. I am a bit hesitant in their diagnosis...I think it is the transmission? Anybody with the same problem? By the way it's still in the shop waiting for parts. Kinda dissapointed coz I've driven the vehicle only about 300 miles. ">
    morganlefeymorganlefey Member Posts: 1
    I just got my Rav4 Sport two days ago and I am noticing that the keyless remote doesn't always work (on both keys). If I try and press the 'unlock' button twice, only the driver's door will open, and then the engine fan goes on. The fan stays on for appx. 10 seconds and while its on, neither the lock or unlock buttons on the key(s) work. Once the fan shuts off, I can unlock all the doors (or lock them). I haven't called the dealer yet, but I'm wondering if anyone has encountered something like this yet...
    hlee_goodhlee_good Member Posts: 4
    I love my 06 Rav4. But I am not sure the mileage I got is ok or not. I used the regular grade gas, got around 24 mpg, is it good? any comment are welcome.
    The last time I measured before I took it to the dealer to be repaired, I got 27 mpg. I drive mostly freeway though, I am still in the break-in period so it might change.
    jimd4jimd4 Member Posts: 877
    Well since some oil will drain down when the car sits overnight etc. it would probaby measure higher than if you ran it and shut it off and measuered right away I would think
    It's been over two weeks now. I don't believe I made any mistakes completing the review in. Should I try again?
    There's a queue being reviewed now for posting later next week; my gut says give it a little bit longer. :shades:
    You could post your summary info here while waiting to redo the consumer review.
    joeujoeu Member Posts: 5
    I just bought the base 2WD model and haven't noticed any brake fade issues. However I did take the car in to find out how to remove the spare tire cover to allow me to install a bike carrier that fits over spare. It took two mechanics to get it off and putting it back on is right out of "mission impossible". It's easy to get the top edge on but there is no clearance to do bottom. The manual says there is a clip release but not on my model.
    Anyone else having this problem or have ideas to fix?
    johan1johan1 Member Posts: 21
    I have a 2wd sport. I also have had the puzzle where to find the spare tire latch. You know what, there isn't any for base and sport. I once went to the dealership where I bought the car for that. I was asked to wait in the waiting room. When I was called out, the spare tire was already removed by a tech and put back on half way. The tech needed my car key to open the rear door so that he could put the whole thing back. One thing you may like to know is that the cover is directional. The dent shape (nike like?) should go from left bottom to horrizontally right. I havn't tried to remove the cover by myself yet :) .
    silveravinsilveravin Member Posts: 8
    Ofelia, I have the same noise on my v6 4x4 sport...a low drone/humming noise that is only noticable at idle and low speeds. At 750 miles, a little concerning. Seems like its' persistent in park, neutral and drive. I am interested in learning what the dealer finds and if it is resolved.
    I took it to the dealer because it was annoying. It took them a few days to figure it out, but they replaced the fuel tank and pump. My car was at the shop for a week. So far I have not heard the sound, but now I am very sensitive to anything I hear coz it might come back. Hopefully that takes care of that problem-I like the car so far.
    Ofelia
    Glad the problem is resolved, knock on wood!
    Was your noise intermittent? Was it barely audible or louder?
    Mine only occurs every few days or so...the reason I haven't taken it in to the dealer yet, cuz they may send me home saying nothing is wrong. I know what you mean, listening for every sound...we're just cautious owners. Better to fix it under warranty!
    bgsayebgsaye Member Posts: 6
    I have also noticed the downshifting issue on my new 4cyl Sport model. I am very interested to see what comes of it. It is almost like the car doesn't even respond at all for a second or two...very dangerous when trying to make a turn into traffic. :confuse:
    it was intermittent, usually on slow speed and when shifting gears. It is audible especially in the back of the vehicle, when I took it to the dealership, they were able to hear the noise. So it didn't look like I was hallucinating.
    Ofelia
    avrguy73avrguy73 Member Posts: 26
    Yupp, I got scared the other day. I wanted to quickly pass a car, so I pulled into the other lane, there was a car coming, but it was managable, so I roll over and floor it: the car just sits there and nothing, actually I got cursed at and the other car had to make an emergency stop. But, just before he'd hit me, the car woke up and shot out like a rocket. But there, that one-two seconds makes a difference. It is the transmission I think, it takes too long for it to downshift. I agree, a dangerous thing. Now I know that before i attempt to do anything like that in hte future I should manually downshift prior to that!
    lirlir Member Posts: 81
    Is anyone else besides me getting poor MPG? I am only getting 20 in the city, I expected 24. I have the 4 cylinder/2 wheel drive Ltd. Is there a chance that it will get better with time? I'm a bit disappointed and almost wish I'd kept my Civic!
    I got gas today and computed my mileage, about 22 mpg 6cyl/2wd, combination hwy/city. I expected more, but it's about the same as the one I traded Mazda tribute v6/2wd.
    andrelaplumeandrelaplume Member Posts: 934
    Its driving me nuts. Adjusting up or down makes no difference. It just loud enough to be annoying and its there most of the time. Anyone notice and and better yet, find a way to fix it?
    jbdrebel70jbdrebel70 Member Posts: 1
    Hello Toyota 2006 RAV4 4cyl base model owners, anybody out there experiencing unusual vibration on driver seat while air conditioning is on. It usually happens in the Drive mode while I'm waiting on a stop light. It does not matter it is on level 1 or 4 the vibration is constant. When the air conditioning is off things are fine.
    It really hard to get the 06 RAV to cool down on a real hot day...almost think the AC is undersized or the car.
    Anyone find the extreme left and right vent deflectors annoying. You can only adjust airflow up/down OR right/left but not both...I guess they look cool though.
    Anyone else annoyed the doors do NOT auto lock when put in gear or auto unlock when put in park or shut off....another real pain, especially with kids.
    Anyone upset that you can only use your key to get in the front drivers door; that is if you do not have the keyless entry key handy.
    Anyone miss having a light in the glove box or IN the hatch...what good is having in the hatch door since you open the door away from the hatch!
    Finally, anyone upset by the lack of body side molding...though you can get it from dealers in Canada.
    That seatbelt rattle is the worst of all though!
    gpurkgpurk Member Posts: 13
    I got my 4WD V-6 about a week ago and the first tank was 22 MPG. Dealer told me it would get better after a few tank fulls. Mostly City. Hope to get 28 to 30 on the highway which for a V-6 is very good. Going to Branson, MO next week and will be 600 miles round trip so it should be a good measure of all highway miles. Will report that MPG after my return. Luv my RAV.
    risarisa Member Posts: 14
    Is the downshifting problems only occur on 4 cyl? how many mileage do you have when it happen? Wondering if this problem will continue even if the vehicle is alreary broken in. I have Rav4 4cyl, after reading some post here with downshifting problem. I am kinda worried if it will happen to me. so far the vehicle is doing fine, It only have 150 miles on it. Try to drive it eassy for now, I don't even take off fast. When i stop at the red light and when i go, i just hit the gas smoothly the most it would only go up to 2000 rpm I don't care if driver behind me will complain and i don't hit my breaks hard either.
    spacewagonspacewagon Member Posts: 16
    MPG 28.6, pure highway, 60miles/hour.
    Mine is a 4 Cyl 2 wheel drive. It first happened to me when it had about 3500 miles on it. Driving it easy makes sense, although in emergency situations that may not be possible.
    I don't drive fast either, but when I need the power I expect it. The issue to me is the car needs to be more responsive to driver input.
    Mine has 6500 miles on it now and it gets 24 MPG with mostly city and some highway miles. It gets 28 MPG with strictly highway miles. The cars I've owned in the past got get better then the EPA ratings. Actually, this is the first car I've had that gets at or less than the EPA ratings. I think I'll wait until I get about 10 thousand miles on it before I decide Toyota pulled a fast one.
    By the way, I also bought a new Chevy Colorado. It's rated 20 MPG in the city and 27 on the highway. Believe it or not, it does better on gas then the Toyota.
    Thanks for the input. I only have about 1000 miles (the car is 6 weeks old), but I too will wait and see what the MPG's are later. I expect at least 24, and right now I get 20. So I'm hoping Toyota didn't pull a fast one. My Accord supposedly also gets 24 MPG in the city, but it's more like 27 for me. Basically, I was expecting it to be like my old car, and it's been disappointing so far after 6 full tanks.
    Lots of complaints about vib under seat with A/C on an off . See other RAV4 sites on net.
    I noticed it when the car is stopped and idling, like at a stop light. When driving in the car and sitting in the rear seats or passenger seat I also feel a vibration in my feet...very unsettling.
    folkepalmfolkepalm Member Posts: 4
    After starting the Rav with the remote starter, how do you enter the vehicle without shutting the engine off? Having to start the engine a second time seems rediculous and very unlike Toyota.
    Well petl, perhaps not a 4 second delay, but a good 1-2 second delay. And it is not going away.
    mterrellmterrell Member Posts: 21
    yea 1 to 2 second is probably correct. Just when it happens it seem like longer . 2 second delay is about right right.
    having 2k miles on the car within 20 days now. Since the first day, I noticed when driving on highway, if I leave my hand out of the steer wheel, it can not drive stright after 2-4 seconds, either towards righ or left. Is it normal? thanks!
    Please pardon the post shifting, but we've opened a MPG discussion and seeded it with some posts from the recent thread on mileage.
    Please visit the new Toyota RAV4 2006+: Real World MPG discussion and report on your mileage there. Thanks!
    Yup, in the seat belt adjuster on both front doors It gets louder as the weather gets hotter. Occurs on smooth or rough pavement. Sounds like a ticking clock or worse. Anyone find a solution please post!
    wiley1wiley1 Member Posts: 2
    When I first got my RAV4, the passenger side seatbelt latch was rattling against the B-pillar plastic whenever I would go over bumps or make a turn. I took it to the Toyota dealer and they twisted the latch so the metal part would face away from the B-pillar. Is this the problem you are having?
    not sure if you were joking but it is occuring as I am wearing my belt. I am not talking about the noise that comes from the floor where the belt is secured...this is easily fixed wityh some felt. This is in the pillar and almost constant from both doors as the weather gets warmer. Mine can not be the only one unless the assembler did both doors and did something wrong. Seriously, if the car made this noise when I test drove it I'd be in a Forester now! I guess I should have waited for warmer weather. At least I am finding some others...there are a few posts in the RAV4World forums...
    hells_bellshells_bells Member Posts: 21
    Here's a problem - they don't make enough V6 Limited models.
    rcolbournrcolbourn Member Posts: 5
    On my wifes 06 Limited Rav4 with 9 speaker JBL it seems that the FM reception is not so great. Radio makes a loud intermitant scratchy noise even at low volumes. The dealer looked at the car and said it appears to be normal. My 04 Tundra gets great reception in all the same places. Has anyone experienced this problem or have any suggestions. Thanks Bob
    What I've noticed with my JBL is that the volume goes up and down all by itself. Very weird!
    Is your radio volume going up and down due to the ASL (automatic sound Levelizer) being turned on. This feature increases or decreases the volume in accordance with the driving speed. Try turning this off. p.174 owners manual
    Will try that. Thanks for the suggestion! I just thought my ears were playing tricks on me. :blush:
    oxwoodoxwood Member Posts: 2
    I've owned my 06 RAV4 for about 600 miles now and shortly after driving it off the dealer lot I too noticed the rattling coming from the driver seat belt adjustment. I'll be taking it to the dealership soon to resolve because it is very very annoying when everything else is pretty quiet. If anyone has experienced this and found a solution, please advise! :mad:
