On my first 6 fillups in my Yaris Hatchback, my average is 41 mpg, with no highway driving. What a great car made in Japan, not America.
i would prefer "supporting my country" and buying american, but who is going to pay for my repair bills and for poor gas mileage? in my research, the yaris wins hands down oveir its competitors with its high tech engine, design and real world gas mileage and at a cheap (comparitive) price.
direct ignition on the yaris is cool! just barely turn the ignition key, release and it starts right up!
in my area, i am amazed at the junk many people still drive:
suv's pickup trucks and older american cars that stink (from the exhaust)... who can afford to drive them?
the japanese and now the koreans are poised to really deal a death blow to the american auto industry once gas goes over $3.00 buks a gallon. my guess is that won't be too far off.
Also illegal to coast downhill in neutral, at least in some states. Just keep it in gear and take your foot off the gas as much as is practical--that saves a lot right there. And when your foot is on the gas, use a very light touch--especially important with automatics to keep the gear as high as possible. It helps to blip the gas enough to get the car to up-shift, then lighten the pedal pressure so that the revs go down but it stays in the higher gear. Watching the tach (or listening to the engine noise if you don't have a tach) is useful here.
My last car was a Toyota Corolla, with an automatic, 174,000 miles, and no problems with the transmission, after coasting many miles.
I like to coast.
You don't "slam it" back into gear, you match the revs to the speed and slip it back into gear without a quiver.
As you say, coasting downhill is not the greatest idea unless it is a very slight grade, and coasting in gear in that case will give you engine braking and still save you gas.
Is anyone having the same questions about fuel economy? I am very disappointed. My salesman told me to bring it in and have the mechanics look at it, but I'm so reluctant to have someone start guessing and fooling around with it. I don't want this to escalate into something else.
1) How many miles do you have on the vehicle? In your post you state 16 miles. that can't be right after 4 mo. of ownership.
2) how are you measuring your gas mileage? I would suggest that you keep a small notepad/notebook in the glove compartmnet to accurately track your gas mileage. make columns: date, odometer reading (current miles at fillup), miles (the difference between last odometer reading at fillup and current reading at fillup), gallons (gas pumped at fill up), MPG (miles divided by gallons of gas)
What this does is allow you to track each individual tank of gas and analyze your driving habits. I also use it as a way of tracking maintenance like changing the air filter or fuel filter.
3)What is your typical driving pattern each day? I commute 86 miles a day. All but 4 miles is highway but I also have to deal with rolling hills and some congestion so my gas mileage normally comes in just a hair under the sticker for highway mpg. Also i do mostly city driving (very short trips) on the weekends. Oh yeah, my vehicle has 131k miles.
it takes several thousand miles for a engine to break-in so I wouldn't panic too much.
It's true that I do not put many miles on the car, however, even the salesman said I should be getting better mileage then that.
During the hot weather I thought it was air conditioning usage that hampered the mpg. Now that I no longer use the air conditioning, the mpg remains the same.
Thank you so much for your reply.
Taken once on an 80 mile trip on Garden State Pkwy. and still had the same mpg.
I want to add that I think the car drives beautifully and has good pickup, more than I expected.
Thank you for your response.
Keep track of the mileage and try not to be too overly obsessed. the more you worry, the less you will enjoy your new car.
Pushing in the clutch to coast only causes the tiny bit of wear when the pressure plate releases the clutch and it starts to slip, but it is no more than shifting.
However, when slowing to a stop in gear, the momentum of the vehicle keeps the motor running, and thus uses no fuel (the injectors cut back and/or turn off). When you push in the clutch, the motor has to burn fuel to keep idling. A lot of times, you are using more fuel by coasting (though a negligible amount) than if you were to keep it in gear, foot off the gas, and coast to a stop.
Of course, you can coast in neutral with your foot off the clutch pedal, and avoid this issue entirely. And in the end, no car lasts forever, just as all wear parts in any car will eventually wear out, so none of these choices leads to the end of the world anyway. :-P
I drive mostly in the city and I have consistently got 33.5 miles per gallon. I have drove the sedan on one long highway trip from San Francisco to Chico to visit my brother, and I got 40 miles per gallon!! I was driving between 70 and 80 MPH on mostly open highways.
City driving on the other hand, I have not heard many people getting at or above the EPA MPG (34 MPG). I think that the Yaris may be getting below the EPA MPG, somewhere between 28 and 31 MPG.
Is anyone who mostly drives in the city getting silimar results?
With a spread between city and highway that narrow, your city miles are more likely suburban than congested inner-city with a stop at every block and a lot of idling.
Most of the subcompacts can have a range so severe that highway mileage is double hard city mileage. Every one of these small cars has an owner that gets teens for gas mileage in true city, but mid-thirties or better on a long highway trip.
Sounds more like suburban miles rather than city. Problem is, "city" is a broad term than can vary widely and affect mileage just as much.
A congested, downtown drive where you wait 2 or 3 cycles to get through stoplights every block or two isn't what the EPA had in mind with their estimates.
Seems to be my observation from the forums.
I am interested in hearing from fellow Yaris and Echo owners on this question. Others need not apply.
As Steve Martin used to say,
"Well, ex-CUUUUUUUUUUUUSE-ME!"
lakesguy, "Toyota Corolla Real World MPG Numbers" #123, 30 Jan 2007 1:16 pm
1. He is very well informed, as evidenced by his insightful economy car test drives/comparisons here on Edmunds;
2. He's usually, although not always, right.
In this case I vote with Backy. Your lower gas mileage is probably due to the onset of winter.
The EPA has acknowledged, in coming out with its revised 2008 criteria for gas mileage reports, that one of the major factors decreasing gas mileage is cold weather. This is for several reasons: the engine has to run richer, hence less fuel efficiently, while warming up; the engine has a deeper hole out of which it has to warm up, so warm up takes longer; it's colder outside, so warm up takes longer; a 5W-30 or 5W-20 conventional motor oil is thicker and less fuel efficient at freezing temperatures (a synthetic, especially a 0-30, can help in this regard); using the cabin heater slows down the warm up process; and there is more road friction on a wet/snowy road than on a dry road. Until the car warms up, it needs a richer fuel mixture just to keep running, and friction is higher than at full operating temperature. And the tires are stiffer, and hence less fuel efficient while warming up. Finally, most people take short trips (5 miles or less) which amplifies the "hit" taken from the cold weather.
This affects ALL cars, not just Yarii, so Backy was right to chime in; although the difference in mpg, in absolute numbers, appears greater because 15% of 37 mpg is a bigger number than 15% of 14 mpg.
Finally, many states switch to "winter blends" of fuels which are also less energy rich and further affect mileage adversely.
Winter driving and its associated fuel mixture will affect ALL cars, including your Yaris. There is no need to be acting like a spoiled little kid....
Not sure if that helps, or if I'm qualified to answer...
You needn't get too "EXCITED" lucy. Trust me, it will NEVER matter. And what's your excuse? No more spaghetti in the house? You don't own a Yaris either. All you do is make disparaging comments about them. Thanks for dropping by to leave another "DEPOSIT."
Nippononly--at least you actually drive one of the cars I requested input about. Thank you for your input. (See, I can be perfectly civil.) As to your crack regarding whether you are "qualified," the weather in NW Ohio (per the post where I proposed the question) has been below freezing since the first of January. You must be pretty smart if you live in California. You figure it out...
As I stated before, and you should know this if you live in Ohio, winter fuel mixtures and the cold weather will have a negative affect on a vehicles milage. It doesn't matter if the car is a Corolla (which I drive), a Ford, a Nissan, or a Yaris.
The average is 42.6 mpg. I live in Pennsylvania, and winter is a factor, but not as much as I expected. This car is excellent for fuel economy when driven correctly. I expect to get to an average of 44 mpg in the spring.
date filled miles gals cost mpg
02/07/2007 297.7 6.98 2.199 42.65
01/31/2007 297.5 6.923 2.219 42.97
01/22/2007 260.8 6.205 2.279 42.03
01/15/2007 169.7 3.857 2.319 43.99
01/09/2007 316.6 7.331 2.359 43.18
12/28/2006 307.8 7.23 2.399 42.57
12/21/2006 206.6 4.632 2.379 44.60
12/15/2006 117.0 2.814 2.319 41.57
12/12/2006 279.1 6.82 2.339 40.92
12/01/2006 258.6 6.01 2.259 43.02
11/20/2006 309.0 7.403 2.179 41.73
11/09/2006 285.7 6.85 2.159 41.70
Fuel Purchase Records
Date, Miles Traveled, Gallons, Total Fuel Cost, Driving Conditions: City, Hwy, MPG
05/13/2006 212.70 5.776 15.30 90% 10% 36.8
06/06/2006 359.60 9.650 25.27 100% 0% 37.3
07/01/2006 372.50 9.987 26.86 100% 0% 37.3
07/14/2006 134.20 3.493 9.43 100% 0% 38.4
08/09/2006 392.30 10.212 28.38 90% 10% 38.4
08/28/2006 230.30 6.048 14.57 100% 0% 38.1
08/28/2006 209.00 5.530 14.15 0% 100% 37.8
08/30/2006 396.20 10.109 26.58 0% 100% 39.2
08/30/2006 403.10 9.974 24.13 0% 100% 40.4
09/30/2006 297.80 7.960 15.99 100% 0% 37.4
10/25/2006 373.70 10.159 19.80 100% 0% 36.8
11/21/2006 316.30 8.534 17.14 100% 0% 37.1
11/22/2006 390.60 10.311 21.75 0% 100% 37.9
11/25/2006 400.40 10.198 22.22 20% 80% 39.3
11/26/2006 280.90 8.058 16.75 0% 100% 34.9
11/26/2006 301.90 8.772 17.54 0% 100% 34.4
12/09/2006 363.10 10.249 21.51 70% 30% 35.4
12/27/2006 328.30 8.994 18.97 100% 0% 36.5
01/17/2007 354.10 9.856 19.41 100% 0% 35.9
02/11/2007 360.10 10.181 19.94 100% 0% 35.4
