2007 Toyota Camry Problems and Repairs
1959698100101106
  • zaken1zaken1 Member Posts: 556
    There is only one wire that carries the signal from the knock sensor to the car's computer. This is the only wire that could have been affected by a rodent. It is NOT necessary to remove the intake manifold in order to test this wire. It can be checked by disconnecting the computer's wiring harness plug, along with the wiring harness plug to the knock sensor; and then using a meter to measure the resistance between that wire and ground; together with the resistance between that wire and the battery. If the knock sensor is totally inaccessible without removing the manifold because of its location; the test can be performed by just disconnecting the harness plug at the computer, locating the knock sensor wire in that plug (which is listed by its color in the service manual) and then testing the wire for either shorts or grounds while the knock sensor is still connected to the other end. This may or may not be the standard procedure recommended in the service manual for testing this problem; but it will work. However; it will require a technician who understands electronics; rather than a flunkie who only knows how to do what the manual says. If the dealership refuses to do this simple and inexpensive test; they are either trying to conceal their ignorance, or they are determined to rip you off. Try another dealership; or take the car to a competent auto electrical, fuel injection and computer specialist and pay them to test the wire. It should cost much, much less than $500. There is a significant chance that the problem is caused by an internal fault in the computer; rather than a chewed up wire. Remanufactured computers for older Toyotas can be purchased for less than $400 from places like www.rockauto.com. But they don't list computers for 2004 and newer Camrys. You could also order a used computer from a 4 cylinder 2007 Camry by phoning a wrecking yard that has a nationwide parts locating hotline. After a request is placed on the hotline; any yard in the US that subscribes to that hotline and has this part will contact your local yard and arrange to ship the computer to them. If you want to see how much you'd save by going this route; phone your local Toyota dealer's parts department and ask them the price for a computer for your car.
  • beantownbeantown Member Posts: 228
    Thanks for the responses. Just to clarify, they were able to run the test and confirm the bad wire for free. What they couldn't do for free is confirm WHY the wire went bad. In other words, they could access whatever they needed to access to run the test itself, but couldn't confirm why it went bad and supposedly can't actually replace the bad wire without removing the manifold first.
    I'm still weighing my options on this one. It's driveable for now, so I'm not forced to decide one way or the other.....and I need the car (don't feel like paying for a rental while dealership after dealership look at it). I just have a feeling that no matter which dealership I go to, they're gonna give me the same "not covered under warranty" angle.....even if it is 100% the car. I mean, really, unless I'm standing next to them when they open it all up, how else could I ever prove that something wasn't nesting in there? They can essentially say whatever they want.
    Ask to be there when they take it apart. Call Toyota and open a case.
  • ledzepplinledzepplin Member Posts: 41
    SO!
  • mssweetmssweet Member Posts: 3
    Has anyone had any problems with the water pump? Dealer has told me I need to have my water pump replaced, seems like I should not have this problem so soon.
    I also noticed that when I step on the gas the car makes rattling or knocking noise.... what could this be?
  • hislambhislamb Member Posts: 4
    I have a 2007 LE and when I accelerate I do hear what I think may be valve clicking. When my air condition is running (and I live in the New Orleans area) I am hearing a strange clicking/swooshing noise. Conversely, turning the a/c off will eliminate this particular noise, but the acceleration clicking remains constant.
    I actually had a rat eat thru my firewall when the car had only 7K miles on it. I nearly traded the car in then. The recall happened after that point.....water under the bridge. Well, I now have 35K on it.
    Well you'll need someone to look at it, and determine what the cause of the problem may be.
    For the engine clicking, what I normally do is to remove the accessory belt, and then start the engine briefly. If the clicking continues, then you know the problem is internal to the engine. If the clicking stops, then the problem is with one of the accessories driven by the accessory belt. I typically find problems external to the engine, as opposed to internal. With the engine off, and belt off, you can then turn the accessories by hand, and feel whether the bearings are good or not (looking for wobble, free and smooth, etc). Replace what is bad.
    For the air conditioner 'swooshing', I assume that is a noise you hear inside the passenger compartment. That may be low water levels in the radiator/heater, or low freon levels in the A/C system. Or, it could be a number of other things. It's much easier for someone to diagnose something when they hear the sound themselves, as opposed to your interpretation of a sound, relayed across written words to the internet.
    So get someone to look at it, and see what their diagnosis is.
    edited September 2010
    It would be helpful to know why the dealer said the water pump needs replacement. If it was because the bearings were loose; a replacement definitely would be necessary. But if the dealer said there are signs of "weeping" coolant around the pump drain hole; this possibly could continue at about the same level for a long time to come, without it getting severe enough to do anything about. It also depends on the quantity of coolant that is being lost: If the coolant level is dropping rapidly enough that it is necessary to add coolant once or more every month; this should be attended to. But if there is little or no indication that the coolant level is dropping significantly, then coolant stains near the water pump area are strictly a cosmetic issue.
    Many people confuse a sound that they think is valve noise with the pinging that is created by use of low octane fuel. The way to distinguish those two types of noise, which both sound similar; is to notice when and under what conditions the sound is loudest. Valve train clicking is usually loudest when the motor is idling; and does not become louder when stepping on the gas. It often can also be heard while the car is slowing down. Valve train clicking is often caused by not changing the oil often enough, or by using an unsuitable oil type, or by mixing or changing brands or types of oil. Contrary to popular myth; the additives in many oil types will react chemically with each other, which can lead to shortened engine life and possible engine damage if one brand and viscosity of oil is not used consistently.
    By contrast, pinging usually cannot be heard at all when the motor idles or is slowing down; and becomes louder as you press the accelerator pedal further. Pinging can be caused either by low fuel quality; or can also be caused by excessive engine temperature, or low engine oil level. Please be aware that some types of coolant leaks can cause the coolant level in the radiator to drop; while the level in the plastic reservoir bottle may look good. So it is ESSENTIAL to check the level directly in the radiator (by removing the radiator cap while the engine is cool) whenever the engine begins to run above the normal temperature, or pings. The radiator should be filled to the very top of the filler neck. When adding coolant, be sure to mix the pure coolant from the bottle with equal quantities of distilled water, before pouring it into the cooling system. Adding water to coolant is necessary in order for the coolant to transfer heat efficiently. Using 100% pure coolant will make the engine run hot.
    There is also a third type of similar noise, called piston slap, which is loudest when the motor has not warmed up to normal operating temperature, and often goes away or is greatly reduced after the motor warms up fully. Piston slap is loudest when driving at a steady speed or accelerating slightly. It usually cannot be heard when the car is slowing down. Piston slap in Toyotas is often heard when using very light viscosity energy conserving motor oil (typically 5W-20 or 5W-30). These oil grades were mandated by the US government, because they theoretically increase fuel economy (by less than 1 mile per gallon). But the legislators who pushed that law through were not aware of the fact that some engine designs (namely Mazda rotarys and Toyota) experience adverse wear and noise when using such lightweight oil. New car dealerships in the US who install anything but energy conserving oils are liable to be legally prosecuted; but this law does not apply to independent garages or people who change their own oil. The best oil for reducing piston slap is Mobil 1 full synthetic (but only in 0W-40 grade). 0W-40 is a European oil formula; which was developed for Porsche and Mercedes. Any store that sells Mobil 1 oil can order it in 0W-40, if they don't already carry that viscosity.
  • thetxstangthetxstang Member Posts: 28
    An excellent, informative post. Thank you, zaken1.
  • barroncbarronc Member Posts: 44
    I haven't had any problems with my 2007 Camry's water pump. How many miles do you have on your car? I experienced a knocking from the engine (V-6) once but the dealer told me it's from a bad batch of gasoline (watered down). It never happened again after that. I use mid-grade 89 octane or once in a while high test 92 octance.
  • notmybmwnotmybmw Member Posts: 101
    As zaken hinted at.......but didn't come right out and say it........the "rattling" noise you describe IS probably pinging, caused by poor quality/low octane gas.
    Put a tank full of the 'good stuff' in her and see if it goes away. (also, as zaken DID say, be damn sure your oil has been changed recently AND is topped up). The Camry should not NEED to run on midgrade....and definitely NOT high test...but maybe you're just buying crap gas and you need to put Sunoco or Shell....or some other NAME BRAND unleaded in it....instead of Jimmy Johnson's cheap-[non-permissible content removed] gas!!
    Good luck;
    Mike
    My camry has alittle over 66k miles. I have been told a water pump should not need replacing on a such a new car.
    I will try the higher grade gas .. hope that the higher grade gas will work
    I do believe they said the water pump needed replacing and something to do with the coolant ..this is very helpful information. I also need tires and brakes which are normal wear and tear, but alot to think about all at once. Thanks alot for the advice.
    I use midgrade 89 octane because I find the car runs much better than using regular 87 octane gas. My Camry has the 268 horsepower V-6 and has a high compression ratio. As a matter of fact I use high test 93 octane once in awhile. It may very well be true that if you own a four cylinder Camry you won't need to go to a higher grade gas than regular. But I'd certainly suggest putting in a good grade gas such as Shell, Sunoco, Mobil. etc. I stay away from cheapo gas stations as I find some have watered down gasoline.
    These should be easy to find online. You can see if, in fact, your car has a certain defect that the manufacturer knows about but will not fix unless you scream about it and threaten to sue.
  • cherann24cherann24 Member Posts: 7
    I haven't had that happen - but occasionally the lights on the shift don't come on and it's frustrating. Also - my husband took care of the cars and now that I'm on my own I'm trying to learn. My 2007 4 cyl Camry made in Japan has a small oil leak. I'm bringing it in tomorrow - but they say by my vin number this vehicle isn't one one that has problems. Also - the car seems to ride rough - but since I know nothing of cars - I'm not sure if this is normal or not. What does it mean for a downshift flare problem? What would the symptoms be? Thank you.
    I could probably be one of those woman. I have a 2007 4 cyl Camry. A friend of mine whenever he drives my car states it runs rough, etc. I also have noticed the hesitation - but thought I was imagining it or thought it was because it was a 4 cyl. After reading these posts I am beginning to believe my car probably has a few issues. However, I have 95,000 miles on it and I'm sure will be told that is why. However, the hesitation has always been there - just didn't realize it was a problem. I am getting the oil leak checked tomorrow - it will be interesting what they tell me. I'm sure it will be expensive repair bills. I would love to trade the vehicle in for a small SUV - but my ex is still making the payments on it so I'm stuck.
    TSB - what is this - thank you
    TSB is the achronym for Technical Service Bulletin. These bulletins are issued by car manufacturers to their dealers whenever a problem is identified and a fix for the problem is devised. If an owner brings a car into the dealership for repair of a known problem for which a TSB has been issued, the dealership will apply the remedy listed in the TSB. This is sometimes done for free. There are also databases of TSBs which are searchable by vehicle brand, model, and year. The government's NHTSA has such a database. Edmunds also has one. Some of the more common TSBs for Camrys concern reprogramming the operation of the automatic transmission.
    In answer to another question you asked; a downshift flare is an excessive increase in engine speed when the automatic transmission downshifts to a lower gear (this typically happens when you floor the accelerator to pass someone).
    Small oil leak-have someone try to find out exactly where the leak comes from. If it is from the rubber part of the oil line that snakes around the engine they must fix it. That is what happened to my 2007 v6, only all my oil drained. Don't hesitate to get that fixed. :lemon:
    There was a recall a while back which I believe had to do with replacing a defective oil line. I knew nothing about the recall until the service manager told me he'd have it done at the same time the my accelerator was being fixed. If I were you I'd bring your car to the dealership asap and inquire about a recall on the oil line.
  • 210delray210delray Member Posts: 4,721
    That leaking oil line recall is only for the V6. The 4-cylinder does not have this problem.
    Yes I know. My Camry has the V-6.
  • djm2djm2 Member Posts: 712
    Hi Barronc:
    I find your posting on gasoline very interesting. I own a 2007 V6 XLE Camry with 59,000 + miles. Since it was new, I have used 87 octane / no-name fuel, and I get 30+ mpg on the highway. (I also change the oil and filter every 2,500 miles.) Once a month, I put in some "gas treatment" when I fill up with fuel.
    Best regards. --------------- Dwayne :shades: ;):)
    That's some excellent gas milage for your 2007 Camry XLE with the V-6 Dwayne. I wish I could say the same for my Camry XLE V-6 which I'm planning on selling in a few months. The car has been very well maintained. I have the oil changed every five to six months and replace the air filter every year. Tires always have the right amount of air in them and they're rotated every six months. Since the day I bought the car brand new from the Toyota dealership my milage has been poor. The dealer says it's because it has 268 horsepower but my friend's 2005 Nissan 350Z has more horsepower, is also an automatic and gets much better milage. My car has only 26,000 miles on the odometer. My next car will be American made.
    Hi Barronc:
    Thanks for the "come back" to my posting. On road trips doing 55 to 60mph I have had this vehicle up to 34mpg on 87 octane / no-name fuel. When I am in Pennsylvania, I purchase 87 octane "Sheetz Gasoline!" I have no idea who supplies the fuel to this vendor. I change my oil and filter every 2,500 at the dealer, and my dealer recommends an oil additive BG / MOA. I have used this additive in the oil since the vehicle had it's first oil and filter change. My Camry has a 6 speed automatic transmission. I have had no issues with this vehicle. It was manufactured in Japan!
    Best regards. ---------- Dwayne :shades: ;):)
    Dwayne, may I inquire what tires you're using on your Camry? I also have an '87 Camry XLE V6 and I used to average 28-29 MPG. I recently replaced my tires (35K miles on the originals) with brand new ones and my MPG plummeted to 24MPG. I have read that tires can make a noticeable difference on fuel economy, but I'm stunned at the disproportion.
    You can look up your tire characteristics on tirerack.com. You may want to have your alignment checked.
    Hi thetxstang:
    I am on my second set of "original equipment Michelin Tires." --- I got 50,000 miles out of the first set, and I had the selling dealer intall four new tires and perform a four wheel alignment. ---- I like to keep everything original equipment. By purchasing tires from the dealer, I can get tire service from any Toyota dealer while on the road! This is important to me since I do over the road trips!
    Best regards. ----------------- Dwayne :shades: ;):)
  • lisabaker1989lisabaker1989 Member Posts: 2
    Anything that can go wrong with my 2007 Camry XLE V6, HAS. The VTT-I oil hose blew in my car and there is a recall on it.
    Hi lisabaker1989:
    I soon as I started to read about this oil line problem, I had my line replaced under the extended 100,000 mile warranty! ------ It took about four hours to replace it with a steel line! ------ I had to be "professionally insistent" to get the dealer to replace this part prior to it failing. ------ Once I told them that I "did not want to experience this oil line failure while on the road," ----- they agreed to replace this oil line!
    Best regards. ------------ Dwayne :shades: ;):)
    Yes I know, I brought my 2007 Camry XLE V-6 into the dealership for the accelerator problem and the service manager said there was also a recall on the oil hose. He said they'd replace it along with the accelerator fix that same day. Up to that time I knew nothing about the oil hose recall.
    Good Morning barronc:
    At the present time I have two (2) primary vehicles. ---- A 2007 V6 Camry XLE, and a 2010 - 4 Cyl Malibu LTZ. ---- I have all of my service performed at the "selling dealer," (which is the reason why I am VERY CAREFUL about choosing the dealer), when I make a vehicle purchase. ---- I keep "outstanding service records" on both vehicles, and the dealer is aware of this fact. ---- My service intervals for each vehicle is "HALF" of what is recommended by the manufacturer. (Example: ---- My vehicles are serviced every 2,500 miles.) ---- When making a service appointment, I keep my "sales person" involved in the process. He / she has a vested interest in the quality of service that I receive, "IF" they want to sell me another vehicle. ----- If I give them all of my service business, I expect outstanding service, and outstanding customer relations, by both the service department and the sales department. ------- I treat the service personal in both dealers in a very professional manner, and in return, I receive very professional service. ----- (I send "hand written thank you notes" after the service has been completed, ---- I leave a "small cash tip" for the service technician, ---- and I give a "bottle of cheer" to my service writer, service manager and sales person at the "Holiday Season!") ---- If you want to be treated as a professional, be seen as a professional person. (Treat everyone with respect, and show your appreciation when service is provided.) ---- I am proud to say that I have two outstanding dealers, and I would purchase another vehicle from them without question. ----- My Camry has been trouble free in terms of malfunctions. The Malibu is a "HOME RUN" for GM and Chevrolet. Prior to purchasing the Camry, I owned a 2003 4 Cylinder Honda Accord. This Malibu drives exactly like the Honda Accord. It is a quality vehicle.
    Best regards. --------------Dwayne
  • knang8888knang8888 Member Posts: 13
    I have a 2007 Camry LE 4 cyl about 45000 miles. I took it to the dealer for an oil change and the dealer mentioned that I need a rear brake job badly. Their estimate is $185.
    This is my first DIY brake job. I went to auto parts store and pick up Wagner Thermoquiet Rear Pads sets (QC1212 - after rebate is about $40) . With a friend's help, we took the rear tires out 1 at a time, open the brake fluid reservoir, remove the caliper, replace the pad with the Wagner pads. The whole job was done less than 30 minutes. We did not bleed the brake when I compress the caliper pistons back. Not sure if this is a good idea. The pads had an uneven wear, both inner pads (by the caliper piston) are less than 10% left while the outer pads still looks normal. I took it for a test drive and I can't tell the difference. The car still drives smooth. Anyway, I'll check it again at 50K miles.
    This is weird that there were uneven wear on the rear brake pads. Just curious if anybody experience the same problem.
    That's typical, found that on all my vehicles over the years. Have the same year/mdl Camry, and did the exact same job about a month ago, but also took the oppty to flush the brake system and rotate the tires as well.
    The reason the pads wear like that, is that the piston itself is on the inside, and when you apply the brake that inside pad is the first pad that contacts the spinning rotor. As you press harder, the caliper yoke (my term) is pulled over, bringing the outside pad into contact with the rotor as well. So the inside pad always touches first, and has the most pressure on it.
  • donewtoyotadonewtoyota Member Posts: 4
    Go back to page 518 and read post #5176 re: Toyota's "new improved" brake pads on Technical Bulletin.
    Thanks kiawah and donewtoyota for the responses. My next challenge to pinpoint the small noise coming from the front of the car. I had new tires put in at 35K and wheel alignment done. This seems to resolve the high speed shaking problems.
    I'm not as happy on this 2007 camry as my previous 87 camry. 87 camry is built solid and drives like new for 10 yrs. This 2007 model no longer drives like new. It hard to stay loyal to Toyota on these problems.
    HI knang8888:
    You are correct with your assessment about the "feel and ride" of the Camry as it ages! -------- While I do not have any mechanical issues with this vehicle, it does not have the "solid feel of my new 2010 Chevrolet Malibu or my former 2003 Honda Accord." ---------- [It is VERY powerful, especially "off the line!" ------- I would like to race a Ford Mustang coming out of a "toll booth on the Garden State Parkway", just to see how it could perform against some competition.] ------------ {Years ago, I had a 1995 Jeep Grand Cherokee with a big V8 under the hood. One Saturday morning I was driving on the GSP coming our of a toll booth, and there was a Ford Mustang in the next booth, so we decided "to go for it!" The Mustang driver was VERY SURPRISED of the power and torque of a big chrysler V8. I stayed right with him till I broke it off at 75mph!} ------- (My jeep only got 15mpg on the highway!)
    BACK TO THE CAMRY!
    You are correct in your observation that the Camry DOES NOT drive like a luxury vehicle! ------ The doors do not close "solid" like a luxury vehicle. ------ (The doors too seem light.) ----- As the vehicle ages, it starts to feel like a "big floating boat." ----- I have the "top of the line Camry," --- (V6-XLE), ---- but it DOES NOT feel like an "expensive / quality vehicle." ---- (It does not feel like a Cadillac!) ----- The appointments on the interior could be more "luxurious," and the seating could be raised up, (IN TERMS OF QUALITY), to a higher level of quality! ---- (There needs to be more padding in the seat cushion. This condition becomes very noticeable as the vehicle ages. I have designed a foam cushion for the two front seats, and covered these cushions with a gray towel material. This gives me a softer ride, and I am NOT sitting in a hole! ---- I gives me better visibility and and more comfort on long drives.)
    QUESTION:
    Do I like the vehicle?
    ANSWER:
    I have owned & driven this vehicle for 59,000 + miles, and I have no complaints in terms of mechanical quality. It has never left me at the side of the road. ---- I have an "outstanding dealer," and the service is VERY professional. (Here again, you as the customer, set the stage for how you want to be treated. Act in a professional manner, take control of the service situation, and you will be treated as a professional, not like "one of the herd of cattle seeking service!") ----- If you compare this vehicle, (in terms of comfort), against a Ford Fusion, or the Mercury Milan or the Lincoln, the Ford products, (in terms of seating), are more comfortable, and feel more luxurious!
    Best regards to all. ------------ Dwayne :shades: ;):)
    I'm right there with you on the criticism of the Camry seats: THEY SUCK!!!
    Has anyone investigated the possibility that a Lexus seat might bolt right in? Surely with the reputation that Lexus has to protect, their seats would be much more comfortable!?!?
    Anyone?
    Michael
    Hi Michael:
    Here is the important question: ----- Why does the leather seat have to be so hard? ----- If you every had the opportunity to sit in vehicles of the 50's, 60's & 70's those leather seats were "soft" and "well padded." ----- When I had the 2003 Honda Accord, I lived in the chiropractic office, ---- because the wings of the bucket front seats would hit my rib cage before my spine touched the back of the seat. ---- Many seats on foreign cars are not made for the American Driver, and this is especially true of vehicles made in Japan. ----- The Lexus seat is more comfortable than the seat in the Camry, but I would bet that they cannot be switched. -----
  • Kirstie_HKirstie_H Administrator Posts: 11,142
    Coincidentally, I came across your message RIGHT after I finished reading a message in a Lexus LS discussion from a member who is experiencing terrible discomfort from his seats - said it's like a metal pole going down the back. Maybe that's not where you want to look for a solution!
    MODERATOR /ADMINISTRATOR
    Need help navigating? [email protected] - or send a private message by clicking on my name.
    Share your vehicle reviews
    Hi Kirstie_h (host)
    Since everyone seems to be complaining about the "comfort" and "quality" of the seats on new vehicles, why are the manufacturers continuing to make seats that only a 21 year old finds comfortable? -------- Most expensive vehicles are purchased by people who have established themselves financially, but these people may have age related issues that make sitting a major issue for a long period of time. ------- I am not driving a Honda Accord today because the back of the front bucket seat does not support my spine properly, since the back of the seat is to narrow, and it catches my rib cage before my back hits the back of the seat.----- {I really like the Honda Accord!} ---------- (I purchased the 2007 Camry because it was the "lessor of the two evils." I could fit comfortably in the bucket seat, but I had to give up the handling of the Accord.) ---- My 2010 Chevrolet Malibu LTZ is much more comfortable than the 2010 Honda Accord.
    American buyers need bigger seats that are padded in appropriate areas. (This is especially important for the older driver!) ------- I would hope that the manufacturers would read these message boards, because some of these suggestion are important to potential buyers.
    That's a good question, Dwayne, but unfortunately one I can't answer! Honestly, the most comfortable seats I've had the pleasure of sitting in over the past 10 years have been in a VW Jetta - not a luxury car. Then again, others hate them for their stiffness.
    The good news is that more and more manufacturers ARE paying attention to what consumers are saying on message boards just like these. For example, if you visit any of our GM vehicle discussions, you might run into Mariah, who is a customer service representative fairly newly assigned to monitor discussions and respond to consumer concerns. Manufacturers may be a little behind on this, but they are no longer discounting the opinions made on various forums. Hopefully Toyota will be one of these!
  • lalonl89lalonl89 Member Posts: 1
    i have the same problem. mine is a 07 LE 4 cyl. and only when i go on reverse it makes a loud noise specially in the morning other than that, it runs nice. I will like to know whats causing this noise? is it the brake pads? can anyone help out their?
  • 07_camry_owner07_camry_owner Member Posts: 1
    Just went through exactly what Beantown was going through. Replaced the knock sensor myself and when I disconnected the knock sensor from the wiring harness I noticed the wires were frayed. Cut the wiring harness off to get a better look and found there were in fact rodents chewing on the wires. Also found rodent droppings in several places under the hood which seems to support the fact that rodents were chewing the wires. I too drive the car just about every day and was rather surprised to find the rodent droppings under the hood. Spliced the wires back together and replaced the knock sensor while I had the intake manifold removed and car is now running like it should.
    edited December 2010
    I turned up the speakers on my PC, can't hear the noise that you are referring to..
  • vishu2vishu2 Member Posts: 1
    I have 2007 camry, recently I see rust formation on my car. When I took to toyota showroom, they say rust of my car is not from inside to outside,so not covered. Not sure wht to do.. can you guys suggest me? may be showroom guys are not willing to do even when my car is eligible.
    There are two kinds of rust that can develop on cars; one is called surface rust, which begins on the outside surfaces. It is usually found on unpainted metal. This type of rust is superficial and does not weaken the metal. It can be found on all types of cars, and is considered a normal result of weathering. Surface rust can be cleaned and removed by sanding and priming or by applying rust preventive undercoating or specialized rust removing products.
    The second type of rust is called rusting out. It is found deep in joints, seams, and in other structural elements. This type of rust can weaken parts and eventually cause them to break. So that is the only kind of rust which is covered under vehicle warranties.
    It sounds like the people you spoke with at the dealership are telling you the truth.
  • chuck28chuck28 Member Posts: 259
    It's been awhile since I posted. I have a 2007 Camry SE V-6 which has had all the transmission issues and shifting problems beside numerous other issues.
    I'm witting today to let people know I had an engine warning light come on last weekend which also included mt VSC and traction light. I took it to Auto zone to have the code read which they do at no charge compared to Toyota which wanted to charge $110 to hook it up on it's computer.
    After confirming I had a bad ignition coil I bought a replacement for $85 from Toyota and replaced it myself. The front coils are easy to get at compared to the back. I was fortunate to have my bad on in the front. It took me 2 minutes to change it, One bolt and one plug. Toyota wanted $300 for the whole job.
    That being said my car has much better pick up and doesn't seem to hesitate anymore.
    IS it possible that this coil has been defective from day one and now has finally showed up on the computer as this coil worsen.
    I'm still test driving the car as I have only got to drive short distances to work and back but it feels like day and night. I'm also hoping my MPG's get better which has always been a problem with this car.
    Unfortunately The coil is only covered under the 3 year 36,000 warranty.
    Feel free to offer any of your thoughts or use the for your own experience's
    My Camry
  • typesixtypesix Member Posts: 321
    Owner's manual states that a click or motor sound may occur for a few seconds when the engine is started or just after the car starts to move. This means the antilock brake system is in the self-check mode. This could be the noise you're hearing.
