Have you received a recall notice for your car, but decided that you're not going to take it in to get it fixed? If so, a reporter would like to talk to you about it. Please reach out to [email protected] by Wednesday, September 26, 2018 telling us why you decided not to get the repair, and the Edmunds PR team may connect you with the journalist.
2007 Toyota Camry Problems and Repairs
1167168170172173177
  • cherann24cherann24 Posts: 7
    I have a 2007 Camry LE with a small oil leak - 1 or two drops a night. At first I was told this was probably normal after an oil change - however - it is consistent and has been going on for some time, so at the last oil change they supposedly found that the oil pan gasket was seeping and the estimate to replace the gasket would be $374. Does this sound reasonable and where is the best place to get something like this fixed?
  • zaken1zaken1 Posts: 556
    It often is not necessary to replace the oil pan gasket if it leaks. Oil pan gasket leakage frequently develops when the pan bolts loosen up from vibration. In those instances, just tightening the oil pan bolts is all it takes to greatly reduce or eliminate the leaks. This repair takes less than an hour (probably costs much less than $75); and can be done by any independent garage which does engine work. Look for a shop which employs ASE certified mechanics.
    $374 for replacing the oil pan gasket sounds awfully high to me. Virtually every shop in town uses a standardized labor time estimating book called a flat rate manual. This book lists the amount of time it takes for an experienced mechanic to do each repair job on popular vehicles. Phone a local repair shop and ask them the flat rate time estimate for replacing the oil pan gasket on a 2007 Camry. You'll need to tell them whether your car has a 4 cylinder or V-6 engine. Once you have the time estimate (better get one from several shops to make sure they give you accurate information) all you need to do to determine the fairness of a price quote is to find out the hourly labor rate of the shop you're dealing with; and multiply that figure times the flat rate time estimate. The result will be the labor cost at that shop for the job (plus the cost of a new oil pan gasket; which will probably be less than $20). Some shops may want to also change the oil as part of this operation; which would add the cost of oil and maybe an oil filter to the job.
    Sometimes an oil change place installs a non standard or poorly fitting gasket on the oil drain plug. Other oil change places do not adequately tighten the oil filter; or do not adequately tighten the oil drain plug. If the place which changes your oil is doing that; there will always be an oil leak. There are too many inexperienced or fearful employees out there. I would get more than one trustworthy opinion about the source of the leak. There are also too many know-it-alls out there who need to sound important; or who want to take your money.
  • notmybmwnotmybmw Posts: 101
    Hi there.
    Couldn't agree with you more on the downward decline of Camry quality. I had a 1997 4 cyl stickshift.........and LOVED it. Gave it to my daughter, still running strong, when we bought our 2007 in June '06. The new one is NOTHING like its 10 year old predecessor. Shakes, rattles, shifting (auto) irregularities, and now an annoying 'clatter' (for lack of a better word) coming from underneath the front end when driving at moderate speeds over uneven surfaces.
    Not inclined to buy another Camry after all this. (And we had a third one BEFORE the 97, so it's not like we're disloyal!) They've cheapened the marque as far as I'm concerned.
    BTW, if your mechanic isn't sure where to look for the noise, ask him if there are stabilizer links on the ends of the front sway bar. (not sure if there even IS a sway bar on the front of these puppies......but that's what was making the noise on my 325i; it was a $27 part and a $30 installation......cheap to get rid of that migraine-inducing rattle!)
    Good luck, buddy.
    Mike
    Agreed on all the points from zaken1. Lots of "loose things" could be the cause of your "leak".
    The only thing I don't see referenced is the "THEY" you refer to. Who dat?
    Additionally, how long have you owned the car? Did you buy it new? Regardless of who you bought it from.....who's been doing the maintenance? Has it had this leak from the day you bought it?..........or just since 'someone' worked on it.
    Call me skeptical/critical.....but I'd FIRST be pointing my finger at the party who's been doing things to the car since you bought it.....assuming it didn't leak when you first brought it home.
    Just my 2c.
    Michael
    It's a 4 cylinder and I am the only and original owner of the vehicle. All the oil changes and replacement of the water pump have been done at the dealership. I think the brakes were serviced once by Tires Plus and that's where the tires get rotated. So - If I blame someone - it would have to be the dealership.
    It appears this isn't a big problem so by delay getting it fixed isn't a problem. I check the oil level periodically and it's fine, so I'm not losing that much between oil changes. The vibration makes sense as this vehicle does seem to have more vibration to it than the Toyota I owned back in 1980.
    As for maintenance - all I have had done is have the oil changed, fluids checked and the water pump was replaced while still under warranty. It has 112,000 miles on it - should I be doing any other service. According to the manual - I don't need to - but the dealership is always recommending other things.
    (My ex always took care of the cars - so I am feeling a little lost)
  • I have a 1999 Toyota Camry with a v6. The car ran real rough and then stalled. The car will turn over but will not start. We replaced the fuel pump and the fuel pump will not work with the key in the ignition and turned on but will work if we run a hot wire. Also the injectors are getting electrical fire but not clicking when we try to start the car. We are thinking the fuel pressure regulator might be bad. Would this stop the injectors from firing. Does this sound like we are heading towards the right direction for this car? Any other suggerstions. Thanks
    edited June 2011
    A problem with the fuel pressure regulator would not affect whether the injectors are being triggered. Besides; the fuel pressure regulator on this model almost never fails. But there is another part which typically causes this problem: It is called the camshaft position sensor. This sensor tells the computer which stroke in the combustion cycle a given cylinder is on; and that information is used to determine the triggering of the injectors. Cam position sensors are known to fail; and they cause the symptoms you described when they go out. So I would have that part replaced.
    Rock Auto (www.rockauto.com) sells an OE quality Beck Arnley cam position sensor for this model under part #1800500 for $47.79 plus shipping. Here's a link to a photo of this part; http://www.rockauto.com/catalog/moreinfo.php?pk=2785371
  • Thank you. We will try this and see if this takes care of the problem.
  • tulips4utulips4u Posts: 2
    I am curious to know whether anyone thought that 24,500 was too soon to be having brake, struts and seat mechanism problems. Could these problems be my fault? :confuse:
  • kiawahkiawah Posts: 3,666
    edited July 2011
    Depends on how hard you drive the vehicle, what kind of roads you drive on and the speeds you drive, and how much you weigh/how often you're adjusting seat.
    My daughter who has taken our 2007 LE as her own, is a very reasonable driver, on good roads. Rear pads needed replaced at 52K miles (mainly highway driving), front's are still fine when I recently checked them at 60K. No leaky struts, and since she is the single driver now, never adjusts the seat.
    For daughter #2 on the other hand, I needed to replace all 4 brakepads at 45K on her vehicle, same roads. She also is a reasonable driver, but does definitely drive slightly harder.
    Personally, I've replaced some of my other vehicles front pads at 25 and 30K.
    There may have been life left on those pads of yours, did you look at them when they took them off and replaced them?
  • ledzepplinledzepplin Posts: 41
    I have an '05 camry with 53000 mi and have had none of those repairs made.
    Who told you to replace these items? If you were a cab driver in NYC then
    I could understand. But not for pleasure driving even if only in the city.
  • My 2007 Camry had only 17,500 miles when I was informed by Toyota service that THE FRONT BRAKE ROTORS WERE WARPED. ALSO FOUND THE FRONT AND REAR BRAKE PADS WERE SUBJECT TO AN UPDATED BRAKE PAD TO REPAIR A BRAKE VIBRATION. REPLACED THE FRONT AND REAR BRAKE PADS. RESURFACED ALL 4 ROTORS. PAD KIT, DISC BRAK $132.37, PAD KIT DISK BRA $57.40,
    TOTAL PARTS $189.77, TOTAL LABOR & PARTS $543.16
    I've owned 5 other Toyotas and NEVER had to repair brakes and rotors
    this soon. I'm very disappointed.
  • luckysevenluckyseven Posts: 134
    edited July 2011
    Where do you rotate tires? Very often rotors get warped when lug nuts over torqued with impact wrench. I prefer to do tire rotation myself and always release lug nuts to the specs if someone else does the rotation for me. MY BOTH TOYOTAS (CAMRY AND HIGHLANDER) DON'T HAVE WARPED ROTORS AND PADS/ROTORS ARE STILL ORIGINAL.
  • dwb2dwb2 Posts: 24
    I had the same problem with my 07 Camry and dealer made complete repairs under warranty. The car was actually out of warranty by time but they fixed it anyway.
  • Hi! mY 2007 Camry all of a sudden has the maintenance required light showing on my dash. I just had my oil changed last month. THe manual says that it is the oil that needs to be changed but can it be something else?
    No, the odometer is what triggers the maintenance light. It sounds like you had the oil changed early, before the light came on; and the car subsequently reached the mileage which triggered the light. Just go to the place that changed your oil; and ask them to shut the light off.
  • mcdawggmcdawgg Posts: 1,680
    When they changed the oil, they forgot to reset the light. You can do it yourself if you want. Instructions are in your owner's manual. It will take you a minute or so. Turn key off with the trip odometer showing trip A. Then, hold down the trip odometer, turn key to on, and watch the display - when it gets to zero, you are done - release odometer button, turn key off.
    I had no idea the Camry was this 'sophisticated'......not to mention the Walmart guys who change my oil!!! LOL
  • dmathews3dmathews3 Posts: 1,739
    GM cars have had this feature for many many years so nothing new as far as I know.
  • fmwegafmwega Posts: 1
    edited August 2011
    Why is Toyota ignoring water pump problems in 2007 camry? I was told by a Toyota dealer that the water pump for my 2007 camry need replacement and it very expensive. My camry has only 65,000 miles. It appeares that this a major problem with 2007 Camry. I used to like Toyota, but I'm loosing trust in them. To much problems. Please I need help.
    Welcome to the world of "Skeptical Toyota Owners".
    I 'joined' when I discovered (while researching my automatic transmission problems) that Toyota and its dealers have a "code of silence" to only inform customers who COMPLAIN about some related 'symptoms' that there may actually be a SAFELY concern with their automobile.
    In my case, there was even a published Technical Service Bulletin issued about my lagging acceleration problem (dangerous at intersections), but my dealer didn't even KNOW about it......AND he was reluctant to believe ME when I told him I'd found a copy of it on the Internet. NOT GOOD!!
  • nmarcel1nmarcel1 Posts: 21
    I agree.... I have 20K on my 2007 Camry LE... I started to hear the chatter which is the indication that the water pump was going.... I went onto to Utube and saw a video on how to change it. It was not an easy job but I changed the pump myself which cost me about $65 bucks for the water pump and 4-5hrs of labor. I was really angry that this Camry's water pump was shot after 20K of mileage. I am extremly disappointed in the quality of this car. Let me know if you find something out there were there was a defect with these pumps.
  • wwestwwest Posts: 10,706
    Unless you see water, coolant, puddling under the car from time to time your dealer is simply blowing SMOKE.
  • Mine went out just before the warranty period was up - so it was replaced free of charge. Unfortunately, since we purchased this vehicle and I have had to endure a divorce and cannot replace the vehicle, so I ended up with two unreliable things in my life.
    The red long-life coolant dries to a crystal solid, so unless it is a very large leak, you won't see a puddle on the ground, just pink crud around the waterpump.
  • The throttle lag IS DANGEROUS! My dealer claims nothing is wrong. Anyone out there have the Service Bulletin number? This is my third, and last, Camry. Next time I'm looking at the Hyundai or Honda. I also have a 2005 tacoma 4-dr PreRunner. It's a great truck!
  • My wife has on 07 Camry. The speedometer is fast by 4 mgh. So if the speedometer shows 60 mph we are really traveling 56mph. I talked to the service lady at Silsbee, Tx. Toyota and she says Toyota sets all speedometers up that way. Telling her I wanted it fixed she says they cannot. So after a short conversation of depreciation, and other sorts of problems with this con-cept (con). I told her I wanted to talk to someone who cares about this problem and I wanted it fixed. After being on hold for 10 or so min. she came back, not finding anyone that cared, and said someone would call me back with the docoments stating that this is Toyota policy. I wonder if they are really that dumb to put it in writing? As of right now we have about 55600 miles on the odometer and Toyota would owe me some 3706 miles.
  • I'm glad you posted this. I have a 2007 Camry XLE V6 and noticed a few months after I purchased it that the speedometer was reading around 3 mph higher than the actual speed. I thought it was just my particular Camry. I hadn't realized Toyota purposefully does this.
    Very common. I am not sure all car manufacturers do this, but I bet most, if not all, do. Reason - they would get sued by someone if they were even 1 mph too high. I have never heard of the miles being off, just the speedometer.
  • chuck28chuck28 Posts: 259
    I recently say some light pink and white crud under my car. It was only the size of a nickel or so. At first I thought could it be from the airconditioner drain. Then I saw a post on this site mentioning the water pump. I have only noticed this crud once. Is there a way to look at the water pump without taking the engine apart.
    Thanks ofr any help, chuck
