If you are really interested in other people helping out, you will need to describe exactly what you mean my "some sort of transmission problem"...
Kass
I have a 2006 MMH with ~26k on the clock. Right now I am averaging 28.4. Best it's ever been except right after an ECU update when I topped out in the 29's and dropped. In the winter I get in the 24's here in StL MO.
Problems I have had:
High Pressure Pump failure (stopped charging batpak and Check Engine Light lit)
Rear shocks replaced (squeaks - but it still squeaks. I thought it was the body bushings, but the dealer claims the tech put body mics on the car and that it was the shocks)
Both these warranty repairs
One issue no one has been able to fix since close to new (bought 5/2006) is a "squeal" from the rear when running on batteries - sounds almost like a brake pad warning, but pads are fine, rotors true. Very annoying
Nits -
- Seats don't give enough thigh support (I am 6'3") and need more cushion
- Give me lower license plate screw speed nuts (mine rattles when shutting hatch, even with some door sealing foam behind it)
- Better floor mats (for $110 these are way cheap - I was starting to wear a spot under my right heel in three days)
- Include the rear cargo cover
- Improve materials used for interior - after alll, this vehicle is seriouly more expensive than the regular version
But all in all it's not a "bad car/crossover" but still too expensive (my stickers was $33170, should have bought the Escape (IMHO). And of course Ford doesn't really want our opinions.
1. Go back to your dealer and get the computer recalibrated. Ford/Mercury keeps updating the settings. My current setting, made a week ago, is quite amazing: I'm staying in electrical mode MUCH longer.
2. Replace the air filter with one from K & N.
3. Use 40 psi in your tires, preferably nitrogen from Nitrofill.
4. Use BP Invigorate gasoline, which cleans away all the engine gunk.
Now I'm getting 30 mpg around town, instead of 26-27.
We are having some problem with the ABS now, there is lots of information on the web about problems with the ABS on the FEH. We are having a cracked tone ring replaced on the rear axle. I am having it replaced and having new rotors and ceramic pads put on the front for a total of $521. I have a good mechanic who is not a dealer. I have heard of people paying the dealer over $700 just for the tone ring replacement!! I will say that one problem owning a Hybrid is that every one jacks up the price of materials and labor. When I went to get an air filter I found that paper filters were $35, twice what they run for regular vehicles. I ended up buying a K&N filter for just a few dollars more and will never need a new one again. It was the same when I went to the dealer for a quote on new rotors and pads. Thank God I found a good independent mechanic that knows what he is doing with Hybrids.
We also have a Subaru Outback and I think for over all cost of ownership, performance, MPG (which is almost the same) and reliability, I think would go with another Outback. I've found that Ford's customer service and quality doesn't measure up unfortunately.
http://www.mycarstats.com/reports/mercury/mariner_hybrid/2008/complaints.aspx
Ford wants big bucks to fix, but you can do it yourself. As a matter of a fact, a 12 year old with any form of mechanical sense can replace the pump. It's not in the cars motor, it's outside underneath radiator. Just, disconnect the wire, couple of hose clamps to remove and a couple of bolts to remove.
Check your hoses under the hood and the coolant tank to see if things are pressurized.
You can buy the pump on line and do it yourself...saving about ~say~ $500.oo :surprise:
Let's hope your home owners or automobile insurance covered the damages if nothing else.
Blew Up? How did that happen? Gasoline leaky and ignited by garage spark, or Electric battery problem?? Other?
