Do you currently own a 2019 or newer RAM pickup? A reporter would like to speak with you. Please reach out to [email protected] by 1/27 for more info.
TL Windshield Issues
My 2006 TL has had 3 windshields so far and ALL have been optically distorted. The 2 loaner cars did too. One was so bad I
was carsick. The service mgr was shocked that no one had pointed it out to them yet. Am I the only one with perfect vision seeing the imperfections ? Has anyone had this problem, and should I continue replacing them or start with Lemon Law ?
I am ready to sell it and get a Lexus or Infinity.
Polarized lenses and NEVER had this problem !! Nor have the problem in other
cars - gotta be the TL's. One of the loaner cars I was given while they were replacing
one of my windshields was even worse than any I had on mine. Service people were
shocked no one else had pointed it out to them sooner. The Pacific Ocean horizon
is flat not rippled as it appears through TL windshields #1, #2 and now #3.
Guess I'll go for #4 .......
Should I have the glass done yet again? Spoke with the dealer and he says there's no difference b/w the ppg and the "honda" marked windshield, though I'm considering getting "honda" glass next time around (although isn't it made by ppg?) as a possibility.
Is this a normal distortion due to the curve of the windshield? If so, why was it not apparent with the stock windshield? Is it normal for aftermarket windshields?
Would I be causing or risking a different problem by having the windshield taken out and replaced a third time? Or are windshield replacements no big deal.
Does such a distortion indicate a structural or unsafe flaw in the glass or is it just a distortion?
Any help and enlightenment I could get on this subject will be much appreciated. Many thanks in advance.
Glass distortion is common, especially in aftermarket "OEM" windshields. It's often not noticed by most drivers.
Distortion in the glass is most likely not going to be a safety issue in terms of structural strength, but if the glass is distorted, I would have them do the job again, and see if they can use a Honda Windshield. If not, see if they can use a different brand then these first 2 times.
Obvisously, the PPG glass is not a very good option for you.
Pilkington is a OEM supplier for car companies like BMW and Volvo and are supposed to be very high in quality, but I know people who have had Lexus windshields replaced with Pilkington glass and complain about this same distortion issue.
Distorted glass can cause dizziness in some drivers and if it is affecting you, it should be replaced.
When you break a windshield and have it replaced, it should be every bit as good as when you bought the car new.
of rippling in the laminate - some worse/bigger than others - and depending on where
the ripples occur, really made driving feel like I was in a fun house, although
not having fun - the after market windshield was actually the best - good luck
