Buying a used ES 300
Im thinking about buying a used 1998 ES300. Just want to know is there any special routine maint. that has to be done by a dealer or can you get an oil chg at local Jiffy Lube. Also does the ES 300 run on reg or prem. grade gas and what fuel mileage to expect. Ive owned Camry's but i'd like to step up to the Lexus. Thanks for responses
and if you have some good pictures for it please put them with the answere. :lemon:
This is a mistake, as people were using the car on petroleum based oils for 7500 miles, instead of 3000 miles.
Use a FULLY SYNTHETIC OIL - Havoline, Valvoline or Mobil 1 High Mileage and a Mobil 1 EP or Purolator Pure One oil filter every 3 months or 3000 miles and the engine will last for 250,000 miles easy.
Also, don't forget to change the PCV valve, as a blocked PCV valve causes combustion gases to remain the crackcase causing sludge and gel.
Good choice.
I have a 1995 ES300 with 170K miles
If the engine is good, then since you have the car apart, now would be a good time to replace the timing belt and tensioner, seals, serpentine belt, water pump, spark plugs, pcv valve, clean the throttle body, drop the transmission pan and clean the filter. It is going to cost about $2000. By the way, the next time you buy a used car, take it to the mechanic and spend the 200 to 300 bucks to have it properly inspected BEFORE you buy it.
If you don't have a mechanic now, then now is the perfect time to fine one that specializes in Toyota/Lexus. Try this link for help finding a mechanic http://www.cartalk.com/content/mechx/
Any other things I should be concern about. Thanks for your help.
1. Looks like you can run regula gas in this car correct? Premium suggested but would like to use regular.
2. Timing belt - does the 95 model have one?
