--in order for the coil inside the solenoid to activate the electromagnet-pushing the plunger up,and making contact with the two terminals(batt/starter),IT NEEDS A GROUND!!..check under where the solenoid is mounted,and clean up the rust and corosion under there..then,make shure the mounting bolts arereasonably tight-not "gorilla torqued",like some ape who doesn't know his own strength(i HATE when that happens-especially on lug nuts!)..try that..or,try running a ground wire to it..desprate times call for desprate measures..
--ANYWAY,,i'd check the coil next..especially if the plugs were wet..if they smell of gas,pull all the plugs out,turn the engine over a few times-to clear the cylinders out,then burn the raw gas off of them(i used a torch,or a lighter),while there,check the gap,..then--it should fire..-cause ifin you'se got fuel,compression,and spark,you should get combustion!?!!..good luck
Messing with the cables to put a new battery in gave a good connection for 2 days, then it failed again because several of the wires are eatten up, inside the rubber insulation.
If the cables are ok, then keep checking 'downstream'. Solnoid or a bad starter.
I suspected this was the case as well
not many would waste the time,or get snarky..i've not done that.
so,if you would re-phrase your question,i will try again to answer it..k?
any ideas?
(--fouled up beond all recognition)..pull the distrributor,and see if the gear in the motor moves..but then,you'll have to know how to drop a distributor in a motor..good luck!
the heater core replacement probably doesn't have any thing to do with it,except timing..
if that don't do it,change the starter
I have a problem, my truck won’t run for more than a few seconds, there is no response from the throttle, it barley starts and then it doesn’t gain any rpm’s (then it does, but drops back to a very slow rpm then stops.) I changed the fuel pump and regulator but no difference. I’m hoping that someone can help me diagnose the problem
1998 Ranger, 3.0 engine V-6
Jakes Dad
Gregg Azevedo
Thank you your help! Really appreciate it.
Chris
--try beating the hell out of the converter..i knocked the clog loose on a minivan--big cloud of black dust came out of the tailpipe,and then it ran SWEET!!
--if that gets it going,change the o2 sensor,put good-premium gas in it,then take it for a L O N G cruise kicking it down every now and again-once it's hot(operating temp),then,quit "babying" it..thicker oil,and most any car will last longer !!
I have a 1994 ranger 4x4 super cab I have had since new. Last week I started having an intermittent starting problem and I am lost so any ideas would be helpful. The truck is starting 99% of the time perfect, runs without hesitation and has plenty of power. Four times in the last week after starting and driving for a short distance I shut the truck off and it will turn over but not start, I let it sit for a few and all of a sudden it fires right up. Most times within a half hour or less, this last time though I had to let it sit at a friends overnight before it would finally start.
I checked for spark and it's ok so I thought fuel was the issue. I tried swapping the ECC relay for the Fuel pump relay and that did nothing, I then changed fuel filters, problem still not solved. Sitting in the cab I have never heard the wine of the electric fuel pump when I turn on the key so I cannot say if it's coming on or not when it won't start. I have tried the fuel pressure release button at the throttle body and gotten nothing from it. I am leaning towards a fuel pump going out but it has none of the normal signs such as hesitation and lack of power.
Any ideas to keep me from a costly diagnosis and repair at the shop would be much appreciated.
I replaced a starter, and the alignment was not so bad that it continued to run, but it 'whined' loudly when engaged. The auto supply house (OReileys) gave me a set of shims and instructions when I went back there.
Getting the shims in and the bolts thru the holes and shim may be troublesome.
Follow the positive cable. Follow the cable on starter back toward the battery. If you find something with a big cable in, a big cable out, and one or more small wires in, that may be it.
