Honda Fit Audio & Entertainment System Questions
I've had my Fit for 2 weeks and am very happy with it. However, I am still perplexed by the Aux plug for the Ipod.
I was told by the salesperson that the Ipod would be charging as it was playing. This does not seem to be the case. Am I doing something wrong? Do I have to buy a car charger to use while playing the Ipod?
I also have to put the volume all the way up on my Ipod to be able to hear it through the speakers. Is this normal??
The stereo on the sport has controls that directly do all the ipod functions such as folder navigation while charging your ipod at the same time. The aux jack next to the power outlet is an input jack that will play from any source with a walkman (3.5mm) jack. (XM, ANY mp3 player etc.)But if you use the aux jack next to the power outlet you must control your tunes from whatever device you have plugged in.
By the way after looking at the sport fit at the auto show I can answer someone’s question that the steering wheel does NOT telescope, it only moves up and down.
http://www.collegehillshonda.com/instructions/8th_gen_civ_sedan/civic4drmusiclin- k.pdf
Hope the Fit ain't so labor intensive but I'll bet it's quite the same when all is said and done
My friends's loaded EX Civic did NOT come with it installed from the factory. :confuse:
Nor does the NA Honda home page show it on any vehicle standard - even EX Accord has it shown as a dealer installed /inflated price option. Ipod Music Link is also optional on all Acura models that have it available...
The only way you get the folder navigation is through the iPod music link kit accessory. For non-iPod devices (and iPods, without the special kit), your only option is to use a double-male mini jack cable, and plug one end into your device's headphone port, and the other into the aux-input, next to the cupholders. At that point, all you are able to control is the volume through the head unit.
The funny thing is, the attachment to control the iPod may actually cost more than the iPod itself...
I’d like to a) “hotwire” the stereo in my Fit so I don’t need to have the key in the ignition to listen to it (BTW: I’ve never drained the battery listening to the stereo in my car); and b) have a “hotwire” rocker-switch to power the windows when the ignition is off.
Can this be done?
If, yes, is it simple enough for a good stereo installer to do?
Avoid it and use the mini stereo jack if you have it.
I wrote a review about functionality and such.
check it out at http://drknife.com/blog/
One good thing, IT WORKS WITH OLD iPODs.
The HML worked with my "4 button iPod".
C
Not everyone hates MusicLink - it has a learning curve that some don't seem to want to invest the time in.
But anything that keeps your eyes off a tiny iPod screen and on the road is a big plus for safer driving...
PS Really nice Blog!
-You can't access your podcast directory. The only way to listen to podcasts is to move them to a playlist in advance (more work for you).
-The TTS (text to speech) software will only allow you to select the first playlist that starts with each letter. (Example: if you have two playlists, "Celtic" and "Country", it will select "Celtic" when you select "C" at the playlist voice prompt.) You can do a reverse search to select "Country" (more thinking on your part), but if you have 3 playlists that start with the same letter, you'll never be able to access the middle one (short of doing things like renaming it "Kountry" or something else that will force more thinking on your part.)
-There is no ability to search within a track (e.g. rewind or fast-forward within a track). If you missed something you want to hear again, you have to start the track over from the beginning and let it plod along till it gets to that part again. Joy.
-If you stop a bookmarkable track (podcast, audiobook), and go and listen to something else in another playlist or playmode, and then return to your podcast or audiobook, it will not remember where you left off. Because you can't search to get back to where you were (see above), you'll have to listen to the track over again in realtime. Double joy.
-Of course, you can't see any information on the artist/song that is playing, so if you have music that you're not familiar with, you'll have no idea who it is. Only way to find out is to not change playmodes and then unplug your ipod and scroll back through the playlist to try and figure it out. If you change playmodes, you'll never be able to retrace what it played.
-Got a bad track? No way to mark it for deletion. Likewise, you can't give star ratings for tracks you like.
-My Music Link Cable is very difficult to squeeze to remove it from the iPod. A little worried that the pins are not retracting fully, which could damage the iPod.
Honda Music Link and TTS.....it doesn't work for you, you work for it!
-Tom
The site is http://drknife.com/blog
the ipod link review is http://drknife.com/blog/index.php?itemid=34
If your here to consider music link, I say save your money, which may include frustration and time. That's what they made playlists and shuffle for. Enjoy your AUX jack.
I thought I'd be able to play my iPod through the Aux input (note that this is different from the Sports' iPod cable... that hooks into the iPod's USB port, sends track information to the Fit's display and allows the iPod to be controlled from the Fit's stereo).
I'm going to call the dealer to see how much it costs to install the jack. Anybody know of any third party products?
I dunno, the more I think about it the more I think I should spend the extra bucks and go with the sport. Not only for the mp3 thing, but the keyless entry and sportier looks kind of make it worth it. I really wanted a great deal though.
The non-bass at higher volumes do seem to show and making me wish for a subwoofer.
just got the ipod set up and the learning while not terribly steep just takes patience. Now the issue...
Plugged in today and old menu system appears..seems to be charging but no check mark...didnt like that anyway but now no music and all things being equal...that stinks..
Anyone?
This has it's own control and display:
http://www.crutchfield.com/S-H91Uj0Gmi5Q/cgi-bin/ProdView.asp?I=108DP1US
This may be a nonhonda version of the musiclink:
http://www.theistore.com/ipod2car.html
One concern I have, however, is that each iPod battery has a limited number of charges it can handle. Because the MusicLink always charges my iPod when it's connected, am I somehow significantly cutting into the life of my battery? :confuse: I hope not.
I have been able to select which playlist within a letter. Start by pressing the search and hold until the beep. It will then start announcing letters. Once the letter is announced, you need to press and release the search, and immediately press and hold it again until you hear the beep. It will then announce each playlist. When you hear the one you want, press and release. This works the same way for artists and CD titles (disks 2 & 3).
As I said, I have had mixed success with this, but I'm starting to get real good with it. What I mean by mixed success, is that sometimes after an update to the iPod, I will run into a situation where I select a playlist, but a different one is played. When this has happened, I had to wipe all tracks from the iPod, and resync everything. This worked for me. I have a feeling that there is an easier way to fix this or figure out what the cause is, but I haven't nailed it down yet.
Another problem I ran into this weekend was that the iPod was suddenly not being recognized by the radio. I would connect it, it would be charging, but no connection to the radio. I tried all sorts of things to fix it. I completely reset the iPod and updated the firmware, with no luck. The final resolution was remove the fuse for the radio to get it to reinitialize. I had to re-enter the unlock code for the radion, but it has worked fine ever since.
This thing is definately buggy, but with a little practice and some trial and error, I'm finally sort of happy with it.
The Fit Sport comes with the Aux port, but you have to specifically request (and pay for) the Music Link accessory. Installation is pretty complicated, as well.
If you did not buy the Music Link, and you're using the Aux port to listen to your iPod, then you will need a separate charger to keep your iPod juiced up. It's normal to have to crank up the volume on your iPod, when going this route.
I believe what would work best for you would be something like the Monster Cable iCharger Ultra-Low Profile Charger for iPod with Dock Connection (model #AICHG2 IP). It will both charge your iPod, and gives you access to the line-out function available through the dock connector. You would get a stronger and clearer signal going that route.
Jeez, this bugs me. I'm pretty sure I'm going to be buying a Fit Base Model--I have no need for the other features in the Sport at the price. In 2006, why doesn't every car stereo come with an aux jack? I've even been thinking of buying other cars (like the Scion xA) just because an aux jack is standard. I know this reveals an unhealthy dependence on the iPod...
A dealer in NJ quoted me $400 for the Musiclink and installation. Given the cost, I might just get an FM transmitter. Anybody have luck with these?
Griffin Transmitter
It has multiple pieces for use as an extension and you can angle the post in multiple directions. It comes with adapters so you can plug in the ipod video,photo and nano. works well in signal transmission. The Apple Store is charging 90 dollars. I got it for about 80 bucks from Best Buy but from what i've been reading it souns like a heckuva better deal than the music link.
(ipod: soundcheck and eq off)
http://store.apple.com/1-800-MY-APPLE/WebObjects/AppleStore?productLearnMore=MA0- - 45G/A
Ipod volume does not affect lineout volume (fixed at one level). I have the unit's volume at 6-8
Tested with 4G and 3G ipods
RE: Volume, I've noticed that the stereo remembers the volume for each input, so if the AUX is up to 15, when I switch back to the radio, it's back at 7 where I left it.
Sweet!
The next step is to figure out a way to add an aux line-in to the base radio. I know that the connection is there in the back of the head unit but the harnesses don't seem to exist yet for commercial sale. Oh the pain of having a new-to-US car! :P
When the iPod (nano, in this case) is attached via the glove-box cable, the iPod screen displays the check-mark and "okay to disconnect" message. This is normal.
However, the stero display now displays CDC and a flashing 6. (This seems to be an error message of some sort.)
I don't think it's a problem with the hardware, since when the iPod is disconnected it displays CDC EJECT (also normal).
Unfortunately, this happened after I updated to the most recent version of iTunes and updated my iPod software to the most recent version. I wonder if this is the problem.
I have, in trying to troubleshoot, completely wiped my iPod playlists and library and reinstalled my playlists, uninstalled and reinstalled the Honda Music Link software and re-run the TTS software. No luck.
I'm hoping someone out there has had this problem and knows the solution. Thanks.
I wonder how Honda can sell something that doesn't work, surely some people must be having a good experience with their Music Link.
does it work well?
would you recommend it?
thanks :confuse:
