Infiniti M35/M45 and Bluetooth
1567911
  • james27james27 Posts: 433
    There is a sensitivity adjustment in the service menus...I think it defaults to medium. To get ot it, if I remember correctly, you start with the stereo off, hold the setting button and turn the volumne control about 20-clicks or so until the menu pops up. All sorts of stuff in there. I know with my phone, all of the settings produced echo, at least on the test - I didn't try it after making a phone connection.
    There's another menu, but I think you need the dealers computer to adjust, but you can adjust the headlights (if you have the auto adjusting option) +/- 15%, which sets the default height which might be of interest.
  • ghstudioghstudio Posts: 970
    There is also a microphone test...but I can't figure out how that works...or if it's an adjustment.
    I believe the headlight adjustment has to do with when the lights come on, not the height of the headlights.
    The menu you can get to does determine the light level where the lights come on, but, one of the dealer menus allows adjustment of the height of the beam. From the service manual, it appears you need their custom computer to access many of those menus; you can't get into it easily yourself. I haven't looked at it, but you might get a little adjustment from the sensor on the rear suspension, but my guess is that it is keyed and only fits one way. If there is some slop, you might be able to cheat it a little there as well.
  • kivikivi Posts: 12
    I did not adjust the settings in the car. I had my wife turn down the volume setting on her phone. On our phones you can adjust the voice volume, and that was all we needed to do.
    We do have 2 phones (same type of phone), and each is setup for the car, but neither of them will connect despite trying many times. I guess a trip to the dealer is next step.
  • Verizon has been known to "fuss" with the bluetooth firmware that is in devices loaded with their software. Moreover, they have been known to admit that this is purposefull (why, one can only guess). I got so frustrated with my bluetooth connectivey on Treo 600, 650, and most recently 700, I finally switched carrier to AT&T with a Treo 750 and haven't looked back.
    My only problem is now the Infiniti will only take 40 phone book entries. This day and age, this is rediculous. A meager amount of memory for an address book in $45k automobile.
    If your bluetooth is echoing or garbled, Infiniti released a technical service bulletin (fix kit) last month which applies to all 2006 and 2007 M's...ITB07-036a It is not a trivial update...the microphone is actually moved which requires that the roof liner be cut to mount it..and the control module for the nav system or display system is replaced.
    I stopped by my dealer today so they could verify the bluetooth problems on my 06 M35 and they agreed to put the TSB on my car. They have already done one car and the service manager said that it really fixed the bluetooth problems in that car and the new microphone in the roof liner looked just as if the car came that way.
    Note: this is not a recall. Some owners find the current bluetooth works just fine. As with any TSB, it is only applied if you can demonstrate the problem to your dealer with your phone.
  • pcc5pcc5 Posts: 3
    I had the TSB put into my 2006 M45 and it has helped the problem some, however, the microphone is placed above your head which creates a problem with the transmission of your voice into the mic.
  • Has anyone used an iPhone in a bluetooth environment in an M35? I'm contemplating the purchase of a 2008 M35 and would like to know if this works well or not.
  • I just had the TSB repair done on my 06 M35x. The echo is still there. Does anyone know if this has been resolved on the 08 M35? My lease is up in 2 months and this may determine what car I get next.
    Ditto for me. The fix didn't fix anything and the echo is just terrible. I've tried every setup option low/med/high. Why do other cars work so well and the infiniti bluetooth is just awful.
  • cindy30cindy30 Posts: 9
    I have a 2007 M35 with a samsung A640. No problems except people say I sound like I am in a mountain, echos etc. I can hear them fine.
    Have been trying to get this resolved for a year and finally they cam out with a bulletin that says it can be fixed. Anyone out there have the same problem? What kind of cell phone do you have?
    Cindy
    If you go to where you bought the phone, they will make all the transfers for you.
    Cindy
    Go to the settings, go to phone and select volume for incoming calls and raise the volume.Should resolve it.
    Cindy
  • arnold14arnold14 Posts: 22
    I have a 2006 M35 and the bluetooth sounds like you're calling from a plane. The reception is very garbled and the car mic gives a very speaker phone like sound, very hard to understand. Is there any way to fix this other than do the service bulletin?
    I had a whole new navigation system put in with a new microphone above my head. Has improved the quality of sound, don't sound like I am in a well, but still sounds like I am on a speaker phone. But I am on a speaker phone, so I think it is fine.
    Cindy
  • dhellerdheller Posts: 28
    I'm having mine installed now at the dealer. Mine was locking up and the TSB #07038 describes the Bluetooth problems the M is having with echos. Hopefully, it will improve. I also heard the navigation that is being re-installed on 07 and later models have some functional improvements on the Nav - have you seen any? I hate it when my M is in the dealer, I have nightmares of mechanics backing into a wall or another car.....sheeeesh....
  • lengelberglengelberg Posts: 6
    Just re-upped to a 2008 m35x. My lease was up and loyalty incentives were too good to pass up. The bluetooth works great without echoes.
    At first, I thought the new upgrade helped my 06 M35, but I've found that it really is still not very good. Mostly, I dial thru the car and then hit the handset button and just talk like a normal person with the phone at my ear.
  • mkaplan1mkaplan1 Posts: 2
    Just picked up my M yesterday and my treo disconects from the bluetooth before I can dial a call. I just read somewhere that treo's are not compatable with the infiniti M. and that you can only receive calls. Is this true, what to do?
