Quick Links
Quick Links
Dodge Dakota Performance and Towing Mods
I think I posted a message in the wrong section..apologies for being a newb here. This forum works a bit differently than most I am used to.
situation: 2005 Dak SLT 4.7L Auto
Need to tow 4200 lbs / 22' Coyote trailer thru Cdn Rockies. Reese WD and Dual Cam Sway cntrl installed.
Added KnN CAI, MagFlow Cat Back, Syn Oil, will run Premium fuel.
Still lookin for a 180 degree ThermoStat..but have had no luck in obtaining one.
No Superchip avail yet. And the Jet module for towing/performance is not rated well at all.
What else could I / should I do to improve the towing experience/HP/Torgue short of buying a diesel Ram 2500.
What are the suggestions surrounding the "Tow/Haul" Button...always or only uphill or what.? My Question stems from advice read here to not use OverDrive while towing and the fact that there are only 3 manual settings on the auto Tranny.
thanx in advanz
stk
thanx in advanz
stk
As far as the tow/haul mode goes, I was always under the impression that it should always be used while towing. On my 02 QC 4.7/auto, I can only turn the OD off, which puts the tranny into 3rd gear. I tow a 25 ft, 4100 lb (empty) TT. With the 3.92 gears it does well. I don't know if I would want to tackle a 10 mile long 6% grade at 10000 ft with it, though. You should also have a tranny cooler and run 75W-140 synthetic lube in the rear end, as well.
Will definitely go with the syn lube in rear end. the cams .. well that is a pretty expensive upgrade that at this time is unaffordable. Tranny cooler is huge and std equip now with the 4.7.
Guess I gots to go with what I got...and see how she performs. Been told many times though that even with mid grade..this motor will likely ping..so I'll probably go with the premium anyway. company pays the gas.!
Stk
Rear end has 75W-90 Synthetic - just changed a week ago....with the Mopar limited slip additve as well.
thanx,
stk
With that kind of weight I would select "OD off," or the Tow-Haul mode for all your driving.
Dusty
The trip was through the Cad rockies and I did use tow/haul. There was only really one spot on an 8% grade that i went into first, kept the revs at about 4000 and up we went at about 50kmh.(30mph).
An extra 20-30 ft/lb of torque would be nice for sure when towing. Still waiting for the chip to come out.
Actually, being able to just turn off the OD would be a handy thing...As even with tow/haul, one can or so it appears, go into OD, albeit likely only 4th gear..??
Rgds,
stk
I purchased a 2000 2-door Dodge Dakota in 2003. I recently purchased a camping trailer which weights 3,200 lbs. The seller of the trailer said my truck will tow that weight with no problem since I have a 4.7 engine with a class III hitch, with 4 wheel drive. But as I look in my book there are different specs depending on whether you have a quad, club, or conv. cab. Believe it or not, I have no idea. I've looked in every piece of paper I've got on this truck, and nowhere does it tell me what I have. How do I tell? I have a back seat. Does that determine the model?
Love this site. Will really help me in the future, I'm sure. Thanks for any help on this question.
Is 3200 lbs the dry weight without Weight distributing/sway bars, propane, and MT inside.? With a 4.7..should be able to do it. consider loaded it would probably be around 38-4000 lbs.
Check on the drivers side door panel (near the lock), and there you should see a sticker showing your vehicles GVWR and towing capacity.
rgds,
Stk
Extended (Club) Cab:
Quad Cab:
Both the regular and club cabs for 2000 have only two doors. If there is enough room behind the front seats to have two mini/jump seats back there, then you have the club cab. Very little space and no seats = regular cab. The existence of a rear side window is also a givaway of it being a club cab over a regular cab.
A few of things to keep in mind: 1) Make sure you have a transmission cooler, if you have the automatic transmission; 2) Make sure you run 75W-140 synthetic gear lube in the rear differential; 3) make sure you have electric brakes on the trailer.
Your towing capacities are listed in the owner's manual. They will depend on body style, 4x2 or 4x4, engine, and gear ratio.
By the way, do I need to put the 75W-140 synthetic gear in the rear differential if I am running with a manual transmission, or is that just for automatics?
Thanks again.
If you have a limited slip differential, you will also need to add the limited slip additive, if the gear lube doesn't already have it.
Thanks again for your help.
Phil
It might be worth it to go with the heavier lube in the rear diff even though I just changed it a while ago as well..and like Phil, they put in 75W-90 synthetic with LS additive. I did pull 4300 or so lbs thru the rockies without a problem..but i would hate to lose a rear diff up in the mountains...Especially seeing as we are going again in a week for vacation.
rgds,
Theo
Then take the GVWR, subtract curb weight, weight of all passengers and cargo, weight of accessories and options, and that is a rough approximation of how much room you have for tongue weight.
ow own a 2006 GMC 2500HD Duramax CCSB SLE.
Now that is a towing machine, and I can tell ya it blows the Dak outa the water.
As for the question...I would probably not tow anymore than 3000 lbs with a 4.7 Dak. Yea I know they say with the 4.7 that you can go as high as 7000. sure and I can walk on water. 7000 lbs is a possilibity but only if you don't mind putting your motor and tranny to the absolute limits. Be smart and cut what the "stealer" says in half..then you'll be fine.
The 4500 lbs trailer I pulled last year with my Dak gave it all it could handle and it was slow slogging up hills...BIG TIME like 30 mph max. that was with 4 people in the truck at the time: 2 Adults and 2 teens.
For a V6 you should be probably OK..again tranny cooler and whatever you can do to add some torque will help.
I pulled a tent trailer at 2400 lbs with a 3.4 V6 Montana and it went fine....better than my 4.7 DAk on the hills with 4500 behind it.
rgds,
Stk
Another concern is brakes. Does the boat trailer have any? An extra 2000 lbs is probably more than the Dakota's brakes can handle safely.
I'm sorry for the late response.
I would hope that a 2500 Duramax Diesel would make the 4.7 Dakota seem over worked. You're not comparing apples to apples.
I've never towed 4500 lbs. with my 2003 4.7, but it handles 3100 lbs. with relative ease, and that's with the 3.55 axle ratio and oversize tires. Maybe its me, but when I'm towing I'm not in any race nor impatient with my progress.
Dusty
A huge engine in a small truck DOES NOT mean it is now capable of safely towing loads which weigh more than the truck itself.
Spend some time towing a bulldozer on a tripple-axle trailer and you will appreceate using a HEAVY tow-vhicle to perform the task.
Perhaps even more important with towing is the BRAKES.... and we all know that the brakes on the Dakota are pretty whimpey.
Does your trailer have its own brakes?
The trailer I towed did have electric brakes but were not hooked up. I found the brakes on my Dak to be adequate at normal speeds and going down hills for the roughly 3100 lbs. I currently have factory pads and the rotors were replaced about 28,000 ago. The rears are still original.
Bests,
Dusty
not for me thank ya very much.
As for brakes, yea, Dak brakes suck period. the rears might as well not even be there. If you are going to pull, make sure you use your tranny & downshift, pulse your brakes, and ensure your trailer brakes are in excellent order and a guy will do fine. I had no torouble in BC on two long trips over some major hill and dale..!!
cheers,
Stk
My 4.7L Dak is rated at 18 MPG highway and I get over 20MPG. My Volkswagen Jetta is rated at 49MPG and I get up to 56MPG on the highway.
My point is that the MPG ratings are highly depandant on DRIVING HABITS. It is easy to get better than the window-stickers if one drives with econemy in mind.
BTW: In reference to my VW Jetta - I do not beleive there is any other vehicle on the US market that can get over 700 miles per tank of fuel on the highway. Those silly hybrids are a gimmick. Test after test has shown that the VW TDI can go a LOT farther on a tank of fuel than any hybred.
I predict as the cost of fuel goes up, Americans will start to do what Europe did many years ago... and start driving Diesel cars. Modern diesel engines run cleaner than gasoline engines AND still get the 30% better economy that diesels always have deliverd.
Dusty
*over 17 MPG on 133 tanks of gas out of 293
*over 18 MPG on 78 tanks out of 293.
*over 19 MPG on 17 tanks out of 293
*over 20 MPG on 7 tanks out of 293
*over 21 MPG on 4 tanks out of 293
*over 22 MPG on 1 tank out of 293
*over 23 MPG on 1 tank out of 293
*over 24 MPG on 1 tank out of 293
There is (was) thought of a Dakota diesel for the 2008, and the 4.7 gets full hemispherical heads and a sixty HP increase next year.
Dusty
That's an interesting distribution on your gas mileage. Very one sided. Come to think about it, mine's probably similar, just about 4-5 MPG less. But, my QC is a 4x4 with 3.92 gears.
The one thing I've noticed with the newer Dakotas is the mileage ratings are much higher than mine. My 02, 4.7, auto, 4x4 was rated at 13/18. An 07, 4.7, auto, 4x4 I recently saw was rated at 15/20. I know the newer Daks have a 5 sp automatic, versus my 4 sp. But when that was introduced, the highway mileage only went up by 1 MPG. I wonder what else they changed to get the better mileage?
But what about the lockup system? If I run at ~70mph, I'm spinning about 2500rpm (2002 Quad Cab, 4.7L, 3.92 rear end). Give it a little gas, it spins up to about 3100rpm, I assume this is the torque converter unlocking?? Give it more gas, it shifts into 3rd (3500rpm to maintain about 70mph).
So is the danger of towing in overdrive that it unlocks and locks too much? If it stays locked is it bad to tow in overdrive? Thanks for any input.
-Eric
Now that I've moved up to a 4500 lb travel trailer, towing in OD is out of the question. The reason is the load is great enough, the transmission won't shift into OD, except when going down hill. When the OD is on, the torque converter will not lock up in 3rd gear, hence a lot of heat is generated due to the torque converter slippage. When the OD is off, the torque converter will lock up in both 2nd and 3rd gears.
It just depends on how much you are towing.
The manual says "overdrive off in hilly conditions." But the definition of hilly depends on whether you live in Kansas or Colorado. So (in marginal situations) is there a transmission behavior to look for to indicate when to turn overdrive off?
-Eric
Besides, ordering direct from the factory is CHEAPER than purchasing off the dealers lot and I got the options I wanted. This is because the dealer has a GUARANTEED sell when you order from the factory. The dealer's purchaser purposefully orders cars for the lot which have options with the highest markup. This be because they still have to SELL the vehicle. (And brush the snow off of it all winter!)
The first one or two years of the 4.7 in a Dakota they used a 47 or 48mm throttlebody. In 2002 or 2003 that was increased to a 50mm.
The camshafts are different for each year up to 2003. The 2003/2004 camshaft duration was changed to 243.5 degrees intake, 253.7 exhaust. I think that fuel delivery and timing algorithm changes permitted a decrease to valve overlap (17 degrees) for an increase in low end torque and improved idle. Likewise since '04 they've changed camshaft profile and fuel delivery some more.
The mere fact that the 545RFE transmission has five normal forward gear ratios and considerably less parasitic losses than the previous "RE" series transmissions could explain part of that 1 MPG difference. Top gear ratio for the 46RE is .69, and .67 for the 545RFE. Pretty close but a slight advantage for Dodge's newer automatic. The intermediate second gear on the 545RFE might actually contribute more to better gas mileage.
Starting in 2007, Chrysler is phasing in Variable Line Pressure (VLP) to its automatic transmissions. This will significantly reduce parasitic losses. In think the RFE will get VLP in 2008.
On my son's last leave I rented him an '05 Dakota Quad Cab, 4x4. It had the same axle ratio as yours. He was able to average 16.6 for the two weeks he had it in very mixed driving.
Best regards,
Dusty
Dusty
Is the result worth it and what are the most reliable products?
For me, A Borla exhaust was the only way to go. Here in Vermont, most exhaust systems last about 3 winters. Since I expect to keep my Dak over 12 years, I installed a Borla the first year I owned it. It still shines like the spoons in the kitchen drawer!
B
