I'm looking at an RV that weighs 4,000 lbs. empty and understand my 97 SE to be able to pull 5,500 lbs, and was wondering how she's going to do on hilly terrain or if an RV close to her tow limit like that is going to stress the trans. I'd appreciate any advice from anybody.
I also wanted to report my first Freelander sighting, and the steering wheel was on the right side, not the left. It had MI plates on it even. I didn't think they were on the road yet?!?!
Thanks for any help offered.
Kim
Thanks!!!
Jeff
P.S> What is this "x-plan"? I was quoted $43,013.50 + taxes/tags for the car w/ cold climate, ACE, rear A/C, and lightstone. Also, front brush bar and Hella 5000's. Is this a good price or no?
X-plan gets you 4% MSRP over invoice, plus 15% off on any accessories you buy. Great way to save.
I'm an avid cyclist - basically, I live my life around cycling. So, I need a rack system for my Disco II that is convenient to use and will look nice as well. As I am only 5'9, I am considering a Thule Swing Away hitch rack, but I think these types of racks are ughy. Anyone have any thoughts on going with a hitch rack verses roof top mounts?
Regards, -Bob
I really want is a Disco II TD5. Does anyone know if Land Rover ever plans on selling these models
here in the US. Also does anyone know anybody who has imported a TD5 from UK?
I ask because this will affect whether I go with the SE or SE7. I will occasionally have four kids (ages 7 & 5) in the car. Don't relish the idea of putting them in the jump seats since they still need booster seats.
If you really want to do some major offroading go see the guys at Northern 4X4, they know ALL the trails.
Una inuq aaniqtuq, -Bob
Please keep us posted on the impending arrival, ffitz.
Steve
The guys at Northern 4X4 convoy up around Hatcher Pass and further, they've found some GNARLY rocky spots. You should see the "trophies" on the front counter... broken axles, hubs, U-joints... parts twisted in half... it hurts just to look at the wreckage.
FWIW, they're getting interested in Pinzgauer and Series Rovers too... there's a great photo in there and they just ordered some elliptical springs for a guy's Series here in town. But for the most part they're hardcore Jeepers.
Typical weather up there; winter is over and now it's time for the other season (construction ). If the pavement get any worse around town, Paisan's roads may have some serious competition.
Looked like the LR dealer had more used stock on the lot than usual too.
Steve
Not really... I didn't get THAT far off the ground. But I have given a few people cause for concern on that hill.
Yep, the roads are a mite rough. When you see people hitting low range to cross an intersection then you've got to think about upping the maintenance budget.
Too bad you're not here today, it's gorgeous!
(hit refresh for updates)
Jeff in the trailer under the bridge in Vail, CO.
My ? is would locking the diff help provide more resistance when downshifting for long hills? 2nd doesn't always slow me quite enough to keep from riding the brakes for 5 miles
Also is it best to brake before exceeding 3500RPM r can you safely go higher?
I would definitely keep it below 4k rpm, I know the engine will begin to cut out from intrusion by the ECU when the RPMs get too high... but that's when under power. How will it prevent you from overreving on downhills? It can't. This is an engine you do NOT want to burn up!
Locking the diff will have zero effect in slowing you down. It's a method to lock the front and back axles together offroad to prevent getting stuck by being cross-axled. Don't lock it onroad, even driving straight ahead; you can break expensive parts. Straight ahead: your front tires are inflated less than the rears, right? That gives lower ride height, smaller rolling diameter, faster rate of turn than the rears.
One last warning: don't assume she'll ALWAYS downshift to slow you when you've got the RPMs way up. In the test procedures for after a trans rebuild one test is to select "2" at some ridiculous high speed, and the satisfactory result is to have her NOT engage 2nd (to protect from overrev). This is a smart transmission, she has some surprises.
Best luck, -Bob
We are looking into buying an RV and was wondering if anyone has experience towing and has a recommended weight limit. I know the limit stated in the manual, I'm looking for the voice of experience here. What is too much? Is 4,000 lbs. going to be a problem in hilly terrain?
I appreciate the help.
Kim
SSSOOOOO...
Can I damage the tranny by riding down a long hill in a low gear if I don't over rev? Is this related to "spooling up" or "winding up" the transmition?
Just riding the brakes isn't an option unless I want to replace rotors every week. They do heat up and warp from my wife's experience in 3 other vehicles.
Also, any recomendations on repair manuals? (Chilton's the best?) I used to do a lot of work VW busses with a book titled " How to take your Volkswagen apart and put it together again for the complete Idiot".
As for manuals, I looked a long time and found the only manuals available for my '96 are the factory service manuals. They're spendy but well written. They can easily pay for themselves on your first service.
Good on you, that you'll be doing your own work. Get to know your truck and you'll have few nasty surprises. You might start watching garage sales for BIG combination wrenches. Make sure they're not worn/spread, and watch for a good 1/2" drive socket wrench... you'll use that on your transfer case and diffs.
Regards, -Bob
Also, they are doing a front alignment check because my (front) tires were worn completely on the inside edges (too severely to blame on normal use, IMHO). They gave me a deal mounting/balancing new rubber, which I had sent over from the local Discount Tire store. BOW, I had trouble getting good tire advice for the 255/55/R18 and ACE. By the book, AR says get Good year Wranglers, which I can't get anywhere in town (at least not the REIN, -rated model). I went with the Scorpion C/C from Pirelli.
Finally, they are replacing the ACE control unit. I once saw a yellow ACE warning, and the fault codes apparently justified replacing the unit. The longevity of the ACE system (mainly the pump and the lines) is the only thing on the truck that continues to worry me.
We've seen a lot of warranty work (new cranny, new ACE unit, new drivers seat, broken ECU pin, various minor recalls), but we love the truck and the service at the dealership.
I remember discussions on this board from 2 years ago when we got the D-II. It was either Wasko or Nanuq who said (I'm paraphrasing) that LR trucks almost always have a problem or two. Just find a dealer who takes care of you (and it looks like most do) and use the hell out of the warranty. Once the kinks are out, the truck will run for life. Oh, and I'm sure Nanuq would want me to remind everyone to change their fluids often .
Having read this board for the last couple months I've seen lots of good info. Thanks. I do have a couple questions.
I put 20k+ miles a year my car more highway than city. Is there any additional concerns I should have with the DII over other SUVS. Also I am, for obvious reasons, interested in the extended warranty. I read that the warranty carrier was changing. Is this all worked out yet and what are the new terms.
Is there any way for me to determine the build date from the VIN#. (I saw that if I post it someone will look it up.) I understand that Monday builds are not the best as are Fridays. Overall how big a difference does it make and is it worth pursuing a tues-thurs car with the dealer.
Being a British car, who supplies the electrical system and is it at all reliable. My wife drove a Triumph years ago and the Lucas systems drove her nuts.
I like the DII's styling and that it is not just another SUV even though my '96 explorer with 115k miles has been good to me. I won't mind a few quirks and fix its in the beginning but don't want to live at the service shop over the long haul.
Finally, any comments about LR Newport Beach or Mission Viejo in CA. They are the closest to me but I will go further for a easier or better deal if someone has a good recommendation.
Question,, If I purchase a 2002 Discovery which was actually manufactured in 2001, is it a 01 or an 02? Hmmm. (Just having fun here!)
HEY LAND ROVER, Why can't we get yellow Discovery's like the one's we see in Landrover Enthusiast magazine!!!!!!! Let me see, Yellow is available in England, they all come from England, whats up with that?????
Regards to all.
Just wanted to let everyone know that the Rovers are doing great. With the Defender in the stable, I'm able to go a day or two with each every week. The Defender is flat out fun, but every time I jump in the Disco and look down at that little green oval, I get that feeling just like the first time I drove it!
Dunno what it is about these rigs, but you just gotta love it!
Now, gotta get the Defender in for a couple of niggly things - moonroof leaks like hell (not good in Seattle - although we're in the dry season now) and a few of the radio buttons don't work. Once I get that back, I'll take the Disco in If you'll remember a post I made about 6-8 months ago, I was having trouble with the radio fading in and out in the DI. Moved from MI to WA in March and the radio started working fine. I assumed it was something to do with the cold weather in MI, but that doesn't seem to be the case. I think the receiver is failing or there's a short/loose connection where the speakers join the stereo - it happens with both the radio and the CD player.
Still - I enjoy the sound of the engine and after a grueling day at work, the silence is better anyways
Thanks - wasko
The last 8 digits of the VIN are YA246420. Can anyone tell me what day this vehicle was manufactured?
Just for fun, my last 8 of the VIN are TA180732. Tincup, can you tell me the build date?
Thanks! This is great!
Was it Hurron3 yesterday who admonished people to let the past sleep and take the trucks on their own current merits? He's right. Even with the aggravation I had, it was sorted under warranty and now all is well. I can only expect the new trucks to be even better and more rewarding than that!
Thanks Tincup. That explains a lot!
Thanks for the info. I appreciate it.
