I spoke to a BMW mechanics and he told me that the rotors were intentionally thin to save weight on the car...hence the need to change the rotors with the pads at 50K miles. The break wear sensor replacement is a good idea for anything under 50K. Thanks for the quick reply.
I am considering a 2005 X5 4.4i. I have read on this forom some of the problems such as brake lining, window regulator, battery, and interior detailing.
Is there anything else concerning the quality and reliability of the vehicle?
Yes they are still using the same battery company, that they have been in the past years (this is the last year for them), and that issue will soon be gone.
The brake and rotors are something you might want to ask about at your dealer, how long will they last? and how long should they last?..Bmw uses a brake pad that loves to make dust.
Im a little bias, sense I do work there, but if I had a choice of X5s to buy this would be the year to get one, o and mine would be the red motorsport one.
Why? You figure the new X5 will have a litany of problems? Or you don't like the way it looks?
But I like the motorsport package.....but I also like the early 80s RX-7 so go with what you think
Can I ask you a question about the BMW alarm? (Actually I should have thought to ask you first rather than posting all over Townhall). I actually have a Mini but I believe the alarm is basically a BMW unit. My question is, if you park on an incline, or where the car is slanted to one side (ie. on a low shoulder), do you need to disable the tilt sensor to prevent false alarms?
Thanks in advance.
Thank you so much for helping me with some problems.
I brought my X 5 to the dealership and they ran their diagnostic test. I did receive excellent service and was treated very well by everyone I met. They gave me a white Z4 over the weekend and I really had fun driving that car. The Z4 is the best looking sports convertible out there at this time.
They said the mass sensor is bad and making the service engine soon light go on. They said my O2 sensors were good. The OBD 2 test at Advance Auto said O2 sensor banks 1 and 2 were running lean.
They wanted $475 just for the mass sensor. Does it sound like it is the problem to you? He said if you replace the mass sensor you will have to drive the car about 100 miles before the SES light would turn off.
They said I need a new coolant reservoir and a new bracket which will fix the low coolant level code. Are you familiar with the new bracket? I read a service bulletin about the low coolant level code and it said the problem is that the sensor is touching the metal right below it causing the code to come on. They recommended a new reservoir and new bracket that will hold the sensor away from metal below it. I really wonder if that will fix the problem. Please let me know what you think.
I am still looking for a telescoping steering wheel motor. Please let me know where I can get a used one.
Do you have any advice on getting a 2001 X5 aligned? My front tires are starting to feather.
Thank you for your help.
Jim T.
As for your tires you have to look at the tread, how is it wearing? is it on the outsides, insides, random highs and low spots in it, or is it worn in the middle? That will tell you what you what alignment you will have to do from there. But a good tire rotation is a must, I do mine every oil change.
As for the coolant sensor, I haven't seen the service bulletin, to give a response about it, but if there is one then its out there its for a reason. But if you don't want to spend the money right now you could just place a small jumper wire across the two pin holes in that connector and the light will stay off, insert the wire and cover it with electrical tape. as a temp fix
Do you have any info on the BMW tilt sensor I asked earlier in Post #312?
I was browsing through the forum to find any discussions related to the squeaky noise during acceleration. I found yours. I also noticed cameliax5's response but it seems there was no real solution. I have taken my x5 to the dealer once for a routine inspection and they said it was an air intake noise. I don't think they realized it was the breaks. Anyway, since then it has become worse and really annoying. Have you been able to resolve the problem?
If CD remains operative, may be a problem of sleep mode of the CU involved in CD Changer, anyway, best thing to do, take it to a dealer, they should be able to see histogram of sleep mode on the car.
Cheers
BWM: I find it absurd that I am dealing with this issue on a $65K SAV twice in less than a year. :mad:
TIA.
Brenn
does the 06 X5's have the aux input for IPod's or do you have to get it dealer installed?
Thanks for the help
djocks
Before i go back to the seller screaming like a banshee, does anyone have any ideas on what it could be?
Many Thaks
How reliable is it from a maintenance perspective? Does this seem like a fair price? Any other advice?
I am currently considering a 2006 4.8 X5. I love the car, but many experts (from various websites) are not much enthusiastic about it.
Any advice?
Best of luck in your search.
By the way.. I have an old buddy named Dave Jockel.. we called him DJocks! Not sure if it's you.. small world if it is!
Mike
How are ya buddy. It is a small world. Not sure which one I have here but I have done a lot of looking. I am up in Wallingford now with Amy and a 2-year old daughter.
It does sound like you have to change the tires on the 4.4i if you get the sport package. I have an '03 330i and I have put snows on it every season. It is not that big of a deal but the snows for an X5 will not be cheap.
I will say this though, for X5's now is the time... Especially for a lease. The money factors are awesome right now and if you can afford it go for it.
For example. the comparable lease for a loaded 325i and an X5 4.4i well equiped is about the same. There is a 20K difference in MSRP. There is no comparison to leasing from BMW. Alll service included, and first class all the way. When I bring in my 3, sometimes I ask for a loaner and they just hand me the keys to something in the parking lot and I go get some stuff done.
I have researched dealerships a lot also. I got mine at BMW of Watertown. If you call ask for Scott D. and drop my name. He is a good guy and can help you out. I have also heard good things about BMW of Ridgefield.
If you need more info email me at djocks123@yahoo.com
I am really leaning towards another 3, it is just a hard time right now because they are not giving much help yet.
Good luck, and I hope you still get a chance to hit them....
djocks
Can all the owners here please help me by letting me know if they have experienced some annoying rattles that are hard to fix, the dealer expertise in these matters and also the overall experience with their X5's? Also, I guess the X5 needs premium unleaded only, so have any owners run their X5's on regular?
Thanks in advance for all your help!
I'm shopping for insurance for my 2004 X5 3.0, and am wondering if it has Std Passive Immobilizer, Passive Alarm. From the manual, I can't find anywhere that mentioned it; however, the government web site (http://www.nhtsa.dot.gov/ncap/cars/2667.html) says it is X5's standard feature.
Anyone has any insight on this?
I was looking at the Edmunds post and see where you have been very helpful to other users. I have a question for you.
I bought my X5 3 weeks ago and the 4 year warranty had just expired. My service engine light came on about 1 week after I picked the car up. I took it to the BMW dealer and they said they found fault with gas pedal and fuel trim bank 1 and 2. They replaced gas pedal $378 and cleared fault memory. Light came back on 2 days later and now they are saying they need to replace wiring harness/engine to the tune of $949. Call me crazy but this seems like a rip off to me. First of all, why don't they know for sure what the problem is? So if they replace the harness and the light comes back on then they're going to say it's something else?
Anyway I took it to my regular mechanic who serviced my 325I. He said fuel bank 1 and 2 running lean but didn't see anything about wiring harness. What do you think is causing this? Is this a common problem and is there any long term consequences to driving the vehicle with the light on? Any advice you can give is appreciated. Plus, several times I am on E before I get gas and a couple of times I forgot to turn off the car. Would this cause the SES light to come on? This is so frustrating? Would this be something that an extended warranty cover? Also, what is the deal with the O2 Sensors?
Also, can you recommend a good extended warranty company? I am looking at Warranty Direct and Auto Club? Are there any others who aren't scams?
Sorry for the long email. Thanks for your help?
Has anyone had this problem? How was it resolved?
Well lets try a few things about the SES light, first off don't ever leave the engine running while you fill up the tank, if you do, you will get and engine light and it will go away after a few days. Reason behind this is a system called DMTL Ask a service rep if you want the whole story behind the fuel delivery system.
Lets see how that goes, don't let them change the harness on your car, they should be able to see the readings of bank 1 and 2 in the their DIS tester. and if the DME is reading all the right input and sending the right ones out to the throttle body.
As for the gas pedal I would try to get a refund on that job, they should of been able to look in DIS and seen if it was bad.
But for now don't run your car so low and dont leave the switch on while you are filling it,let me know if you have any more problems and we shale go from there
Thanks for responding. No, I haven't had them change the wire harness, but the funny thing is I had my mechanic reset the code, it came back on after a couple of days. Then last week I was at my wits end because I needed to get the car to inspection so I could get my sticker, it was 1 week overdue inspection. Well, last thursday night, the light went off, just like that. It went off the week before but it came back on shortly afterwards. Well, this time it didn't. So I got up took the car to motor vehicle inspection and it passed with flying colors. Thank God. Sunday I called my mechanic to tell him the good news. I called him from the gas station so that if the light came on after I got gas then it may be gas related. Well, 15 minutes after I get gas, the light came back on, and it's still on.
I am at my wits end, I don't know what to do. I think I am going to get a refund from BMW. The problem seems to occur when I go to the pump, do you think it could be a problem with the gas cap?
Also, can you recommend a good extended warranty company? Thanks.
As for a warranty, I cant really help you on finding that, sorry. Let me know how things turn out
If you don't have a sunroof, check the rear left and right air vents located under the rear panels between the tires and the bumper, possible that the vents may be upside down. the luvers should be black in color and about 5 inches square and the luvers should be staked like the tiles on a roof..
If you still cant find it get a garden hose out and water it down while you are inside looking for it ,best of luck, let me know what you find
Thank you so much, I will do that and see what happens, I will also have them check out the gas cap. You are a wealth of knowledge, thanks again for taking the time to respond. I will keep you informed.
