Ford Five Hundred/Mercury Montego: Noises
                    I just purchased an 2005 Five Hundred with 5000 miles on it. I have noticed a low grumbling noise at about 35 to 45 mph. Has anyone had this problem or is it a characteristic of the car,or could it be tire noise? It is a limited with awd and the cvt transmission.
alldatadiy.com lists all the TSBs for each model -- however a subscription is required. Personally - I think its worth the money so that you can look it up yourself and discuss it intelligently with the dealer.
The subscription also includes all types of diagrams, service instructions, etc.
You get what you pay for.
Nothing in the TSBs fit my case exactly, nor do the TSBs I read suggest a solution. Another fellow here said change out the uppper strut bearings. I have just discussed the problem with the local dealer suspension specialist who said the problem comes back after the change. It may be an "if you have it, live with it" deal that Ford is trying to pedal. :lemon:
I am in the market for a new FWD Montego. However, I dont envy all the "noise" issues discussed in this forum.
Have these "noise" issues been resolved in the 2007 FWD Montego?
I dropped it off at the dealer, and fortunately they could replicate the problem. It required replacing the instrument cluster. Fortunately, still under warranty.
I purchased an '05 Montego this past spring and have noticed it makes a whining noise similar to an electric motor when making a turn. Never put too much thought into it until yesterday, although I have heard it on other occasions and under similar conditions. So anyway, I am on the turnpike yesterday and when I get on the ramp to exit, my nephew says, "what is that loud noise? It sounds like an electric motor." There was definitely that kind of noise, but it only makes it when turning the vehicle. It also made that sound when I turned into my driveway after our trip. No noise when going straight. It is an AWD with CVT transmission and 71,000 miles. I did not purchase the extended warranty as they wanted $2,000 for it. Is this car going south on me?
1. Start engine and let it run until the temp is between H and C on the temperature gauge.
2. While engine idles turn steering wheel left and right several times.
3. Turn engine off
4. Check level in reservoir. It should be between MIN and MAX. Do not add fluid if between these limits.
5. If below the MIN, add proper fluid in small increments until the correct level is reached
6. Replace cap if removed.
