you can email them or call them and ask them about syncing your phone. They are very helpful. An update on my issues with the bluetooth: I now have an iphone 4g and have set up that phone. So far I am still getting the same complaints for whomever I call. I can hear them plain as day but they have trouble hearing me. I have yet to take the vehicle in for a service call but will do so eventually.
But overall it works just fine.
I have a 2011 Honda CR-V, SE, and ever since I purchased it (4 months ago), I am experiencing static noise and fade-away problems in some of the local FM stations. the stations are really not that far, and the signal should be pretty strong. interestingly, the noise or fade-away doesn't happen always. it happens some of the times. I have taken the car to the dealer multiple times, they haven't yet been able to identify or resolve the issue.
is anyone else having this kind of problem?
I hope this info help you guys out.thanks!!
My wife has the 2012 CR-V and I've always noticed she sounds like she has a lisp when I talk to her on it.
It's not that bad, I wouldn't worry about it.
Just got the 2013 CR-V EX. Love the stereo. Here's an issue I'm having that I hope someone can help.
When connecting my Iphone 5 using the USB dock and Bluetooth, at first, it works fine. I can listen to the Iphone via the dock with no issue. But if I switch sources, when I come back to dock, there is no audio. This is because on my phone, it defaults to HandsFreeLink. I have to go back to the phone and manually switch back to the dock.
Is there a workaround that is known?
So I have to go in and select 'normal' play mode, and then select shuffle. If I select shuffle mode it will shuffle but will repeat each song (plays it twice) before shuffling to the next one, so I have to first clear 'repeat' mode by selecting normal mode. Then I am able to select shuffle mode.
Anyone know how to solve this? It's not a setting on my phone. It's annoying to have to reset listening each time I want to use it.
I have a 2014 Honda CR-V AWD EX and the pairing of my Motorola Razr worked very well with the car's Bluetooth System. Problem occurred when I had to replace the phone with another Motorola Razr (same type). After pairing with car's BS (I deleted old phone from car's BS) it paired and connected correctly. I noticed driving the next day the BS system repeatedly connected/disconnected the phone and continues to do so. Several times I have deleted the phone from car's BS system and it doesn't help.
