I would like to know what you find so please return to the site and let me know.
Mike
Locate the Fuel Pump relay. It should be on the drivers side finder under the hood. Remove the Relay from the clip and unplug it. If the fuel pump stops running while the relay is out, it is the relay. Hopefully this is as far as you will have to go. If it does stop the pump, just replace the old relay with a new one. Please let us know what happens.
Mike
Truck runs ruf and the dianost. reads a code of 141 lean fuel. can anyone help
I ordered and received a Chilton's for my truck. It said that my '95 truck "has a modular In-Tank Reservoir (ITR) assembly consisting of the pump, a venturi jet pump, a supply check valve & a shuttle selector valve."
This last item I suppose is what I was looking for inside the driver's side frame rail. I guess I'm out of luck 'cause lowering my main tank sounds like more work than I'm willing to invest at this time.
Thanks again for your assistance.
mike9408
