Oh to the previous poster above my post the removal of the fuses worked for a while for us and then didn't anymore. If it doesn't start right up just give it a good whack on the top of the dash above the instrument panel and then try to start it.
You will find 2 plugs below the fuse box on the left side of the brake pedal. Unlug both of them, turn your key to "on" wait 20 seconds, turn key to "off" plug noth plugs back in, you're done.
Let me know
the door is extremely hard to shut and usually requires 3 or 4 times of slamming before the door will fully shut. does any one else out there have one of these older type of vans and have you had the smae problem(s) yet? if you did what did you do to correct the problem(s)?
:lemon: :mad: :confuse: :sick:
Have you tried calling Chrysler's Customer Service yet? If not, you are in for a thrill. You'll get to talk to a lot of agents in India. If you are persistent enough, they'll transfer you to someone in the US. Good luck!!!!!!
and last but not least sawsall blades 1 blade abt $1.50. it roughly costs about $25.00 to make a handle asuming that you dont have to purchase any of the tools special for this project.
not sure on the arc rods exactly how much they run they were my buddies he let me use his arc welder.thanks for all of you help guys and gals helpso far.
God Bless you all ! :shades:
P.s. if yall know how to upload pics please tell me how if you want to see the finished product btw I didnt go for prettiness just a working one. but i could dress it up and make it look better
by the way in case any of you all want to email me instead of posting a response on here or to email me for pics here is my emai address truckinforjesus@windstream.net
:shades:
It worked great for 4 days and now the lights are turning off again while driving. I deliver pizza part time and one of these days the pizza won't get there. I am waiting until it really stops working before taking it in. Otherwise they will think I am nuts.
I have a 1998 Dodge Caravan 3.3 engine, 147,000 miles on it. I came home last night and parked my car. This morning I went outside to start the car and put the key into the ignition. The key won't turn. I thought maybe the key was bent or something like that, so I went to get the spare key. It did the same thing. Key won't turn. The steering wheel is not locked.
Can anybody out there tell me what the problem might be and What do I have to do to fix the problem?
George
I had to give up my part time pizza delivery job because the headlights just don't want to cooperate.
Reseting the BCM didn't work anymore but taking the battery terminals off for 30 mins seemed to get everything working again. On occasion the lights will not turn on. It takes 3 or 4 times cranking the switch for the headlights to come on.
I did figure out while on a recent road trip that pulling the bottom plug of the BCM as described by kpeglow on 10/26/08 makes the head lights turn on but disables the entire dash board. I had headlights to get home but no gauges, blinkers or wipers.
For now the van only gets used twice a week when I have to go into the office. The rest of the time I carpool or share my better halfs car.
Good luck out there and let me know if there's a fix.
but any way take and replace the egr valve, the o2 sensor and the idle engine temperature sensors this will take care of your problem if it hasn't already sent a loop or register to your computer..... on a 1997 that one is almost fully electronic everything......no big deal if it has though either get you a code reader with a resetting capability or take it to a trusted shop and pay about $75. - 150 to have it reset. let me know how it goes truckinforjesus@windstream.net
I keep the cover on and when it acts up, I pull really hard on it and just do the switch manually.
The replacement part is only $50 but no rush since I can get the thing to work. I'll replace the part once I get ready to trade in or sell.
Good luck out there and be sure to check your headlight switch.
Checked fuses, wiggled key??? Any ideas?
