Toyota FJ Cruiser Blind spot
Help! We just got an FJ last week and I need suggestions on how to help with blind spots. We live in ATL and I am a vervous wreck when I have to change lanes!
Try this: Adjust both outside mirrors so that you have to tilt your head over to the window on the left, before you can see the side of your FJ in the mirror. This places the glass at an angle that shows you things coming up beside you. In fact when adjusted correctly you can see cars in the mirror right up to the point that you can see them out your side window.
Do the same with the right hand mirror..Adjust until you have to tilt your head pretty far to the right to see the side of your truck.
I have been doing this for years in SUV and cars for that matter. It keeps you from changing lanes when there is someone in your blind spot. Actually it seems ackward at the start but you get used to it very quickly and it is way safer. I learned this little trick from the Car Guys on NPR and it really makes a difference. It virtually elimates all blind spots on FJs and other vehicles too.
Give it a try, I bet you like it. You will be shocked at how many times you glance in that mirror to see a car alongside you that you had no idea was there and that you could not see otherwise.
GypsyJon
Thanks for the tips=
BTW-we have a yellow FJ from Sandy Springs Toyota!
There's a bit more in the Help link - How do I post a photo in the Forums?
Any helpful ideas? ( I am not a bad driver and do use my mirrors)
1) Angle your stock mirrors out to pick up traffic on either side that is out of your view when you turn your head slightly and not so far back that they show up in your rear view mirror. As one guy I know said, the inside rear view mirror is for the rear view. The side mirrors are for the blind spots. Now this didn't work for my wife who resets the mirrors every time she drives the FJ after I have driven it. She won't practice driving with the mirrors out; rather she wants to see the side of the FJ in the mirrors when she uses them. You are wasting your time trying to argue the point to my wife, she won't listen; thus this solution did not work for "our" FJ.
2) For about $2.50 each buy two 3 inch round convex mirrors, (sometimes called fisheye mirrors) and stick them in the outer top of the stock mirrors. They even have them now that are adjustable, (modest movement). They won't block your stock mirrors, and will give you a view of what's beside you and not showing up in your other mirrors. They take a little getting used to but they work well once you make the driving adjustment to using them. I practiced by watching traffic in other lanes as I passed it to get a feel for what a close vehicle looks like compared to something farther back.
The second solution was somewhat forced on me by my wife’s attitude but I do think it's the best way to solve the problem.
Roll
http://www.multivexmirror.net/Details.asp?ProdID=1089&category=6
I love this car -- i have it as a second car and use it to go up to the mountain, to lug stuff around or when it rains (my other car is a convertible)
But like pretty much everything, we humans can certainly adapt. How are FJ sales doing? I've seen many on the South West Coast of Canada. And similar to a nice looking woman, I can't help but glance.
On another note, Toyota is planning on re-introducing the Supra? That could be good.
Enjoy!
The sideview mirrors should be set as follows:
looking in the rearview mirror, as an overtaking vehicle's bumper just leaves the view of the rearview mirror, it should just be coming into view of the sideview mirror on the side that is being overtaken (passed). This should be the setting for both left & right side view mirrors. When set properly, the sides of the vehicle being driven are NOT visible in either sideview mirror.
I've heard it said that it should be absolutely unnecessary for a driver to swivel his/her head around in order to see what is beside or behind the vehicle being driven--everything should be visible in the mirrors when properly set.
The Zen of Adjusting Your Side Mirrors
It could be me...nonetheless, these links do not seem to work
Seriously, a few people do have problems getting to the CarSpace links for some reason.
Try going to the Guides tab at the top and then you can drill down to the mirror adjustment blurbs that way. The easiest way find them there is to hit View All under the Driving and Safety section.
