Real World Towing with the Pathfinder
trailerguy
Member Posts: 9
in Nissan
I have a 2005 Pathfinder LE and want to tow a travel trailer (I already tow one at 2800 lbs.). Does anyone have any real world experience (including the Rocky Mountains) pulling 4000-4500 lbs. loads for long distance and periods (yes, I know the manual says it will pull 6000!)?
Also does anyone know of a good, sturdy set of extension mirrors that can be had for this thing?
I suspect the 2006 capacity is the same as 2005 (max of 11110lbs or 6000 lbs tow). I will try to post something once I have tried it for a while.
Our Surveyor is 4100 lbs. unloaded and proably pushing 5000 lbs. loaded ( we seem to empty the house into the trailer since it has so much room compared to our last TT, a Casita - a great trailer but too small for us!).
The Pathfinder does not like this much but if you keep your speed to about 60 mph you can still get almost 12 mpg. Besides, if you watch all of the other things passing you on the interstate, you get some idea what everyone else has!
I do not think we are going to cause any damage pulling at this 80-90 % of the towing limit and prefer to try to leave a 1000 lbs. margin. We also chose a low profile TT to stay within the 60 Sq. Ft. front area limit. We had high head winds going west this past week and it really causes a lot of problems.
I recommend a combination anti-sway and equalizer hitch. I am using the Equal-I-Zer brand it seems to work well.
While I would really like more capacity I have problems driving a something called and "Armada!" (and besides, it won't fit in my garage!).
Check if if you have more questions.
TG
Please let me know how you feel about pulling your new TT.
I am on the verge of purchasing a surveyor sv291 which is a 29 footer. Weighs 4800lbs dry. I have a 2006 pathfinder.
In theory, it should be okay but I would love your feedback.
If I may, I would like to comment on Forest River product quality. While I don't think they are worse than others in the industry for these light weight trailers they do have some room for improvement. I would be happy to share details but suggest you contact me directly at johnt@indra.com and avoid all this web site login business.
John T
On wiring harnesses: The dealer is all wet! You need six wires or the seven pin harness to tow even a Casita 17 ft TT let alone some thing like the Surveyor you mentioned - one for ground, one each for left and right turn signals, one for tail and running lights, one for battery charging, and one for the electric brakes. So, you will not be able to use the Pathfinder until you run and extra two wires from the engine compartment. I recommend a good RV service dealer to do this when you have the electric brake controller installer. Good luck.
TG
TG
I have several hundred miles on my Surveyor now and we are leaving for a full summer in the northwest and Canada day after tomorrow. I built a carrier for a Honda generator that sits on the back bumper so we are fully self-contained (as long as the holding tanks don't get full).
This will be our first real trial in real mountains so I expect to be moving rather slowly once I leave the flat land. Anyone who wants to follow along with my picture log should contact me directly at johnt@indra.com.
Trailerguy
Consider posting your pics right here in your very own CarSpace!
SUVs and Smart Shopper
Not like I know very much about the subject, but I didn't see anyone mention this stuff and seeing one guy just bought a 24 footer or something- the following is some info I have learned on various info websites.
Keep in my of the following because it seems extremely important.
When you count the maximum tow capacity- make sure the max is the DRY weight or unloaded weight- meaning
THIS IS THE TRAILER ITSELF NOT EVEN INVLUDING ANY "options".
You must remember to add the car you are driving- your (driver), passenger- AND any cargo weight as well.
One more thing- don't forgot the amount of people you would ever want to be riding in the trailer- their weight- lets say 200 lbs per person plus their cargo.
Chances are the new weight is much, much more than the max which you may just be reaching.
The person who said they want to save 1000 lbs to be safe- sounds good but you may be forgetting completely all your luggage which may be 1000lbs easily itself. I think it makes more sense AFTER you factor in all weight- give whatever the weight is ITSELF- an extra say 5-10%.
The length of the trailer really just depends on the amount of room you need to move around as upon researching them- many smaller ones- and larger ones have similar weights- me I think at least to begin with I would feel safer turning- maybe reversing (yiiiiikes) in a 16-19 inch trailer.
I have NEVER towed before and although the thought makes me anxious, it isn't for any other reason than I hope to be cautious and to it correctly then after getting the hang of it- there should be no reason to be- scared because I took all the necessary steps.
Any advice for a first timer?
Ie: more mirrors?
driving at a given speed depending on the amount of total weight.
Any advice involving hitches- and weight distributions, brakes (upgrades) i know NOTHING!
Fnatic
That said, you would be surprised what you end up carrying especially if the trailer you select has a lot of room. Mine is a (Surveyor 24 ft. model) weighs about 3800 completely empty. I weighed it at a landscaping materials place the other week when it was fully loaded (all gear and tanks about 3/4 full) and I found I had added 1500 lbs of stuff! this meant that I missed by desired margin of 1000 lbs by about 5000 lbs.
Everything works fine as long as I don't try to go too fast uphill but I am still not pleased with what it must be doing to my Pathfinder.
Other things to consider beyond weight are frontal cross section (for wind drag) and length (to handle cross winds on the highway). Sometimes the owners manual specifies these and sometimes not. There is a lot of advice on the Internet on both of these.
thanks for the heads up. It seems the pathfinder considering I am in a city the small size plus its capability to tow 500 lbs (pre 05) is amazing is perfect but I am a car person and i am still not sure I would be happy with the car. I may just make do with a the lightest trailer cruiser 130x at 2600 pounds and use a 2007 impreza rs wagon, 2005 outback wagon, even pacifica!
If you put it your way it's scary to think no matter what you cannot in essence use the strength of the car and pull something without damage meaning the car can pull it with ease. I can't help but think that must be possible, because I do not want to take ANY chances and frankly anyone who does is just plain stupid and careless. No I won't be getting a pickup and certainly fuel economy will suffer but I will simply go smaller, or ensure there isn't any strain - unnecessarily...
I will be towing a 3200-lb (dry) 26-ft. Trail-Cruiser 26QBH trailer to Bristol for the NASCAR race next week. 4 big guys, lots of beer and gear - should be a good test for the Pathy over mostly level ground.
I'm curious whether anybody has experience adding a K&N intake kit to a vehicle to increase performance (and presumably MPG as well). The kit I'm considering is the Air Charger Performance Kit (part #63-6014), and it will allegedly add about 14 HP to the 266 that is provided by the stock Pathy. Might be worth it for $270, especially if fuel mileage improves. I can't tell that it creates any warranty issues with Nissan, either.
Thoughts?
Great forum... I have a 2006 Pathfinder SE, which is a rare sight in SE Michigan. In the past month, I have added a brake controller, 7-pin connector, weight distribution hitch, and a K&N air charger intake kit (63-6014) to pull my ~4000 lb hybrid travel trailer. So far, so good.
We just returned from a long weekend trip out of the flatlands and into the rolling hills of Kentucky. With the exception of the poor roads in SE Mich, the trip was great. The Pathfinder had no problems pulling the trailer at 65 mph on the expressways and through the rolling hills of Kentucky, averaging ~ 10.5 mpg for the entire trip. Does anybody else have experience pulling a 4000 lb trailer with a 60 sq. ft. frontal area with the Pathy. I am curious how my mpg compares to others that have not done the cold air intake upgrade yet.
Jeff
Kip
I currently tow with a Suburban and while it handles the weight much better, I can honestly say it doesn't have any more towing power. Those Nissan powertrains just rock.
What you'll need to watch is tongue weight. Most boats are in the 5-10% of gross weight for tongue weight. You'll need to make sure your not overloading the rear axle, which can cause some handling issues. Get the boat and have fun. Being that close to the GCWR, I'd recommend not towing real far.
I've seen your reply on the forum so I thought I'd ask you this question (and anyone else who reads this). Will an older Pathy (3.0 V6) be able to comfortably pull a small boat (1,500 lbs)? I don't want to stress out the engine or tranny. I trying to decide if I need to get a vehicle with say a 3.8 or 4.0. As you can probably tell from this message, I am fairly clueless when it comes to towing requirements.
-Thanks
Matt
I think the Paths with the 3.0L have a tow rating of 5000lbs, so you should have no issues with 1500 lbs. I have an '04 3.5L and and have towed at the 5000lb limit with no problems. If you find the tranny "hunting" for the right gear, just hit the OD off switch (shouldn't have to at only 1500 lbs) - the engine will run comfortably at the higher rpms and you'll be in a better spot in the power band.
Mike
Thanks a lot for the reassurance. I've read great reviews on the Pathfinder, but was a little worried I'd be over working it. Thanks for bringing back to reality!
-Matt
If you are going to be towing for long distances or hilly terrain, an auxiliary tranny cooler might be a good idea. Just a little extra insurance!
I don't know when Nissan started putting them on as standard equipment.
Kip
http://www.rvtowingtips.com/
Kip
My 2005 Pathy LE tows my 18' dual console boat/trailer @ approx 4k lbs just fine. Would rather have v8 truck but Pathy is more flexible for my uses.
