Toyota 4Runner Start Stall Problems
I have a ’91 4Runner 4WD V6 with 190Kmiles (original owner) and have a starting problem. Once the truck warms up to operating temp (ambient temp above 80*F) then off for a few minutes (like driving to the gas station to fill up) it would not start. The solenoid will “pop” but no starter motor activity. I rebuilt the solenoid with Toyota parts
worked for 2 weeks
same problem
hmm...replaced starter motor with remanufactured one from Orielly Auto (house brand)
worked for 3 weeks
same problem. Rebuilt solenoid with Toyota parts
worked for about 2 weeks. Took it back for an exchange...same result week after week. Then I went to Pepboys and bought a reman’ed Bosch
This time the solenoid would not “Pop”
I tapped on the solenoid it worked
hmmm
took the starter back and got another
same results. I have rebuilt the ignition switch, added a new ground strap directly to the starter mounting bolts, added power wires to the starter solenoid and motor and replaced the battery. Nothing seems to work! I am getting 11.92V to the solenoid and 12.76V to the starter motor regardless of starting or not. I’m about to throw in the towel. Any ideas? I will consider anything at this point
Any direction would be greatly appreciated. Thank you!
I was told it may be the engine or the belts. Checked the belts, they were fine. The engine, I was told, would cost me 2,000 for a rebuilt one. Is that normal?
I'm not sure if I take the 4Runner in, will I get screwed over? One mechanic that I called said that it wouldn't be worth replacing the engine on such an old vehicle.
I guess I should mention that it's a '91 V6 and has well over 220k miles... but I like my 4Runner... It has saved me from some heavy water and I hate driving the little cars.
Can someone point me in the right direction, please?
Aloha
Keith
Here's a little run down on battery problems;
If your battery connections are loose or dirty, when you turn the key to "on", everything looks fine as far as lights, gauges and radio go. But when you try and start the vehicle, the amperage draw is so much that the connection is now lost due to the fact that the battery is weak or dirty/loose connections.
Start with removing the (-) negative terminal then the (+) positive from the battery. Clean and inspect the terminals and the battery posts. Reattach doing positive first, then the negative. Coat the connections with some dielectric grease.
See how it starts...if OK you're good to go.
If not, take your 4R to a shop that will test your battery.....
Your connections might be loose or corroded down at the starter and ground point on the engine block but start with the above (easiest) first.
Good luck!
did you find out your problem? I have a similar one, and I am thinking it is the starter. let me know what you found.
thanks.
bcg
I had added a viper alarm to my truck with the help of my friend as soon as i got my truck about 2 years ago, so i thought maybe we screwed something up, but i sounds like i am not the only one.
I hope someone has a clue what is causing this......
Thanks to anyone that can help.
Thanks for any help...
I started to attempt to pull the tumbler but the manual refers only to a column mounted ignition and mine is in the dash. I can't seem to release the retaining pin to remove the tumbler.
Can someone lead me in the right direction???????
hello. 1996 Toyota 4 runner 316km. Ran fine. First thing to fail was the signal lights. Fuze blown and replaced. Instrument fuze blows next, then stereo looses power. Get the thing parked. Shut her off, went start her again within 15 minutes. Did not want to start, but fired up. Would not shift out of park. Throttle was very delayed from pedal input. Died quickly, got a boost and fired right back up. Stereo came back on. Still would not shift from park. The engine would sputter when given fuel and eventually died again. Starter clicked at first. Then nothing.
Any ideas? Will be towed to a shop. Trying some the earlier suggestions.
