Symptoms as follows:
Car dies not have climate control.
Engine thermostat is functioning properly.
Coolant level good.
After engine is fully warmed up, turning on the heater only yields about 15 seconds of proper function with hot air blowing strong. After that, the air flow slightly decreases and the air blows cold.
Analysis:
Blend actuator door is closing due to a faulty signal from the temperature controller or the blend actuator door is broken.
Please advise or comment.
Thanks to all in advance,
Jakec
Well, a friend was due to look at my car on Sunday. On Friday night, my husband and I are driving home when suddenly the car just stalls while being driven with tons of steam coming out from under the hood. The temperature gauge on the dash was in the green and in the middle between hot and cold. The car would not restart. We wait at the side of the road for it to cool just enough to limp the car into the parking lot that had a street light in it (we didn't have a flashlight). This parking lot was less than 100 feet from where it stalled.
Well, we couldn't help but notice that all of the car's coolant was on the ground underneath the car. We purchased more coolant, poured it in, turned on the car so that the coolant could circulate, but the car immediately dumped all the coolant on the ground. The car has enough oil, so there isn't a problem there.
One, what could possibly cause this problem?
Two, would the engine be damaged since, obviously, the engine temperature gauge isn't working and I don't know how long it was overheating before it stalled? (it was very late at night and to be honest, I was just barely staying awake at the wheel)
Any suggestions before I start tearing apart the dash. thanks
TIA,
Steve
Does anyone know about this problem? How do you get the A/C to reset? That could at least be helpful, since we are now going to be facing very high temperatures here in the near future!
FYI - that generation car had very poor cooling systems and transmissions, but if taken care of aren't too big a problem (a new water pump only cost me 30$ since I could replace it myself).
just had a thermostat changed on my 01 Sable. Was running fine before, just no heat. Thermostat was definitely bad. However, as soon as that was done, the car ran terrible! The engine light also came on. The mechanic swears he did nothing else and now doesn't know what to do. Is this maybe a coolant sensor problem...could that have been damaged during thermostat installation? Maybe incorrectly installed thermostat? There looks to be some kind of sensor right above the thermostat and I wonder what that is and if that could have been damaged, causing the running problem.
