Buick LeSabre: Problems & Solutions
Post your LeSabre issues here.
thanks for you help.
I've heard this problem mentioned in other discussions but can't recall the types of outcomes they had.
Were the battery cables inspected throroughly including the double connector on the positive terminal, if it has one? They can corrode from acid down into the copper cable; the ends can appear okay but you find the actual cable corroding away inside the plastic coating. Check the ends of all grounds and positive wires at the other ends. Loosen and retighten.
Plugs? AC and within last 60K miles? Book recommended type?
Wires? OEM quality NAPA, Belden, Delco? Not something in red box with dragons on it from box store? within last 60K?
doubledog
Has anyone else had a problem with the wheels rusting?
My car is a 2004 celebration edition, has 16" chrome wheels. Was made in late May 2004. Now just 2 years old the front wheels are covered in rust. I'd thought that brake dust was covering them, but on closer inspection, no, it's rust.
I'm wondering if this is covered by warrenty.
I think Toyota could even pull #1 in Sales this year ??
Done with Buick and 'maybe' General Motors (like a Whole Lot of Others). The quality just isn't there but it is with the Toyota.
susieskunk
If I'm right, your mechanic should have check the blower control module that's in the housing near the blower motor on the firewall under the hood. The blower control module does what the resistors do on a standard blower setup only it's electronic giving more speeds. Follow the power line from the blower motor to the unit, about 4 in x 1 in x 6 inches. It goes into the air path inside the housing endwise and the air stream cools it.
They typically fail and the blower won't shut off even with the key off. Sometimes they give strange speeds on the blower with erratic changes. That's what ours did. I believe they're available at Advance Auto parts, the chain store and of course recycling yards.
