Honda Accord Keyless Remote
I just purchased a '98 Accord LX 4cyl/4Door, and it came with a Keyless Remote with 4 buttons, one of which is marked "Option" - what does the "Option" button do?
According to the owners manual the button in that position pops the trunk lid, but this button does nothing by itself afaik.
I've tried holding it for several seconds to see if it might toggle the audible/inaudible operation when locking/unlocking but it doesn't seem to do anything.
My 98 EX had 3 main buttons. Unlock, lock, and trunk. There was a small red panic button as well.
There is no LED on the remote, and pressing & holding the "option" button seemingly does nothing.
The remote has 3 buttons plus a small red "panic" button. Also has Honda markings stamped in the plastic and stickers on the back indicating an AHM part, so I don't think it's aftermarket, maybe the dealer knows - I'll check next time I'm in for service. In the mean time, the alarm and lock/unlock functions work perfectly.
I have the keyless entry key and after only driving for a short period of time (15 mins) and when I pull the key out of the ignition - the metal portion of the key is extremely hot to touch..
Does anyone have any ideas? I would greatly appreciate it..
I called the Honda shop I frequent and explained the problem to the service advisor and he said check all 4 doors. I almost said "hey genius I did that before I called you." I have an appointment on Thursday. I wonder how much this is going to cost. :confuse:
The windows coming down is supposed to happen. You should also be able to do this by pressing the unlock button twice on the remote, and holding it the second time.
They ended up replacing some control module which was time consuming due to the fact they sent the wrong part the first time. The repair was 330.00 dollars but I was smart enough to purchase an extended warranty and my deductible is 100.00. I can honestly say the quality of this vehicle is nowhere near the quality of the 94 Accord I previously owned.
btw
How much does it cost to replace the valet key?
By "inside", I'm assuming you mean with the key in the ignition. The remote won't work with ANY key in the ignition.... regular or valet.
Found the FCC ID should be: KOBUTAH2T
Honda wants $110 to replace. I found a place online
keylessremotesonline.com that has it for $38 and I program it myself.
Anyone heard of that website or can direct me to another company to
buy my OEM New replacement remote for cheap?
Jackie
00 accord ex v6 black
Just found this site. It's very informative. I have 2005 Honda Accord with only 55,000 kms on it. I have replaced battery & starter already. Now, I'm having a problem with the keyless remote and the power door windows doesn't work. But the sun roof powers up. The funny thing is that the power door locks do not work on the driver's side but can lock & unlock on the passenger side.
I'm just wondering if anyone of you experienced car fanatics have had this problem or heard of this.
Please any advise or solution will be greatly appreciated.
I am so sick of making appointments to bring my Honda in the dealership.
http://tinyurl.com/2t8zun
I tried to print out your step-by-step to reset the power window, but it looked fuzz and small, could you give a hint as to how to read it clearly? Thanks
John
