Toyota Yaris Engine Questions
I live in Florida so I have the LUXURY of being able to dump ALL my cooling fluid and replace it with a mixture of 15 percent Glycol, distilled water AND WaterWetter. I have dropped engine operating temperatures significantly. I will be able to provide EXACT temps shortly but it looks about its a 20 degree drop. GLYCOL transfers heat VERY POORLY so the less you can use the better. IF YOU LIVE WHERE IT GETS COLD YOU MUST HAVE FREEZE PROTECTION. WaterWetter ADDS to heat transfer making the cooling system more efficient.
But what is Water Wetter, and why can you use it only in Florida?
http://www.redlineoil.com/products_coolant.asp
The company is so good at marketing that people actually think its a quality filter. Oil filters utilize filter media to "filter" the oil. Fram has some of the least filter media of ALL filters. Factory OEM filters are generally decent quality but there are ALOT of filters that are far superior to OEM. I personally use Mobil 1, Porolator PURE ONE, ans I used to waste my money on K&N and Amsoil filters. Believe it or not the Wal Mart brand filter actually performs BETTER than many name brand filters.Check out the reviews on the "quality" Frams!
CHECK OUT THIS:http://minimopar.knizefamily.net/oilfilterstudy.html
http://motorcycleinfo.calsci.com/FilterStudy.html
The Yaris is already designed to run on 87 octane. Aint none lower than that available at the gas stations in my state - perhaps there is in Florida? If you have some source for 85 or 82 octane unleaded and you want to trade in a bunch of expensive chemical additives to make the engine run cooler, thereby tossing out the low-cost-maintenance advantage of this car (which would otherwise require no coolant changes for a long time), just so you can see some slight gain in performance, more power to you. Literally! :-)
I personally WASTE MONEY and use Mobil 1 w/Mobil 1 filter every 5K. I also expect to hit over 300K on my vehicle. Since there is a TIMING CHAIN on the 1.5 my PRIMARY CONCERN is providing the best lubricants available in order to acheive over 300K on a 1.5 liter motor.
I just wanted to make sure a balanced view got onto this thread, that's all. Do all that stuff you love if you want. The Toyota 1.5 is one of the most durable engines they make - I am quite sure that with maintenance by the book, it will go 300K miles with or without the synthetics and whatnot.
It is fun to baby your car.
I just spent an hour on the phone with Toyota tech support. I was given a case number and it simply states that the owner has informed Toyota that he is using FULL SYNTHETIC LUBRICANTS in his car. Toyota HAS NO ISSUE REGARDING WARRANTY CLAIMS, as long as you keep proper records and NOTIFY them that you are switching to SYNTHETICS.
I might go 10% higher than the recommendation (which would be 35 in the Yaris), but not more, for those reasons. Usually I just follow the manufacturer recommendations.
But yes, you will make 10-20% better fuel economy, probably. Which will save you probably $100-200 per year (at 12,000 miles per year), for which you will pay by going through your $300 set of tires maybe twice as fast as you otherwise would, costing you around half your savings. So is saving $50-100 per year worth compromising your tire traction? It's a decision only you can make.
www.nhtsa.dot.gov/cars/rules/TireSafety/ridesonit/brochure.html
alot less room for error. also on door car has gvwr 3280 lbs
what does it really weigh?
:P
j/k
T
I took my Yaris to my dealer for the first free oil change and was very happy with the service. I have a second one coming in a few weeks. (Free as well, I paid sticker but got a second one free as part of the deal! Hey, I did better than some!) I am seriously thinking about letting the dealer do all my normal service! I know that is crazy, but they are quick, nice and close.
My question is do they really do more during a normal service than somewhere else? Is it worth the extra dollars to let them do it? Would it really be worth it to take it to them on the normal (about every 5,000 miles) service schedule?
I am not going to do my own work, but I'm not mechanically inept either, I just don't have the time, but I might have the money if I thought it was beneficial? Comments please...
That's what I did. I mean, it's SO convenient, I don't have to balance my checkbook anymore. I just go to the dealer and they tell me what's left in my account.
Now the kids are happier. The wife is more content with life. We should all have our cars serviced by the Dealership more often.
:shades:
I have found a few things to be true, which has led me to do a lot of servicing at the dealer:
1. most routine servicing is about the same price at the dealer as elsewhere, give or take a $20 or so, which I am in a financial position not to really care about. Also, since my dealer also washes and details the car at every service, it's worth an extra $10 to me anyway.
2. If they somehow screw up the servicing, they will stand behind their work much more than most independent shops, and certainly MUCH MORE than the corner Jiffy Lube or gas station.
3. If it's a service where you have to leave the car, every dealer I have ever been to has had either loaner cars, on-site rentals, or a shuttle that will both drop me off and pick me up, and usually some combo of two or more of those.
Now, can you get a faster oil change at the Jiffy Lube? Yes, definitely. In and out in ten minutes beats the heck out of the dealer's express 29-minute dealie, which usually is more like 39 minutes. I don't mind, but that's just me. I cruise the lot checking out the new models. :-)
And they also do the wash and detail, like I mentioned, at my local dealer. And check all the underhood fluids.
Also, for major repairs, you can usually get a significantly better price at independent shops than the dealer - as for whether or not you will get the same caliber of work quality, it varies shop to shop (and dealer to dealer, as they are certainly not all equal either).
Oh, final note: I don't typically follow the manual when it comes to every minor service. That WILL wind up costing a fair amount of extra money, IMO. I do intermediate servicing at 15K miles, a major service every 30K, and oil changes at 5K intervals with tire rotation every 10K. Once I'm out of warranty, it just gets the one big service every couple of years or 30K miles (with oil and tire rotation at the usual intervals in between), which has always proven sufficient for my driving pattern.
Your schedule sounds about like what I had in mind. And I agree with you, I’d don’t mind paying a few extra dollars for minor service that has benefits.
I'm an advocate of FULL SERVICE. That's why I chose to direct deposit ALL my payroll checks into local service dept's account.
I WANTED THE TOYOGUARD and Pinstripes and VIN etching. I wouldn't have had it any other way. I'm not going to leave my baby exposed to the elements.
Heck, I even have my gas pumped at FULL Service fuel stations.
87 Octane? NO WAY!! Not for ENTRY LEVEL my mode of transportation. I baby it with SUPER PREMIUM high grade 99 Octane. Sure, I could save a couple measley cents by running across the street where they just sell regular gas, but I choose the service station with the ULTIMATE Gas Guarantee. This way, if my clown car ever goes bonkers, I know they'll stand behind the Gas they sell and replace my engine for FREE.
I even take my car in to service everytime I need my mirrors adjusted (just so that they are accurately calibrated with the X and Y axis).
It's just like the old proverb: You get what you pay for. And that's why I ALWAYS Pay more for Good, QUALITY, GUARANTEED products and service. I'd rather be POUND WISE and PENNY FOOLISH.
Can you believe some moron actually once told me to BUY LOW and SELL HIGH? I say: BUY HIGH and GET MORE FOR YOUR MONEY. Tell the cheapskates to stay at home. :P
T
A couple of other notes as to what I wrote:
1. that schedule works for me because I drive the car about 18K miles per year, and a lot of my miles (more than 50%) are on the highway at full speed. If you do mostly rush hour driving, or you drive way less miles than me, then you may want to adjust your schedule accordingly.
2. One thing you DO have to watch out for at dealers: some dealers have a list of "recommended services" that so far exceed the manufacturer recommendations that you can really overspend. If that is the case at your local dealership and there is no convenient second choice dealership, then for any services that are not just oil changes or tire rotation, you can either
- bring the owner's manual in with you each time you leave the car, and just have them do what is shown in there, which may cost you less (paying a la carte, instead of their combo price for extra services), OR
- call ahead and price out just the services you want (again, using the manual) and then call a good independent shop and get a quote from them, and compare prices.
One thing that can be very beneficial with Toyota servicing is to use Toyota parts, rather than aftermarket parts. So if you give the dealer a miss, you may want to still ask that the place you DO go use Toyota parts. Any place worth their salt will do so upon request, and it shouldn't cost much more.
Again, I don't mind paying a FEW extra bucks for quality and honest service. I live in a small town, and people come from the big city just to deal with my dealer. Believe it or not there are some good ones out there...
Kiss my :P
I guess you're also the type to slap a baby for smiling at you?
:P
If not then PLEASE UNDERSTAND thats the BIGGEST SCAM CAR DEALERS use to make money on HIGH DEMAND VEHICLES. TOYOGUARD does NOTHING. The warranty is WORTHLESS. People actually think that TOYOGUARD PROTECTS THEIR PAINT and if the paint gets DAMAGE THAT TOYOTA WILL REPAIR IT. TOTALLY FALSE.
TOYOGUARD IS NOTHING MORE THAN A POLYMER PROTECTANT. WANT PROTECTION?
WWW.ZAINOBROS.COM FOR POLYMER
WWW.ARMOURFENDUSA.COM FOR ACTUAL PAINT PROTECTION
As for the interior 2 cans of scotchguard at a cost of 10 bucks protects the interior.
I change my own oil and filter because I know its done PROPERLY AND I USE THE PROPER PRODUCTS.
FULL SYNTHETIC MOBIL 1 AND EITHER A PUROLATOR PURE 1 OIL FILTER OR A MOBIL 1 OIL FILTER. THEN REGULARLY CHECK YOUR AIR FILTER AND BASICALLY THATS ALL THERE IS TO GETTING 300-400K OUT OF THIS ENGINE. I ALSO SWITCH MY MANUAL GEAR OIL TO FULL SYNTHETIC REDLINE AS WELL.
The YARIS is the easiest car I ever owned when it comes to oil changes. It takes literally 5 minutes to change my oil. ITS DONE PROPERLY WHEN I DO IT. I CAN AFFORD 5 MINUTES TO MAKE CERTAIN THE JOBS DONE RIGHT.
Bringing your car for oil changes is like RUSSIAN ROULETTE.
You never know who is doing the work or WHAT OIL AND FILTER IS BEING USED.
HERE IS A LINK REGARDING OIL FILTERS. AS SHOWN FRAM FILTERS ARE AMONG THE WORST FILTERS MADE. GUESS WHAT MOST SHOPS USE WHEN THEY CHANGE YOUR OIL?
PENNY WISE DOLLAR FOOLISH? I SUGGEST SPENDING YOUR MONEY ON QUALITY OIL FILTERS AND FULL SYNTHETIC OILS (NOT BLENDS) AND CHANGE YOUR OWN OIL.
A SET OF RHINO RAMPS ARE 20 BUCKS, JUST DRIVE YOUR CAR ON THE RAMPS AND DRAIN YOUR OIL. PLACE A PLASTIC BAG OVER THE OIL FILTER AND UNSCREW IT. THE OIL WILL FALL INTO THE BAG ALONG WITH THE FILTER. NICE AND NEAT!!
HERES THE LINK ON FILTERS:
Here's the problem: PEOPLE KEEP PAYING IT!!!
If you don't understand why dealers keep charging it when people keep paying for it, I dunno what to tell ya.
We currently don't have a prep package like that. We DO however, have a $5000 "Chrome Wheel" package that goes on all of our automatic FJ Cruisers. Are the wheels worth $5000? OF COURSE NOT! Do people pay it? THEY SURE DO!
The bottom line here is, if you don't want it, don't BUY it. If enough people stop, IT WILL STOP. If people keep paying it, don't blame the dealers.
We aren't the Red Cross. We want to make as much $$$ as we possibly can, but most importantly, we want to make as much as you will LET US.
Everyone, including dealers, knows how worthless things like Toyoguard are.
But Toyoguard allows them to make money on cars they'd otherwise have to give away. Especially when people come in waving invoices and wanting full retail for their trade...
If you don't want it, don't buy it.
T
I could definitely go for a Yaris, but I can't see going into debt for one when my Corolla is bought and paid for, and with only 93K miles, it's just getting broken in.
My name is Jesse Brenneman. I JUST bought a Yaris yesterday, and am amazed by the comfort, the drive, and the looks.
However, this morning, my key sort of stuck in the ignition position. I mean, it didn't automatically kick back to where it normally does. So I went to move it back myself, and the engine turned itself off before I could touch it. I was thinking maybe it sensed something was weird and shut itself off. So I waited a minute and tried again. This time it started nicely, but the "check engine" light came on as soon as it did. Weird.
Next, I put gas in it, and the gas cap wouldn't click when I tightened it. I tried like 10 times, but got cold so gave up.
I was wondering if anyone else had experienced similar problems.
Jesse
On the subject of engine lights and gas, here is another weird one. When I picked up my new liftback last week the salesman made the comment that they have had problems with engine lights coming on for customers who use BP brand gasoline. He recommended using any other brand and kind of endorsed Speedway brand. Has anyone else ever heard such a thing?
2) I can't find a recommendation for the interval to change the AT fluid in the manual.
