Honda Odyssey DIY Tips
Here's an opportunity for all you know it alls to help others with doing the simple things on the Odyssey. Give detailed instructions (step 1, step 2). Provide links to where you bought the parts.
For instance, oil changes and air filter inside the van are examples.
If you have done something unique, share it with the Ody community. If you have found some technical tid-bit that is of help, share it.
-Hypercore
-Hypercore
Jipster, always good to have an editor around :-)
The title's been changed.
-Hypercore
DIY instructions would be even better if we could post pictures in addition to text.
Another option, which I may opt to do, when the occasion arises, is to put together the document in Acrobat format and have it available for download from a repository.
How would I find info. on how to remove the dashboard or just the CD player?
* remove steering column covers
* CAREFULLY pry off center panel (trim around the stereo)
* remove two bolts holding radio bracket
* pull out bracket (disconnect electrical connectors as you go)
* remove 4 bolts holding cd player to bracket
* ta-da
If you have a newer Ody or would like to see the pics, I'd recommend picking up a Chilton or Haynes manual. I've used mine often, fixing various things in my wife's Ody. There may be others available too... maybe better ones. I have a Bentley for my car but they don't make them for Hondas.
ClaireS, Host
Coupes & Convertibles | Vans & Minivans
Drive on over and see me!
Actually, I have several computers that are on 24/7/365... even when I go on vacation for weeks at a time. I can access everything on my PC(s) from remote locations... My brother helped setup all of this. I don't know all the ins-n-outs of it, but I know it works.
As for being prone to hacking, I have multiple firewalls setup.
Could someone please post how this is properly performed for a 2001 Odyssey EX?
Thank you :confuse:
http://www.hondapartsdeals.com/honda_install_guides.php
Chimrichalds Photo Album: Installing a Grille Insert
I have performed quite a few automatic transmission fluid changes and in all the vehicles I have done you had to physically remove the transmission pan by un-bolting it and then change out a filter. I would guess that Hondas also have a transmission filter.
When I perform trans fluid changes I measure exactly the amount of fluid that was removed. You can do this using a 12 oz disposable plastic cup and count how many times it is filled. Then I add the same amount of fluid back. You do not want to over fill the transmission, and as long as it was not over filled to start, this will work. You should drive the vehicle and check the fluid according to the manual, usually warm in Park. Add fluid as needed.
Manual transmissions are much simpler. There usually is no filter and you just drain, measure and refill.
200 bucks is a major ripoff! it is sooo simple and only about 20 minutes (once everything is figured out).
First of all -what you need to get - use only HONDA Transmission Fluid - they have a special additives that no one else uses - warranties are null and void if you don't use Honda tran fluid. (Special additive packages are available to add to regular tran fluid, but, in the end, costwise, its not worth it - dish out for genuine honda fluid) and get a replacement "gasket" for the drain bolt.
Ask your dealer how much to replace (if it isn't actually in the owners manual) (there are fluid capacities and refill quantities) - ask for refill quantity.
drive the car first so that the tran fluid is at least warm -i think hot is preferred- (i suspect to get whatever particulates in there suspended and thus removed w/ the fluid)
The fill bolt is on top of the transmission (roughly below and to the left of the brake cylinder in the back right side (drivers side) of the engine compartment). Loosen it, i believe its a 19 mm bolt - you'll need a long ratchet extension to get to it-
remove the fluid via the drain bolt under the transmission (its sideways facing, if i remember correctly) and also about 19mm) - drain. Replace the drain bolt using the new drain bolt gasket.
you'll need a long narrow funnel to get to the fill hole. there are a lot of tubes and cables and wires to get around/through to get the oil to fill hole - i actually used two smaller narrow funnels stacked to get in there. I believe you use around 3.5 qts of fluid to refill - but again, check with the dealer for refill quantity. make sure all bolts are in their place.
if you want to flush the system - drive the first oil change around until the oil is hot and repeat the procedure.
if you can get the oil change for $35 bucks, it is probably worth it since the tran oil is going to be around $16 alone - if not more. just make sure they use Honda tran fluid. (this is why i do myself in the first place - i don't trust repair shops that much and i don't like my local honda dealer)
once you figure the logistics out, it is actually easier than an engine oil change - no filters, no transmission oil pans and/or gaskets.
its been a while, so i'm not a 100% on quantities and bolt sizes - i'll let you check that out - but the procedure is simple enough.
have fun
http://www.handaccessories.com/odyssey01.html
Pick CD player and select the one you have. You can then download the instructions.
http://www.handa-accessories.com/odyssey/odytrailerhitch.pdf
Steve
The new mirror was $188 + tax, in a box. It went on with three nuts, from inside the car. You just need to pull off a little pannel on the inside of the door, its about a 5 minute job.
What I thought was great was that when you buy them from Honda, they are already painted. You just give them your paint code when you order it. It sure makes it less costly to deal with. Thanks Honda for that one!
I am new to this forum.
My 2004 Odyssey starts to show up a problem with its washer fluid level warning. It stayed ON no matter how much I top up the washer fluid.
1) I tried to disconnect the battery for about 1/2 hr to see if it is reset. It doesn't work.
2) The pume seems OK because it sprays well.
3) Is it a bad level sensor? OR does it need to be cleaned?
If I want to disconnect, what are the steps that I have to follow. Please kindly describe in detail for a rookie.
Thank you,
1.Disconnect the 2P connector (at the bottom of the tank) from the Washer Fluid Level Switch
2. Remove the Washer Fluid Level Switch from the bottom of the tank (washer reservoir)
3. Check for continuity between the 2-termianls of the Switch;
Note:There Should be Continuity when the float is down.
There should be No Continuity when the float is up.
4. If continuity is not as specified, replace the switch.
Sorry, I am not sure if the float/contact can be cleaned or not... Or, if the float is just all soaked and sink to the bottom of the tank all the time. I suppose if the the float floats and if you can clean the contacts, it will most likely be corroded again soon. Some time those Blue/Green washer fluids can really cause some major build-up in a tank. Good Luck!
The weather forecast next a few days is "Raining" and hopefully this coming weekend, I could explore into it. I will update once it is done.
Rgds,
Do I have to get a special tool for this or any tips? If possible, photos would be helpful.
Thank you,
My Wife went in to do an oil change at the dealer and was told that she needed a service (this will be the first one adn ti is around 10k miles).
What is the service and where can I get a list of services and what is involved in case I chose to do some of them myself.
Just think of it like leaveing a window open on your house. If you need to use a password then think of it like leaving a key under the mat.
Help!
