Forester roof racks/kayak carrier
I'm trying to determine what kayak carrier will work satisfactorily with my 2005 Forester.
The accessory rack OEM from Subaru is quite affordable but both the specs for the attachments and a good photo of the carrier are sadly lacking on the Subaru parts page. (photo larger than a postage stamp when printed woudl be good).
Just wondering if a Subaru owner could comment on the using the carrier offered by Subaru and if you HAVE TO GET THE SQUARE CROSS BARS TO HAVE THE 150LB CARRYING CAPACITY WITH A KAYAK, why can't subie give us better specs on the parts page shown here:
http://www.subaruparts.com/catalog/?section=513
Any actual experiences with the rack attachments would be appreciated.
The OE cross bars can handle 150lbs, and Subaru sells clamps that mate up with Yakima accessories, I think they were $7 each way back when, when I looked years ago.
That's surely cheaper than buying new cross bars. Good luck.
-juice
For 2007, it looks like Subaru is now offering a type of J cradle as the kayak carrier. This is an easier kind of carrier to use, and as the kayaks are carried nearly upright, you can fit 2 on the crossbars and carry 2 boats. Both Yakima and Thule offer similar products, as do other manufacturers. As with any system, the boats should be tied down at both ends, but this is especially important with J cradles.
We used the Yakima kayak stacker for a couple of years on our 2002 Forester, but then switched to a system from Yakima using saddles. We did have to buy the Yakima mounts and longer crossbars in order to carry two boats, but it is much easier to use.
There are lots of choices out there depending upon how many boats you want to carry and your budget (foam blocks are inexpensive yet work well directly on the crossbars for one boat).
Larry
The picture they show kind of looks liek a cradle mount. Perhaps I'll just go with the foam blocks on the cross rails since I'm just going to carry one at first.
I do use the tow hooks on my Outback - there's three of them near three of the wheels. I've never had a problem having the boat painters tied off at an angle to the boat.
I wouldn't trust the plastic grill unless you can find some metal support hiding behind it.
I have some unused Subaru Bucks that I can use for the purchase.
Ron W.
Maybe I could get the specs somewhere?
Ron
Maybe directly from your Subaru Dealer? :P
Also picked up the Yakima 6 pair ski rack, $100, but that will require "mighty-mounts". The Yakima site was a little ambiguous on that, might have been a model change, but th supplied hardware is only round or square, not factory "aero".
Lots of boaters don't but racks/straps/ropes can fail. Then you have a nice flying projectile. Just takes a minute to add a "fail-safe." link
I got a new Dagger Rival a couple of weeks ago to add to my quiver. :shades:
SUVs & Speed Shop
I want to buy a kayak and need a roof rack for my 2006 Forester. I have a factory rack on the car, just the basic rack, nothing fancy.
Will the Yakima "HullRaiser Aero mentioned earlier work, or do I have to buy crossbars.
Thanks for your help. Forgive my ignorance.
Even my old '98 Forester had these handles at the front and back that worked as tie-downs.
In your case, I would tie a loop on one end, then go around the cross bar and pull the rope through the loop. It's self-tightening - the harder you pull, the tighter it gets.
Maybe some boy scouts here can offer more specific advice? I used bungees, as well, to take up any slack and things shifted.
