Welcome to the Edmunds forums! We are changing the way you sign into our forums. Click here to learn more.
Pontiac GTO Reliability and Maintenance Costs
2»
  • roadrunner70roadrunner70 Posts: 241
    does anyone know more about the gas cap recall? thanks rr70
  • eliaselias Posts: 2,176
    if yours busts, a pontiac dealer can give you a new one in a jiffy - i think the letter said at least until 100k. i bet they will go beyond that. probably faster to buy the stant/whatever replacement at an auto parts store, but won't be free. i drove for a month before i noticed my gas cap was not holding pressure whatsoever. worst mpg ever. with the vertical filler neck, it's almost impossible to splash gas out if you keep the shiny side up - but when the cap breaks, the evaporative losses are considerable.
  • Hey -
    I have an 06 GTO as well and am having the same kind of problem you were experiencing when you wrote this. Did you have any luck fixing the problem? Any suggestions for me? Thanks.
  • I found a brand new '06 on a dealer lot in July '07 and promptly bought it. The car now has 8600 mechanically flawless miles on it. I'm considering the 490hp Bobcat package from SLP, but this also raises some concerns for me being that I'm completely not a gearhead.
    This mod involves swapping out heads, pushrods, and rocker arms. I'm pretty sure that voids the warranty and I'm sure will cause lots of problems if not done carefully and correctly. Is anybody here familiar with SLP and, specifically, the Bobcat packages? Will SLP also install these parts? Does SLP pick up the portion of warranty that is voided by the installation of the mod?
    I plan on calling SLP direct and asking these same questions, but I thought I'd ask here to get feedback from folks who are living with this mod.
    I appreciate any responses.
  • hippehippe Posts: 14
    Why not just bolt on a supercharger. The internals will hold up to it, certainly up to 500hp, and your mileage might actually improve.
  • mparis1mparis1 Posts: 107
    Got my replacement letter this Sept. 2008....replace ment for 10 years or 120,00 miles. you have to hear the "rachet" sound when closing...just close lightly...do not push down....I have no problem...25,00 miles
  • I have a 2005 GTO. Can someone tell me where the interior fuse box is and I how I get to it? My owners manual says it is on the drivers side below the instrument panel. I can't find it. It must be hiding.
    above your left knee/thigh as you drive - the standard/old-school USA-car position. the panel/rocker under steering wheel hinges at the back.
    three pressure-latch-connector things attach it near
    the front. it's really a very solid setup, but i already broke one of the latch/connector things on mine, so don't be a doofus like me and pound on it trying to get it to re-latch.
    you can pry it open gently, just keep applying more force gently down at the seam/gap directly facing driver, and the panel will pop open.
    btw on mine i found a 20A fuse inserted for the USA-absent-cig-lighter, conveniently available for replacing the burnt fuse for accessory/center-console. :)
  • please change the ( COOLANT TEMP SENSOR ) THAT WILL FIX THE PROBLEM.
    Hello Elias ....nice to see you again.....wonder how is GTO Robert doing?
    Can you advise me? Or other members?
    Question----Engine Service Lite came on---26500miles-----possible oxy. sensors ???
    Can I still drive around?
    What Service should I have done? coolant,plugs, filters????
    Thanks Guys :shades:
    hey there mparis1...
    GTO Robert's ls1gto/ls2gto web site seems to be doing fine!
    Let's hear it for $1.53 gasoline! Woo Hoo!
    26500 is way early for an O2 sensor to go.
    Is your gas cap loose-goosy? If yes, you can probably get a free pontiac replacement at a dealership with a quick unscheduled stop like I did.
    Pontiac has sent letters extended the warranty on the GTO gas cap twice so far.
    Just informed my Pontiac Dealer, largest one in brooklyn,ny ,BRUNO PONTIAC, is closing this month....NO GTO service guys left in Brooklyn. Do any of you fellows recommend a place for service in the NYC area? :cry: :cry:
  • I have a 2005 Pontiac GTO with 70,000 miles on it. Only problems I have had are tire issues which I have seen are due to struts now and my car eating batteries. But other then that it has been a great car! But here's my problem now. Back in February I was sitting in traffic and then my car said it was overheating so I pulled over. No smell of overflow like you smell when a car overheats. Sat there for a bit and then proceeded to drive 50 miles home with no other problems. It's not late August and it did again twice and both times I waited a bit and drove it home. No problem. All the times it happened I was sitting still and idling. I replaced the thermostat and while idling from a very cold start (overnight) it sat half way for a few then the temp gauge started to move. The fan kicked on and stayed high a little and then moved again and then it sounded like a bigger fan kicked on and it stayed a few and then moved up. I had some sensing the heat of the engine. The manifolds where about 240 but the rest of the engine including by the thermostate was only 130 degrees. Again no smell of over heating. I also have had no loss of water/coolant either. Any suggestions?
    hey there coach.
    my 05 gto also has 70k miles - just got a new battery and trans-fluid swap after giving symptoms of clutch not totally disengaging the gears.
    for your car, sounds like the two cooling fans are operating normally.
    maybe the temperature-sensor is malfunctioning and reporting overheat when there is no overheat? presumably you are talking about the analog temperature gauge as the one which indicated overheat.
    fwiw, if you turn on the A/C that should make both cooling fans run all the time, helping to cool the engine!
    possibly check ls2gto.com also - lots of knowledgeable folks there...
    please do let us know if anything interesting is discovered.
    cheers...
  • dear eilias,
    what battery did you get. my understanding is that the group 85 battery is only available from GM.
    RR70
    hi roadrunner. i got a battery at NTB and do not recall its details currently. there are oddities with the battery spec - some battery shops will claim they don't have a matching battery. but they really do - once they see the battery they should say - oh we have an exact match for that (even though it won't be properly in their database!)
    not sure i recall all the details. iirc, "type 34 fits" is one answer , and you should not have to cross-over the +/- cables - should be an exact fit. ls2gto/ls1gto web site has plenty of battery discussion/advice to help you.
  • thanks for the tips on the battery. rr70
  • your right, lots of battery discussions. group35 is the drop in size. thanks, rr70
  • mick1mick1 Posts: 84
    edited December 2012
    2004 GTO PBM is 8 years old and is down for another winter. Still going strong. Who else remembers their buying experience the end of 2004.
    2005 M6 CGM is 7.5 years old.. still strong @ 103k with pedders suspension & ice-bear tires for winter-running this year. Longest I've ever kept a car, by far...
    I do remember the 2005 buying experience, sure does seem a while ago.
  • kokozkakokozka Posts: 1
    2006 M6 now 96.000 km owned for 5 years (46.000km). Leaking front struts, collapsed rear springs, radial rod bushnigs and strut mounts, driveshaft, axles, clutch, clutch master cylinder, wraped brake rotors. In stock form this car cant handle sporty driving and is so soft with lot of wheel hop. Lot of parts have to be changed for performance parts to avoid poor design and quality of factory parts. Paper quality drivetrain from clutch to differential. Only engine and interior makes this car interesting in this price range... In future i have to replace slowly dying steering rack and LSD... im so happy :D My mods: monster clutch level 2, one piece aluminium driveshaft, urethane bushings, KYB shocks, Lovells springs, long tube headers, kn cai, ecu tune, 18 wheels.
2»
