My PocketDock came over the holidays. It is a solidly made, compact device. It works exactly as advertised and the sound is great. I experienced no noise or interference. You control the volume with the Civic's controls - either the regular knob or the volume control on the steering wheel. To control the other iPod functions (skip, menu, etc.) you must use the iPod itself. One quirk, while your iPod is connected to the car, it remains powered on at all times even when the car is off.
This solution works perfectly for me - a good mix of function and cost.
Dan
Questions:
1) Can I unhook the XM sat antenna from the back of the navi? If so, how do I get to it?
2) If answer to 1 is yes, will the antenna connector work on my Sirius unit? (ie, is it a standard connector?)
Any help would be greatly appreciated!
example - If I have the following artists loaded on my iPod -
The Beatles
Bona Fide
Buddy Guy
The iPod puts them in that order. The TTS software from Honda counts 'The Beatles' as a 'T' artist, instead of a 'B'. So, when the system lists off the 'B' artists, if I select 'Bona Fide', I get 'The Beatles'.
The same applies to album names (for instance, 'The City' is under 'C' for the iPod, but under 'T' for the Honda TTS software).
Definitely needs some work.
The second method is to buy the musiclink cable from Honda. This costs around $399. It routes the cable from the back of the stereo to the glove box. You put the iPod in the glove box, and the cable connects to the port on the iPod (not the headphone jack). When you use this method you can control the music being played by a combination of the controls on the radio, and on the steering wheel.
More information is available about this at link title. There are some problems with this setup, mainly due to bugs in the software controlling the iPod. This software is called 'Honda TTS'.
On the plus side, the iPod charges itself and you can select the music without taking your eyes off the road. On the negative side is the cost (obviously), and the bugs that still are in the software.
I should have mentioned that the musiclink also works only with 4th generation iPods, iPod mini, and iPod nano.
-1/8" male-to-male audio cable (available at Radio Shack or the like)
-An MP3 player or some other device w/ a headphone jack
Plug one end of the audio cable into the the headphone jack on your player and plug the other end into the Aux jack next to your cigarette adapter. Play your music, choose Aux from your car's radio, and away you go.
You might also try burning them at a lower speed.
What volume levels to others use for playback ?
Robert
The input device has a dropping resistor inside the headphone jack to drop the volume somewhat when using headphones. This is common and gives you a bit more adjustment range when using headphones with the device. However it does give you the problem you describe.
There really isn't anything you can do about it, unless your device has a "line out" jack (which does not have the dropping resistor).
Make sure your cord is not an "attenuating" cord, as these have their own resistor in them, which would double the drop in volume.
I will check to make sure the cable has no attenuation. I was thinking maybe there was a setting on the Civic radio that could adjust the sensitivity. Sounds like it is working as designed.
Thanks again.
Hope this helps!!! Love my Civic, my personal spaceship!!!!
tomjogden, "Honda Civic Sedan 2006" #3965, 18 May 2006 9:25 am#3964
Someone replied that this was a known problem, and the dealers would know how to fix it. I'm at the dealer now, and they seem baffled. Has anyone else hit this problem? If so, and you had it fixed at a dealer, what did they list as the fix (on the repair order)?
Noticeable Ticking Through Audio System Speakers
The intake manifold tuning valve (IMT) in a '06 Civic can cause a noticeable ticking through the audio system speakers. You'll hear it with the ignition switch turned to ON (II) whether or not the engine is running. And you'll really hear it if you're tuned to lower-frequency FM stations. To fix this problem, use the HDS with 2.004.004 or later software to update the ECM/PCM.
The fix was covered under warranty, and took about an hour. I got a free bagel and coffee for my trouble.
For example, when I use my iPod, my bass sounds weak and the highs sound slightly more prominent. I didn't notice it until I turned back to the FM radio and the music was booming from where I had to set the audio settings for my iPod.
If your player has a "Line out" jack, this gives you an unadjusted signal.
or....If you can preset a particular environment on your iPod that is suitable for when plugged into your car it will help you fix it quickly without having to manually readjust all the setting each time you switch between using the IPod with headphones and in the car.
I have a Creative MP3 player and I have a different preset environment for in the car vs headphones.
Artist-Album Name-Track #-Song Name.mp3
So for, let's say Rush's new Snakes & Arrows first song Far Cry, it would be:
Rush-Snakes & Arrows-01-Far Cry.mp3 (this file is saved in Folder Snakes & Arrows)
The files each have the proper information in their properties on the PC as well (i.e. Artist, Album Title, Track Number, Title).
When I put the disc into the stereo, it seems to put the tracks in a random order and I have no idea what the logic is. In my example, Far Cry is being listed as track 04 instead of 01. This makes it impossible to play an album or song list in proper order, which is especially frustrating for live albums.
I'm just wondering if anyone knows how this works and/or how to get everything in the desired order.
So I still don't get it. I really which there was an in-depth explanation somewhere.
If your XM unit has a headphone (or line out) stereo jack, it will work.
One thing that has been mentioned is about the volume setting. The Sirius radio has a volume control in the menu. I'm guessing the Roady does as well. Make sure you turn it all the way up.
if you have an EX or Si, all you need is a cable with a 1/8" stereo mini plug (male) on both ends. Radio Shack has them (and best buy, etc).
Parts and Installation is a little over 500.00.
Does anyone know if this is true as the parts places are closed now at the moment and maybe they are installing aftermarket or maybe just wrong or lying.
Integrated xm would be easier and safer to use.
I need help soon as I was hoping to buy this weekend.
Ken
Unfortunately my parts and service dept are closed so I cannot give you their opinions on installing XM on an Civic LX. The sales managers I have asked all agree it can be installed on any vehicle you like.
"XM ready" means that the wiring harness attachment is pre-installed. All you have to add is the tuner and antenna to an XM ready vehicle to receive XM.
For the LX you have to buy the attachment seperately.
It sounds like it could be true.
I checked on installing the Honda version XM brain on my 07 EX. It just seemed like too many dimes and not enough sugar. I downloaded the installation instructions and basically the entire dash had to come out of the car. Also, the antenna was to be mounted on the windshield next to the right A-pillar - not acceptable.
I opted to install a Sirius plug and play in my car. I got the antenna professionally installed (mounted it on the trunk lid), the rest was elementary. I use the AUX input and it works great. Best of all I got it all done for a fraction of the cost.
Right now you can get a Roady XT (XM) for under $40 after rebate. Sirius has comparable prices. Even if you pay someone to install it you will still have less than $100 tied up in a satellite radio, AND you can move it from vehicle to vehicle or get a home kit and use it inside.
I looked at the instructions too and I definitely value the integrity of my dash or to say it simpler, I hate rattles. And installing it may cause some. I wasn't to bothered by the antenna placement though.
Also after listening now to my cars stereo, I'm not to impressed with it on the LX.
But I already have a skyfiII and will try that as some of the places to hold things should hold the skyfiII pretty well and neatly without wires showing.
It was more of a safety issue for me as the portable units are not that easy (at least for me) to operate and drive safely at the same time.
I'm 47 now and have to admit my reaction times aren't what they used to be.
Thanks for the info.
I didn't want to buy multiple car kits, so I mounted the Sirius Stratus radio using self sticking heavy duty velcro on the mounting bracket and attached it to the underside of the dash right above the power outlet. When I take it out of the car you cannot even see the velcro strip. One other word of advice: If you decide to use velcro or even the self-sticking tape on many of the mounting brackets, be sure you let the glue set up for the recommended 24 hours before you attach the radio. Otherwise it will pull away from the dash and/or mounting bracket, especially in hot weather.
Good luck!
Joe
Rush-Snakes & Arrows-01-Far Cry.mp3 will not necessarily be read before Rush-Snakes & Arrows-02-Armor and Sword.mp3.
But if I name the files as follows, it will work:
01-Rush-Snakes & Arrows-Far Cry.mp3
02-Rush-Snakes & Arrows-Armor and Sword.mp3
So you could do a folder for each album to keep it organized. Or you could make any playlist and start the file names with the order you want the tracks listed.
It's a bit of a pain at times, but at least I can make it work now. Time to re-burn that Rush archive.
Looking into buying a new car, my FIRST NEW Car and currently a Honda Civic is my top choice, followed by a Corolla. If I go with a Civic, I'm going to get an EX Model for sure, with possibly the Navigation. I'm not quite sure it's worth it though, as it seems to add over $2000.
What I am curious about is with the Navigation option, and also for the option without it and just a standard CD player, where is the AUX jack for an iPod or MP3 player located? I really want to find this out. Is the plug durable? I ask because I wore out a plug on an aftermarket radio from daily plug/unplugging and just want to make sure it's going to last, as replacing the stock Honda radio seems like it will be very difficult.
If I didn't have the streets/trips...I'd have a Nuvi as my cousin travels with one all the time. Just pops it in her purse.
