Honda CR-V Winter Driving
What kind of tires come on the CRV?
Does it go good in the snow?
VSC keeps you going where you point the car in the snow. And AWD makes it easier to get out of snow drifts if you happen to be plowed in or what not.
I'd venture to say that FWD with traction control would be sufficient for most drivers in winter, particularly since the CR-V's high GC keeps you out of most drifts. However, since the AWD can be had at a very reasonable price, why do without?
I suspect the lower 2007 model may be less of a Winter Warrior, but that remains to be seen.
FWIW, I have driven in snow with the Honda Odyssey, which had the traction control. It worked OK, but I had to go really slow.
However, I preferred the RT4WD in the CR-V. I still went at a reasonable speed.
But I have been in mud with the RT4WD and would not have made it out with FWD.
Sounds like it is worth getting the RT4WD.
I live in Northeast Ohio and I'm sure I would make use of it.
I've never owned any type of AWD or 4WD vehicle before, which leads me to another question. Is there any major extra expense involved with maintenance of the RT4WD CR-V? Is it a reliable system?
The system itself is a proven system that first appeared on the 1987 Honda Civic Wagon AWD. Now in its modified form it is on the CR-V.
The only additional maintenance is the dual pump fluid replacement. Honda says 60,000 miles is OK, field says it needs to be replaced around 20,000 miles, depending on how much AWD you use and how deep you ford the rivers :-)
I've never owned any type of AWD or 4WD vehicle before, which leads me to another question. Is there any major extra expense involved with maintenance of the RT4WD CR-V? Is it a reliable system?"
On the 2006 and earlier it is a simple mechanical device that works with a hydraulic clutch. (I don't know what the 2007 will use). It is very reliable. The book says change the rear differential fluid at 60K, but I changed mine at 30K. That is the only expense, other than the weight penalty. It gets about 1 MPG less than an FWD.
So...my question is has anyone actually used "link type" CHAINS on their CR-V without damage or had experience with this issue?
To demonstrate this for yourself, get a link of any size chain, stand over a piece of sheet metal, such as what cars are built from, and whip the chain down on it. Repeatedly. :P
It can happen, has happened to me. Chains are on, links break, and the chain is now a giant whip, loose and slamming into the car, underside, rear and sides, like a giant whip.
Newer, plastic-types are more forgiving on auto bodies, and easier to install, with Nylon cord holding them together. clipping to the sides, rather than having to get down on your hands and knees, on your back, to install when there is a blizzard outside, on the side of Highway 50 or I-80.
It simply depends on how often you will use them, and if you had the foresight to buy a AWD model, where you can sometimes be allowed through without chains.
I agree a broken link would be diastrous, but that is not what the issue is in this case. It is the clearance, I believe.
I would ask ole Les to take them back, and you go buy the clip-ons.
I was hoping that maybe someone had actually used chains on a CRV and could speak from experience.
It is AWD. Maybe chains aren't necessary.
swvsings
I have also used it for some light off road driving on muddy unpaved farm roads and while camping.
FWD with traction control will only get you so far.
I have driven both FWD and AWD and the AWD is much better in the snow.
Considering a 2007 Honda CRV or Rav4 and not sure if I should go with the AWD or FWD with traction control. The AWD has a little extra weight and slightly lower gas mileage. I don't do off roading.
Anyone have any input to help me with my decision.
Tks,
