any ideas? have not pulled pan yet.
thanks!
P0841 Trans Fluid Press Sens/Switch A Circ Range/Perf
P0846 Trans Fluid Press Sens/Switch B Circ Range/Perf
P0871 Trans Fluid Press Sens/Switch C Circ Range/Perf
P0988 Trans Fluid Press Sens/Switch E Circ Range/Perf
P0876 Trans Fluid Press Sens/Switch D Circ Range/Perf
P0750 Shift Solenoid A
I tried everything the only thing that fixed it was a computer
got one from a wrecking yard
Was going to pull pan and check filters or screens etc. ????
Ideas??
Even though you may not have a Check Engine light, also check for trouble codes.
kcram - Pickups/Wagons Host
I have a fairly extensive mechanical background on heavy equipment, just never messed with auto transmissions. I did yesterday drop the pan, replace the screen. and re add aprox 8 quarts of fluid. There were no chunk of debris, but the magnet did hold close to 1/8" of smudge on it. cleaned and reassembled, it once again on short runs appears better.
I am not sure how to check trouble codes if it happens again, and there are no warning lights being activated. The truck has over 140,000 on it, and has been used for some heavy pulling (trailer with bobcat equipment on it etc)..
Thanks again, very much appreciated. as you know most shops want the $3,000.00 to overhaul something that could be a easy fix.
