please help
I'm thinking it might be the tranny cooler in the front of the truck. Maybe it's clogged up slowing up the flow of the fluid. That could explain why the winter time is alot worse because maybe because of a thin flow, it actually cools the tranny fluid way to low. What do you think. I know they make a tranny line flush in a can for about 10 bucks. Does your truck get worse in the winter and better in the summer?
I took it around the block and it wouldn't start in low gear. This transmission was flawless before I dropped the pan for service.
Anyone have any answers for me? Out of all the searching I decided to order a new governor pressure solenoid and sensor. Then I found this site. Parts have not been installed yet.
Truck is an '02 QC with 5.9L and 101,000 on it.
Has anyone else encountered this issue and if so, how did you resolve it?
47re transmission. I have 2 issues: 1st is after truck sits, drop it in gear...., wont move. after several seconds, slowly will pull off.
my thoughts on this is the anti-drain valve for the pump...?
then, 2nd issue. part throttle cruise 35-45 mph light throttle pressure, trans shifts in and out.. (of overdrive?)...this has gotten worse as time has gone by... when it first started a friend at a trans shop replaced the throttle position sensor. I dont think this changed a thing...,but i didnt notice it as much/bad.
I have serviced the transmission regularly and used dodge filter and plus 3 fluid.
I am an ASE certified master mechanic....also smart enough to know when something is above my head. I dont have an appropriate scan tool, so it's like shooting in the dark.
additionally....no trouble code lights on the dash.
When above 55 mph everything seems fine..., and if you push hard on accelerator, seems to go up thru the gears ok...
I would appreciate any helpful ideas on these problems.
Corkscrew
1 - governor pressure solenoid, sensor
2 - throttle position cable
3 - shift linkage
4 - Trans relay in distribution box under hood
5 - bad connections in harness to pcm , transmission
6 - bad PCM - powertrain control module on firewall passenger side
7 - fluid burnt, too high , too low (check with truck running in neutral)
8 - Bands need adjusting
9 - fluid filter clogged
10 - valve body malfunction
Dieseltrans.com has a tps noise filter if it is the alt noise problem...seem to be real nice folks...lotsa good stuff 4 our trucks !...good luck...keep in touch..
How many miles on the vehicle?
Does 1st gear seem solid? Does it slip in first?
Do you have reverse?
Dusty
However, the anti-drain back valves on Dodge older trucks are prone to clogging and if the system has a lot of clutch material floating around, and they can sometimes stick open. The cooling lines could be clogged, too. If the transmission is due for a service (every 25K on a 47RE), then maybe a filter change will solve your problem. Delayed engagement is typically due to either low pump pressure or a torque converter that's drained over night. On Mopars, low pump pressures are usually caused by leaky seals, less often caused by a worn pump. Torque converter draining can be caused by a anti-drain back valve stuck open or bad seals.
The shifting problem is quite often caused by a sticking Throttle Valve Cable that goes from the engine throttlebody to the transmission, or one that's out of adjustment. Check the terminals in the electrical connector that goes to the transmission for signs of moisture and/or corrosion. Keep these connections clean!
Don't forget that engine tune can also affect this problem.
Best regards,
Dusty
Check the electrical ground path from the transmission to the engine, and the transmission to vehicle frame. There should be zero resistance (ohms).
Remove the electrical connector at the transmission and check for signs of moisture or corrosion. Clean as required.
Dusty
There are a number of things that could cause this problem, including low hydraulic pressure, a dirty or worn valvebody, a transmission electrical problem, or a stuck servo. My first suspect would be a problem with the Governor Pressure Sensor, Governor Pressure Solenoid, or a problem in the governor electrical circuit. A common problem on older Dodges (especially those that may have sat for a while) is moisture and corrosion in the electrical connector to the transmission.
I would recommend taking this vehicle to a Dodge techniciam and have them diagnosis the problem with the DRB3 scan tool.
Dusty
*delayed 2-3 upshift
*delayed 3-4 upshift
*3rd gear FEMCC (fully modulated converter clutch) from 30-40 MPH
*3rd gear PEMCC (partially modulated converter clutch) above 35 MPH
*Above 25 MPH the torque converter will not unlock unless the throttle is closed or if a wide open throttle, 2nd gear PEMCC to 1 kickdown is made.
Dusty
Any help would be greatly appriciated !!
kdhag@gvtel.com
Thanks!!!
Big Joe
the mechanic change the torque converter keep doing same thing then i overhaul the transmission keep doing same thing some time when i disconnect the alternator plug stop doing (sometimes) now no more keep jumping 3 to 2
The truck start doing that in 45 to 55 mph now no matter the speed keep doing the same crap.
II have a long trip to work 55 miles up and down
I'm tire of that any help? suggestion?
Thnx in advance.
now fighting for repairs again! could be just my truck and good luck with yours. happy birthday to your truck!
between the tach rpms dropping and feeling the tranny engage. This happens during the first two shifts at normal driving speeds, but when I really get on it I don't notice it, or when I disengage the overdrive it shifts normally. Could this be a major problem or is this a sensor going bad? My dealer says that this is normal, is it?
I think he is trying to save me $400 on a new fuse box but by time he is done I may have that in there already.
Any thoughts would be appreciated. Ironic that this failure happened when it did.
Thanks :confuse:
