Frank
09 Versa sedan MT-6 34.5 MPG average over 5800 miles
I made the dealer give me two extra keys, also programmed, for a total of four programmed keys and two programmed remotes.
They all have to be together and programmed at the same time, to make them all the same.
After learning about the keys, I knew more about them than the dealer technicians, and had to teach them how they work, and when they aren't supposed to work.
dog and we need more space.
Dave Proe
I would definitely consider the Versa for a economical,, basic transportation rig (preferably as a hatchback). My main concern is would be that it seems to have developed a unreliable reputation.
a noise like the air is restricted from comming out, this can range from total failure
to partial failure, It seems like shutting it off and letting it sit for awhile might be the ticket.. But I am looking for a fix if anyone know what is going on please give a shout. it restrict the air flow from the defrost vent and at the bottom when you turn it on the heat. There must be a fault part, the part that switches the vent to be wide open instead of closed, had a little problem like this on my montana van, would not
open all the way for vent, but thats another story, thanks fro your help in advance.
2007 nissan versa, thanks
When we bought our 2007 Versa, it was February. We didn't discover until the weather got warm enough that there was a leak in the AC system and it wasn't cooling. Dealer fixed it, no problem. Haven't had any issues with our 2010 at all.
Our seems to have this problem sometimes at road speeds whether cold or warm.
2800 km. Would it improve as engine breaks in?
New car, new noises to get used to!
It seems lubrication is hit and miss to create such conditions.
Get ready to litigate later.
If you can find 09 documentation on the web(specs and accessory list) it may mention if two keys and remotes come as standard equipment.
Sounds good now.
I had a friend suggest that factory or dealer gas in the tank could be stale and form gum deposits.
I really wish the seat was lower, but i had to have the manual shift.
Has anyone had a similar experience? Or did I get Nissan's only "Monday morning" car?
