Ford Escape Hybrid Brake Problems
13
    dsteakdsteak Member Posts: 18
    this was an on-going problem for me from (see previous posts), and when they finally sent an engineer to my dealer to take care of it, it stopped happening for 1.5 years. however, the last 2 times i took my car in for servicing (tune-up, etc.), the problem recurred a few times right after servicing, and then not happen again. since my dealer went under, i'm taking it to a new one so i'll try and get some resolution in the future from then, maybe perform the same maintenance the other dealer did when they "fixed" it.
    maximus12maximus12 Member Posts: 1
    I have an '08 (bought in '07) - master cylinder completely failed after 750 miles - was replaced and no problems for almost 1.5 years, but I have periodically heard metallic sounds coming from the brakes. At first it would happen when coming out of the mountains or immediately afterward while the brakes were still hot (sounded like sand in the brakes ~16k miles) but went away and didn't repeat. Left the car to sit for ~2 months and noticed a little tarnish (could have been rust) on the exposed brake surface. Started driving again (tarnish vanished, ~20k miles) and after a month or so metallic noise (like the crappy brakes on my '93 camry) started intermittently happening sometimes when I brake and sometimes when I am just going slowly or turning (car doesn't have to be hot, 20.5kmi). Very loud sound. Wasn't repeating when I dropped it in the shop.
    2 questions. 1) Are brakes supposed to rust? The old Camry's never did. 2) Anyone worked on this problem or experienced it? Any advice?
    marcuscrvmarcuscrv Member Posts: 4
    I just bought a 2006 FEH 2WD with 45,000 miles on it. When I got the car, it made a light whistling sound when applying the brakes and sometimes when the car is in electric mode and you are driving. I was looking over this forum and I have seen people with a similar complaint. The car is certified pre owned for 100k but it is only the powertran. Right now I have 25 days till the premium part of the plain runs out so I like to get it checked out and I do not want to spend the first 100 dollars again for the dealer to tell me that it is normal when it is not. From looking over your forum I tried braking in neutral and I do not get the whistle so I believe it is something in the regen braking system. The service manager tells me everyone has a low whistle and I am probably hearing the pumps. Any opinions wouls help, thanks Marc
    jurdeanjurdean Member Posts: 9
    Marc,
    I am the original owner of a 2006 Escape with now 16,000 miles driven. From the onset, I've noticed a low whistle noise when driving - coming from the front of the vehicle. I kinda thought it was the brakes. What the service manager is telling you sounds right.
    Whether this condition is normal is for this forum to reply back.
    I'm still in the warranty period .
    Here's one for you. How do you like the ride with your Escape. I 'm keeping the tire pressure at 32 psi. Feels harsh to me when driving what I thought was like a "car" suspension. Maybe the shocks need replacement. Unless this is "normal".
    Ed
    The car drives like a truck. I had a Honda CRV with 200K with the original shocks and it was less bumpy. However I keep the regular 35 psi in all 4 tires. The whistle sound drives me nuts.
    Marc
    i complained to ford (go to website and contact service through them). they sent a technician out from detroit (supposedly) and he fixed the constant problem. since then, it only happens once or twice after i service the vehicle and then it stops. that's not a resolution really, but it's better. but i was still under warranty at the time, i'm not anymore.
    every time i hit the brakes, i wonder though. and i always think that warning light is going to come on. not much confidence to have in a $30K+ car, sadly. i have considered trading it in.
    scalabilitydabscalabilitydab Member Posts: 4
    The saga continues... :mad: :mad: :lemon: 2 weeks ago ABS light/service brake system message and brakes go mostly to the floor. Dealer finds codes 1524/1526 and replaces master cylinder ($1700). One week after repair same issue. Different dealer finds different code (they won't show me) indicating some ground harness. Because it's a different repair they won't honor the repair warranty from the other dealer. I referenced a recall notice regarding ABS module and they indicate I don't fall under the recall because it doesn't mention "hybrid" only regular Escapes. I am filing complaints with the BBB and the NHTSA and will NEVER buy another Ford. FYI...in 1989 I bought an Escort. In the first year with 15K miles the timing belt broke. Ford would not honor that as a warranty repair stating "The warranty only covers internally lubricated parts that are NOT designed for failure and that the timing belt is DESIGNED to fail". That may be, but not in 1 year or < 20K miles.
    I remember a recall on my 2006 Ford Escape Hybrid dealing with Traction Battery harness - 07B48. Probably nothing to do w/ the brakes. You probably had the recall done.
    Anyway - in the time I've had this Escape - I got 3 service brake messages, while driving - there would be a "beep" and then this message would show up on the instrument panel. I would find a place off roadway to stop - shut off the vehicle and the message would go away. Then continue my trip. It wouldn't happen again. It's now been over 6 months since happening. No problems. Obviously there was some "short. I called the dealer. They told me to make an appointment for all day to check out. I don't have all day to have the Escape "looked" at. Never been to the dealer. Probably will happen again after the warranty period.
    Following the tire pressure placard on door- noticed that my Escape rides "rough". I think it's the shocks. Is it possible that the shocks were set up with lower tire pressures at the factory.
    I do not expect a "car-like" ride w/ this vehicle but these SUV's - Escape to me included - should ride like a car. At least when I took the test drive.
    Well - maybe I should think "truck" suspension here.
    Is it a tradeoff here - to get better gas mileage - you have to keep the tires at 36 PSI.
    I have never received a recall notice for my vehicle. IN fact, when I mentioned several recall notices regarding this issue I was told it "doesn't apply to your vehicle because they doesn't specifically mention hybrids". My problem with pulling over and stopping the car is that I have a 3,000 foot elevation drop between my house and my office with several 10% grade areas with no shoulder. It's not a safe area to be driving and have brakes fail. And when this does occur, I have about 10% of my normal braking capability (and that's probably on the lenient side). Anyway, got the car back yesterday and drove from Denver to Dallas. No problems so far...
    wilcoxwilcox Member Posts: 582
    Have been reading about brake issues on Mariner and FEH's AWD's. Thanks for your concerns and advice.
    Our Mariner has a tad over 47k miles. This week there have been two occasions at startup when "service brake..." message flashed and vehicle would not start. It also made some weird noises in operation at an intersection.
    I have the camera close by and the next time it gives me a warning...I'll take a picture of the message/code.
    If the dealer tells me some baloney about there's nothing wrong,,,using the ' doubting Thomas bit'...then, when he or she is finished blabbering, then I'll produce the photo evidence.
    I know they're going to try their best to have me chase my tail for 6 months...or, if brakes fail, end up being part of my funeral...
    Heirs can participate in lawsuit..and become millionaires on my behalf....Aaahaha
    I'm partial to Ford products and hope they don't try to screw me on this issue.
    andys120andys120 Member Posts: 23,392
    That seems like the long way around. If your dealer won't simply hook 'er up to the scanner to look for trouble codes at your request I'd say you need to find another dealer.
    Thanks for the suggestion. Good idea.
    I hope to have a little leverage with a photo when I go to dealer...especially since the standard 3/36 warranty is over...even though the hybrid portion of the warranty is still in effect.
    I think it's a "system/electrical" problem due to the complex nature of the hybrid system.
    Every thing is working ok at this moment. I've played with the emergency brake to see what happens...engaging and releasing it had the effect of firming the brake pedal. Also, have verified that shifting into N will deactivate regen-braking system.
    We'll see what happens....this may be a sign that I need to let the Mariner 4x4 hybrid go and get a premium Mustang GT convertable (that I've always wanted). The metalic blue, silver, and black 2010's are looking real good now! But hate to give up the Mariner's mileage, utility, and comfort....
    Well Heil, it's been almost 10 days and the Mariner is working perfectly. No brake problems and average mileage is staying @ 30.6 MPG's.
    Maybe there was a little dust that got removed...
    hilltownshilltowns Member Posts: 2
    About 2 months ago I had the tires replaced on my 2008 FEH at 34k with Michelin tires better suited to the winter weather we have here than the factory issued tires. Ever since then, occasionally when braking at low speeds, the brakes seem to slip slightly before completely engaging: brake, slip, engage. I brought the car to the dealer twice and both times was told that they did not experience the problem when they took it out on the road. Well of course not, the problem is intermittent and at slow speeds. Then the other day as I was leaving to drive lots of hills where I live, the CHECK BRAKE SYSTEM and ABS warning lights went on. I went right back home, called another dealer and made an appointment. It was a long slow drive to the dealer, not knowing what the brakes would do. They found that the EXCITER RING on the Right Front Axle was cracked and said that this caused the ABS to read incorrectly, perceiving that the right front wheel was moving faster than the other three, thereby causing the ABS to kick in. $400 dollars later (the part cost $37 of that, the rest labor to take the axle out and replace it) I drove home thinking that the problem had finally been solved. I pulled into a parking spot and the same thing happened again, brake, slip, engage. I have a call into the service department now, waiting for a reply.
    I have been reading scary accounts on line of FEH brakes failing. Can anyone tell me if they know what the root problem is, if Ford has made any comment, or are there programs to fix the problem. Thanks.
    shasha22366shasha22366 Member Posts: 1
    I have a 2005 FEH and I have had the exact same "brake light" issue". I just brought it in this morning to have it checked out because they told me that "it's safe to drive" but I need to have it checked out. Well I have a 2 year old son and the last thing that I want is for him to be in the car when the brakes become "unsafe". There is NO recall on this just a "letter from FORD" stating that there is a "corrosion probelem with the brakes in the Hybrids. This ought to be interesting.....I will post more later once I know more......
    justinddjustindd Member Posts: 1
    I feel everyone's pain. I have an 08 Mariner 4WD that has the brake 'lock/slip' problem, where sometimes it does a brake, release, engage behavior, and othertimes worse. The other day the rear brakes locked up and I had to drag the back of the vehicle for about 100 yards with locked brakes. Then when I hit the brake pedal, the wheels unlocked and I was rolling again.
    The car has been in for service for several days and I have them doing the final repair under the lemon law. They called me last night to tell me that they saw the behavior (which must mean the brake, release, engage behavior) and it is normal for the vehicle and FORD says nothing is wrong. Perhaps I didn't descripe engage properly here because engage on mine means engage to where the wheels in the back nearly lock, then release a little back to where they should be. I guess FORD considers it normal for cars to have brakes lock up, slip and slide on wet roads and ultimately cause accidents.
    much to my surprise the problem seems to have been fixed, at least for the moment.both front exciter rings were shot, one borken and one damaged. Since they were both replaced its been smooth sailing, and in fact, the feeling of instability at higher speeds is gone. The problem here is the lousy design and poor manufacting of this element. the exciter rings are attached to the axle, and exposed to the road. All the grit, all the snow, salt, you name it. They are made of an alloy that rusts, I kept one so can see it is not a great piece of manufacturing. The first one broke clear in half, the other lost one of its "spokes" that sense the speed of the car. DEALERS SHOULD KNOW ABOUT THIS. The first dealer had no clue after several visits, but the second one said that this happens a lot, which is why the keep the part in stock, ad they located in a small town in upstate New York. Bravo to them for figuring it out. Only wish the two visits had not cost $750!
    Have the exciter rings checked on all 4 axles. Good luck.
    owlsnestkidowlsnestkid Member Posts: 4
    Hi Hilltowns, I may have a similiar issue going on with my '07 Mercury Mariner Hybrid...I had my tires changed earlier this summer, and more recently I've been noticing the brake-slip-engage situation. I'm near Manchester, NH and because the problem is intermittent, the dealer in town drove it and it wouldn't happen for them. The problem is getting worse, I copied your post and sent it to them, and plan to bring it back and insist that they check the exciter rings on all four wheels.
    escapebrake1escapebrake1 Member Posts: 1
    about a month ago my 2007 FEH started to jump when braking down to a stop
    it would occur at about 15mph or less, intermitently. now it happens often.
    i sometimes coast in neutral to a stop sign to avoid it happening. does anyone else experience this? it seams to be front brakes
    Hi escapebrake1, I believe you have the same problem I just had fixed. If its a "brake, slip, engage" type situation, have the Mercury dealer check the "exciter" rings, aka "tone" rings within the braking system. They could be cracked. They seem to be a common problem (at least what I've seen). It feels like when you hit the brakes that the brakes suddenly "give" for a second, then engage, correct? Mine were cracked, I identified this problem to the dealer after checking this site.
    Being a FWD vehicle the FEH is highly susceptable to loss of directional control if regenerative braking is enabled at low speeds on a slippery surface. During braking, actual braking, one wheel hits a bump at low speeds, loses roadbed contact, and ABS will INSTANTLY disable regen.
    What you "feel" is a slight surge forward.
    Obviously a faulty "tone" wheel would result in this happening more often.
    degu1degu1 Member Posts: 2
    I have enjoyed my 2006 FEH and have 60k miles. I've followed all recommended maintenance etc. Two weeks ago the brake warning light started coming on occasionally. I checked the emergency brake..no problem, the car would brake as it normally would, I checked the brake fluid levels..no problem..but the light and alarm would still come on especially when hitting a bump or turning. I thought maybe a sensor and electric problem with the dash. Took it to the dealer who said they couldn't get the light to come on when they drove it..I explained I wasn't imagining it. They took down more info..I became wary of if they knew what they were doing. I was in shock ( to say it mildly) when they said they hooked it up to a diagnostic machine and what I needed was a new master cylinder ($1800.) If the brake light still continued "Ford" recommended a new ABS system ($4500.) Even after they would do this work they couldn't "guarantee" the problem would be solved. I asked why there wouldn't be some other physical evidence that the brakes were bad, ie fluid leak, squeaking, spongy breaks..and was told they didn't know but they had to advise me that this was the "repair" that Ford recommended. I haven't done anything as I want to get a 2nd opinion. After reading what alot of you have said I'm really stumped! Any advice? I too am afraid to drive it!
    i had the same problem with my 2006. read my previous posts. call ford directly, don't listen to your dealer. mine also said they couldn't reproduce it, so i took a photo of it when it came on and showed them the photo. eventually ford sent someone to fix it (they eventually ackknowleded it was a problem. in one of my posts i listed the fix). they resolved my problem (sort of), the light comes on for me right after i get my car serviced, but then only comes on maybe once more and then goes away. again, call ford directly, go to the website, there is a service number and file a report.
    to save time, what is the service number. Has happened to me intermittedly. Which means maybe 5 times since I i've owned the Escape Hybrid.
    Probably need to get fixed before the warranty is up.
    I agree that the problem does not involve the master cylinder or any major repair. Has to do with the parking brake or getting the code off of the truck computer - then following the recommended repair outlined by Ford engineers.
    post #34 explains what they did.
    wantasafecarwantasafecar Member Posts: 1
    I am having the same problem with my 2009 FEH. Purchased car on August 11, 2009. Brakes failed while we were operating the vehicle in mid September 2009. Specifically, no response for first 2/3 of the way that braking foot moved towards floor. In last 1/3 of the distance as braking foot moved towards and touched the floor, only a weak insufficient response. Took to nearest dealer, who kept car for 5 days and replaced a travel booster switch. Dealer assured us the car was safe to drive and that the problem had been fixed. However, the same problem reoccurred while we were operating the vehicle less than a month later. Took to nearest dealer again. They had the car for 18 days. Replaced wiring harness. We are afraid to drive the vehicle.
    sbaker343sbaker343 Member Posts: 1
    Ford Escape Brake Wear and Service. My 2007 Escape has been a great vehicle: the reliability and mpg are terrific. However, I recently inspected the brakes and found that the brake pads on the right side (outside pad only) were worn almost completely. I had the front rotors reground and the pads replaced, and will tackle the rear brakes soon.
    Question #1: Does anyone know of similar brake wear patterns, or what may cause this unusual wear? (Vehicle has only 24,000 miles).
    Question #2: What are the basic steps for rear brake disassembly, specifically dealing with the emergency brake mechanics? Are special tools required?
    It ended up being the front ABS toner rings, which were both broken. The dealer fixed and charged me $548.32 for the job. Last week Ford offered to fix Fusion and Milan Hybrids for having very similar braking problems!
    http://www.foxnews.com/story/0,2933,584882,00.html
    after a year of the message/light coming on maybe once, i took it into ford to see if they could eradicate the problem completely. they said ford has a fix which replaces grounds which cost $300+, and now the message/light comes on every time i drive the car, which is worse than it ever was. has anyone successfully had this problem fixed??? why do i get the feeling noone has (on this forum)?
    bingo01bingo01 Member Posts: 3
    I'm new to this forum. I'm the sad owner of a FEH 06 with the dreaded braking problem. At 78k the car is past warranty. Ford says that $5000 worth of parts (replacing abs controller) may fix the problem. Has anyone her had an experience that actually fixed the braking problems? Is there a class action suit yet?
    Finally got the problem diagnosed at our local Ford shop. Apparently my vehicle has a cracked tone ring that is turning off the abs. $600 estimate to fix it. Glad I didn't follow the advice earlier to replace the entire abs module for $5k.
    On these vehicles the tone rings are exposed to the elements. Makes them prone to fouling and breakage. Bad on Ford for this engineering error!
    Are the others FEH owners reporting these problems to NHTSA?
    I did not report my exact same problem to the NHTSA. What is their contact information, I will definitely contact them. I emailed Ford back in February of this year (and even involved a local news investigative reporter, Susan Wornick, cc'd) and here was their (disappointing) response (and my original inquiry is below that):
    To: steve
    Sent: Thursday, February 11, 2010 9:49 AM
    Subject: Ford Motor Company
    > Dear Steve,
    > We apologized for the inconvenience the situation may have caused you.
    > However, our records indicate that a decision has been made and the CRC
    > can not overturn this decision. However, to ensure our records are
    > complete we have documented your feedback
    > We are sorry that our response could not be more favorable to you.
    > Sometimes e-mail communication does not allow us to gain additional
    > information that may be helpful in responding to your inquiry. Should you
    > feel that we have not adequately addressed your questions, please feel
    > free to contact us via telephone at (800)392-3673 between the hours of 8am
    > and 5pm, local time, Monday through Friday. Hearing-impaired callers with
    > access to a TDD may contact 1-800-232-5952. Upon calling us please
    > provide your reference number - 0465220390.
    > Sincerely,
    > Rex Bryan
    > Customer Relationship Center
    > Ford Motor Company
    > For online support visit us at: www.customersaskford.com which contains
    > answers to frequently asked questions and links to other key product and
    > service information.
    > Ford Confidentiality:
    > For security reasons, please do not submit any sensitive personally
    > identifiable information, such as credit card numbers, driver license
    > number, SSN, DOB, etc.
    > [THREAD ID:1-525GWZ]
    > -----Original Message-----
    > From: steve
    > Sent: 2/9/2010 07:55:48 PM
    > To:
    > Cc:
    > Subject: Re: Ford Motor Company
    > Hello Rex,
    > Thank you for your prompt reply to my inquiry. I was informed of Ford's
    > recent decision to fix brake problems (re: your Fusion and Milan Hybrids)
    > via the WCVB evening news program in Boston, Massachusetts. Susan Wornick
    > is
    > a consumer investigative reporter that I trust. It was an interesting
    > report
    > and seemed very similar to troubles I experienced with my Mercury Hybrid.
    > So
    > I notified Susan of my circumstances, and she also wanted to understand
    > what
    > Ford's response would be. I have cc'd her here and kindly request that you
    > continue involving her in our communications going forward.
    > The problem -- in 2009 my Mercury Mariner started experiencing an
    > intermittent braking issue during summer 2009. When I applied the brake, a
    > brief slippage occurred. Rather than a full immediate response, the
    > vehicle
    > continued to lunge forward, and then after this lapse, the brake fully
    > engaged. This was a very unsettling feeling. I first brought this to the
    > attention of my Mercury dealer, State Motors, in August 2009. The dealer
    > conducted a vehicle evaluation and were unsuccessful in identifying the
    > problem, so it remained unsolved.
    > However, the problem persisted. After continuous concern about our safety,
    > I
    > researched the issue online and found numerous other Ford Escape Hybrid
    > owners describing similar experiences. Some had noted defective tone rings
    > as the cause. I brought this research to my dealer's attention, which
    > contributed to proper identification and repair of the vehicle. As it
    > turned
    > out, the two front ABS Tone rings were cracked. It seems apparent these
    > tone
    > rings are not designed sturdy enough by Ford's supplier.
    > While my Mariner Hybrid may no longer be under factory warranty, this
    > problem introduced a dangerous driving condition that compromised optimal
    > vehicle control. I insist that full reimbursement is made by Ford for the
    > expenses related to this particular repair. I paid nearly $550.00 for this
    > braking issue in September, 2009. An issue such as this should not be
    > categorized as 'normal wear and tear'.
    > One remark recently made by Toyota this week was -- they consider the
    > company's priority to be on safety rather than sales. I'm encouraged that
    > you emailed me today -- but sincerely hope Ford will do what is right for
    > me
    > and all other Ford customers affected by any safety-related issue -
    > regardless of how many or few that may be. The brake issue experienced
    > could
    > have contributed to an unfortunate road accident for myself and other road
    > travelers. My diligence to research and identify the issue proved to be my
    > best defense, but Ford should not wait for a tragedy to occur before
    > taking
    > action.
    > As requested, here is my contact information along with details about my
    > 2007 Mercury Mariner Hybrid:
    > Name:
    > Address:
    >> City:
    >> State:
    >> Zip Code:
    >> Cellular Phone Number:
    >> Daytime Phone Number:
    >> Home Phone Number:
    >> Vehicle Identification Number: 4M2CU39H08KJ05143
    >> Odometer Reading: 85383
    >> Servicing Dealership: State Motors, Manchester, NH
    >> Has the vehicle been diagnosed by a Ford/Lincoln-Mercury Dealership for
    >> the current issue?: Yes, I have attached copies of the service reports.
    > I trust that you will escalate this within Ford and that a Customer
    > Satisfaction Program will be initiated as a result. Our correspondence on
    > this matter should make a positive difference. I look forward to your
    > correspondence Rex.
    > Thank you,
    > Steve
    coloradodrivercoloradodriver Member Posts: 1
    I am new to this forum. I purchased a 2009 Ford Escape Hybrid about 6 months ago. It was a one-owner car with 42,000 miles on it. A couple of weeks ago the check engine light and red brake light came on. I took it to the Toyota dealer where I bought it used, but they couldn't find anything wrong. I drove it without problem for 2 more weeks, then the 2 lights came on along with a beep, and I lost the brakes. Had to use the emergency brake to get home. Took it to a Ford dealer this time. They had to call the Ford company because the technicians had never seen this problem. Ford told them the brake pedal assembly was the problem, and it needed to be replaced at a cost of $1315 (which was not covered under the extended warranty I had been convinced to purchase from the Toyota dealer). I asked how certain Ford was that this would fix the problem and was assured they were confident because my car showed a fault code "C1012."
    So my questions are as follows:
    1. Has anyone had experience with this fault code or having the brake pedal assembly replaced, and did this fix the problem?
    2. Does anyone know of a class action lawsuit or other legal action in the works? Reading through this forum it is clear Ford has known of this problem for years. It's amazing no one has been killed - yet.
    bolter24bolter24 Member Posts: 3
    When I make a left hand turn I get a metallic swishing sound from my right rear tire. Has anyone heard of this? I also have the groaning brake syndrome, alot of noise when applying brakes at low speed.
    I had the same problem. Turned out not to be brakes but the bearing going out. Front drive side bearing at 36K, front passenger side bearing at 48K, rear driver side bearing at 60K. All had the same symptom. Ford charged me for a brake job the first one and I didn't even make it out of the service bay without reproducing the symptom.
    Not such good news. What did you have to pay for the bearing replacement?
    Hard to say. There was the $800 bill they charged me for the brake job which I told them I didn't need. So they "comped" me the labor for both and charged me another $400.
    The second and thrid bearing replacements were $500 - $600.
    Thanks for the info, I will bite the bullet and take it in this weekend. I will post the results.
    otiswinstonotiswinston Member Posts: 2
    I've had to replace the brake rotors (front and rear) three times on my 2005 FEH, and it only has 100K kms on it. Ford denies there's a problem with the vehicle. Has anyone else experienced this problem? I've been driving for over 35 years on multiple vehicle types and never had this type of wear.
    escapeforeverescapeforever Member Posts: 4
    Sorry to hear you were quoted $600 for two new tone rings. My 2006 Ford Escape Hybrid had to have both replaced (at a Ford Dealer) for only $230 total. That was this summer (2010) and I've experienced no problems since. Many report that dealers and repair shops insist on replacing the axles too -- at considerably more expense. It would seem that this isn't necessary if it's only cracked tone ring(s).
    For more info suggest you search the web for "Ford Escape Tone Rings" -- there's much to hear about out there in cyberspace about them.
    edited November 2010
    Rotors are so much thinner and lighter now (I suspect cost-cutting is the culprit) that it doesn't surprise me that on a vehicle like the Escape that you'd be doing replacements like that. So much depends on the driving conditions and type of driving you're facing when it comes to brakes. But back to the rotors, it used to be that it took two hands to carry one rotor, now you can easily carry one in each hand. Less metal means less weight, less cost. It also make the rotors thinner, less able to dissipate the heat, and more prone to warping. So I guess that technically, there's no "problem",, at least not one that has a fix other than to replace rotors when they warp, but it sure as heck is a pain.
    i'm baaaaaaaaaaaaaaack. after a year, the CHECK BRAKE SYSTEM message and emergency brake light are back on again. This seems to happen in the winter, not sure if the cold has something to do with this, but Ford just does the same thing as last time, which is fixing a ground. well, that didn't work, again. after 2 days symptoms are back.
    anyone ever have this definitively fixed where it never happened again?
    feh2005feh2005 Member Posts: 1
    Dsteak! I will be damned! I have the same issue however it only seems to happen in warmer weather. In winter I did 2 long trips of 1K miles + and had no issues.
    As soon as its spring, and the weather a bit warmer "Service Brake System" and the red light come on. My toner rings appear to be alright!
    The ford dealer could not replicate the issue after charging me $90 + taxes for inspection :mad:
    Ford is now telling me I need a new ABS Module ($4K+). They weren't interested when I argued I've had this problem for 4 years and 10 visits to the dealer. My warranty is expired and I'm responsible for the repair, even though obviously the ABS Module should have been the fix 4 years ago.
    My last Ford.
    winkstartwinkstart Member Posts: 1
    Total Brake Failure! The story: After 96,500 trouble-free miles, I had the rear brakes serviced at the dealership. They replaced the rear pads and rotors and changed the brake fluid.
    I picked up the car to drive home. After running a couple of errands, starts and stops, the ABS and BRAKE lights came on, a chime and SERVICE BRAKES SOON on display. I stopped immediately, and called the dealer. He said to drive it back to them. When I restarted, the brake pedal went to the floor. NO BRAKES!.
    They towed it back to dealer and kept it for a week. They said the brakes were fine when they re-started it. Now they say it's fixed, it was "a bubble in the brake line." All better now, they say - it sounds bogus to me. If there was air in the line, why were the brakes fine for the first half-hour? Why did they keep it a week? I feel so lucky that this happened to them, not me! So far, they are not trying to charge me. More as this develops.
    cdwrightcdwright Member Posts: 1
    I have a 2005 FEH. Went 150K on the original front rotors. Had them replaced at a mom/pop shop w/ 3rd party rotors (even though I questioned since it is a hybrid). Replaced them 3 times, but after the 3rd set warped they gave up and blamed it on "bad driving habits" (depared w/ choice words for the mgr). Went to Ford, and they replaced w/ factory rotors, but not for the hybrid. Then went to a different dealership who finally acknowledged that the FEH requires special rotors. There were 2 on the planet in Japan, but they replaced under warranty. 2K miles later, these are now warping too.
    P.S. Also replaced the steering mechanism at Ford corporate's recommendation. Now $3500 into this and still haven't fixed the original problem.
    It's entirely possible that the "bubble" was in the ABS/TC "loop", side-tracked, as it were, and only after it moved to the "main line"....
    Often results from inadequate oversight of the McD graduates that are assigned these routine (changed the brake fluid) maintainance tasks.
    willieinmainewillieinmaine Member Posts: 4
    Hi there,
    Thanks for all the great info. I wish I did not need it! ;)
    I have a 2005 FEH with 187K miles. I had the front brakes replaced this June (rotors, etc.), drove from Maine to SC - everything great, up to 30mpg.
    Yesterday (11/18/11) I was driving home and the car was lurching, acting strangely. I pulled over and the front right brake was really gushing smoke and hot as a pistol. My shop was near by so I let it cool and limped it over.
    This morning he replaced the caliper and brake hose but said he could not bleed the brakes after trying for nearly 2 hours. He arranged for me to go to the Ford dealer so I did as I have been there before. So $239 for him.
    From his shop to Ford dealer, almost no brakes, pushing down very hard, ABS light on and SERVICE BRAKE SYSTEM displayed, and brake light.
    The Ford dealer had the car for a few hours and said they could not bleed the brakes either. Here is what the 'receipt' said:
    "Tried to perform an ABS bleed with the IDS, can not perform. Codes in system C1323, travel sensor 1 fault. C1524, calibration incomplete, brake travel.C1525, initialization incomplete. These are hard faults. Ford has bulletin for code 1524 to replace master cylinder first before proceeding further. Customer declined repairs. Vehicle unsafe, should not be driven."
    I limped it home on on just reserve brakes - pushing all the way to the floor, really hard!
    I do not trust the Ford dealer, especially that one. After reading this blog I am also concerned that they will charge $1142 for the master cylinder (their estimate) then want another $4K for the HCU.
    OK - How f&^%ed am I?
    Seriously though is there any way an independent mechanic can have a look at this and really determine if I need a master cyl and the HCU? Any in New England?
    Any help or advice would be appreciated. Is it worth taking to another Ford dealer? Is it time to trade it in for whatever I can get?
    My shop guy did pay the $137 Ford charged to look at this so still just $239 into this. I paid $5500 for this car about a year ago, very clean, have driven 20K miles. I really love it besides this.
    thanks,
    Willie in Maine
    unhappyforderunhappyforder Member Posts: 3
    I have the same thing...I just had my 2006 FORD Escape Hybrid in for service on an issue that caused the engine to turn of and ask me to pull over to a safe stop. ($700ish water pump fix) and now I'm getting TOTAL BRAKE FAILURE with the ABS light going on!
    I've been told it is about $5000 to fix!!!!! This is a catastrophic failure that I've I've called FORD to ask for them to stand up and help me out. (My hybrid system is still under warranty, and the service dept says it is so expensive because of the Hybrid system!?!?)
    I am so P.O's and this will be my last Ford! My sister was going to buy one like mine, but after hearing about this she switched to a GMC. I may be driving a GMC or Chevy next week.
    What to you do with a 2006 Piece of junk ford?! Anyone know where I can find someone to take it off my hands? I can't afford to get it fixed. :-(
