Subaru Forester (up to 2005)
I haven't shopped for Yakima racks in a while so products have changed a bit, but it looks like the Cobra, Anklebiter and Raptor models should work with Mighty Mounts.
Ken
The
I have Forester 2003 2.5x, manufactured in jan 03,
At the moment it has 3300km on the Speedo.
I live in Sydney Australia (BTW beautiful country). I drive only in the city. (Must admit - the time I drive there is not that much of the traffic, but never the less it is not a hiway)
My worst ever fuel consumption with this car was 11.5L per 100Km (24m/gl)- my first tank.
Since then my average is 9.3L per 100Km (30m/gl) and it was as low as 32m/gl.
The only way I can explain that you guys having such a hi fuel consumption is that you have a ,softly speaking, not a good quality fuel in the US.
BTW the fuel I use is standard ulp RON 90. This is a lowest unleaded RON available here in Australia.
Forgot to mention I have only used A/C 10% of the time.
Regards...........Vitaly
Juice: what else can it be if its not fungus?? got any ideas? I read the post on head gaskets, but I don't have any of the symtoms, no sweet smell to the exaust. I'll try that bleach thing tomorrow when I work on the car.
Mike
That would be imperial gallons? In US gallons, I believe your 9.3l/100km is a little less than 26mpg.
- D.
Thanks for correction. You are absolutely right.
My conversions were based on imperial gallons.
I have conversion table in front of me, but it never occur to me that it is not US gallons.
Thanks again.............Vitaly
It's pretty well understood that most OEM audio systems are WAY below what would be considered good quality sound.
-Bob
I found a picture of one and it looks bulky but then again I've heard that some fold down pretty flush. Thanks.
Dan
As for the Yackima rack you cannot use the mighty mounts for the fork mount bike carriers. That's my dilemma as I have 2 steelheads on 48" bars for my civic. I would have to go to the forester towers to be able to use my existing rack pieces. At $100 per steelhead plus lock cores, I would like to use them for both vehicles as needed.
Gene
We measure octane by average RON and MON, (R+M)/2, so we can't even compare octane directly. But yeah, we have dozens of gas varieties so you never know what you're getting. Manufacturers have to "dumb down" engines to handle the worst stuff.
I love not having to bend over to wax it, saves an incredible amount of time too.
Mike: no idea, I find the whole thing rather bizarre. Keep us posted?
-juice
Thanks for all the help.
Mike
The Front Speakers are next. I think I'll go with the Sony XPlods - which seem to be much better than the Subaru upgraded speakers.
The Rear Speakers are small, 4" I think, and Crutchfield doesn't list any recommendation. I may just leave them as they are, because they are practically under the two front seats anyway.
If the rear speakers were in the back part, or even on the lower inside of the tailgate, THAT might be a place for some 6 x 9s or something good like that.
Anybody seen/heard of that option?
Check it in a week, then maybe a month after that. I doubt it'll come back.
Haven't seen speakers in the tail gate, but I think there are plugs on it that you can remove to change some light bulbs, so you should be able to see if there is room.
When you buy a speaker, make sure you get a surface mounted grille.
-juice
I replaced the speakers in my WRX with Rockford Fosgates -- 6.5" up front (needed to fashion a spacer ring) and 4" in the back. Used DynaMat behind the speakers and around the speaker opening. If I had to do it agian, I would skip the rear door speakers altogether.
In the WRX, you could sandwich some 6x9 speakers in the rear deck, but there's no such option like this on the Forester. Even if you could squeeze something into the hatch area, the location would not be ideal for mid or high frequency sound. For the Forester, I think the best option is to keep the mids and highs up front, and bass in the rear. I had a component system set up like this on another car, and it sounded good.
Craig
Here's the answers to your questions:
>I was wondering if the OEM rack you bought from Subaru stays on your roof all the time.
I mount it every Spring and leave it on until the Fall. It take about 15-20 minutes to mount and align, so it's really not something to pop on and off.
> Does the front assembly that holds the tire fold down or do you remove it?
If you are referring to the lockjaw mechanism this holds the frame, yes it folds down and sits nicely on top of the wheel track when not in use.
> Does it create a lot of wind noise or effect your mileage?
No wind noise complaints. Mileage may go down about 1-2 MPG, but I was never sure if that was due to my driving habits or the drag. Not a big deal.
> Does it get in the way of your sunroof if you have one?
Didn't have one on my 99 Forester and I haven't put it on my 03 XS prem yet, but I can tell you that it will not block the *operation* of the sunroof, but the bikes will definitely block your view up. I see this as GOOD since I can look out my sunroof and see that my bikes are still there!
I guess bulky is a matter of opinion. It doesn't require special cross members, so it just looks like two tracks and two lockjaws on top of the existing rack. If you want to be able to effortlessly throw a couple bikes on your roof whenever you want and not block the rear hatch, this is a fine choice.
If you buy it, just remember to get the adapter clips for the Forester's roof rack. Your dealer should remind you, but you never know. They're about $12 IIRC. Incidentally, the adapter clips are identical for all '99-'03 (not sure about '98) Foresters.
Good luck,
Elliot
-Bob
Had the Forester in the dealers looking for the missing oil and the guy who put it on the lift set one of the lift arms too far back. I noticed the damage a couple of days later when I got a good look at the car in profile.
It goes into the body shop tomorrow for them to straighten the bottom rail, possibly replace the lower trim piece and then repaint. At least the dealer was very reasonable about paying for the repair. This is the second time I've had to send the car to the body shop after they got done with it. The first was to get a scratch buffed out. I've learned to do a full walk around when it goes into any shop, then repeat when I pick it up. Now I guess I'll add checking the jack areas as well.
I just hate letting anyone else touch my car.
BTW - for anyone that's done it, just how tough is it to pull the front door panels on the 03 Foresters? New speakers are getting to be a better and better idea as time goes on
Larry
I put a piece of wood to protect my cars.
-juice
Anyway, the creaking noise was diagnosed as “rack & pinion bushings” that needed lubrication. After their work, all has been quiet for a month and a half, but now it’s back again. Anyone have a suggestion that I can relay to the dealer to check and fix for good? Thanks.
Greg
Hmm, you can spray lithium grease on bushings, which takes seconds. I wouldn't want to do that every 45 days, though. I do it when I rotate the tires.
-juice
Now here is the interesting thing about the Forester chassis. It is extremely tight and solid, so much so that when I took the rear end up (tires only 1 inch off the ground), one of the two front jack stands support points came up too. A full six feet away, and the chassis didn't have enough flex to keep weight on both front stands. Solid stuff here.
I am leaning towards the wooden rail that you use, Juice.
John
-juice
Craig
<rant off>
Greg
P.S. wish I could mount and balance my own tires.
They tested the Forester X with an automatic, and it's their top-rated small SUV, just ahead of the RAV4. They liked the ride, handling, braking and the interior layout. They also praised the acceleration, 0-60 in 9.7 seconds, which was second-best in the group, just behind the Sorento.
About the only bad things they had to say was that the gated shifter is a "nuisance" (have to agree there) and that the tires "aren't very grippy."
They seemed to like the Baja, although they said it's definitely better to think of it as a car than as a truck.
They liked the well-made Element even though the interior design was "fraught with compromises"; the Outlander was unimpressive; the Sorento had a nice interior and strong engine but ride and handling were poor; the Aztek's only good point was its cargo space.
The Sorento is not at all supposed to be in that group at all. It has Body-on-Frame, it's larger than the others, it has low-range, and it's a TRUCK! Not to mention a 5000lb towing capacity!
Arggg I hate Consumer Reports.
-mike
First, it wide, *very* wide. I'm sure it's roomier than a Grand Cherokee, for instance. It definitely belongs with the mid-sizers.
Price might make people cross-shop with compacts, but it is not compact. Check inside and see for yourself.
Any how, nice to see the Forester on top again. Too bad their test came a month after the Car Issue, which had the RAV4 on top.
-juice
BTW, the OS came out second to last in the 8/02 issue, just ahead of the PT Cruiser, and behind the Jetta Wagon, RAV4, '00 Forester, Focus Wagon, Matrix/Vibe, ZX5, CRV, Protege5.
Also, does the OBS get the 4.11 final drive ratio? Forester might have slightly quicker gearing.
-juice
I know I would if I were in the market, I would probably cross-shop a whole range of vehicles, before narrowing down my selections. I'm sure a lot of people are on the fence as to whether to buy a car-based SUV or a truck-based SUV. A report like this could help them make up their minds.
Bob
1) You need to pull two trim pins out of the headliner and even though I was using the right tool, one of the pins broke apart so I have an very occassional rattle in the headliner. Once you install it you need a phillips screwdriver to get it in and out.
2) You lose the use of the pull curtain since the grate mounts directly into the curtain mounts.
3) It is a very solid well made barrier - and you should be able to beat the dealer's price. I paid around $110 for mine.
HTH
Larry
Good to know the Forester is back on top. I can't wait until reviews of the XT come out.
I guess I'm one of the few that actually like the gated auto shifter on the current Subies. I think it makes 3<->D shifts easy, IMO.
Ken
Russki, I wish I had a Subaru when I visited Oz back in '89. After a week in Sydney, I flew up to Brisbane for four days and then drove from there to Melbourne in some sort of foreign-Ford. Learning to drive on the wrong side of the road wasn't so bad, but those traffic circles and left turn "hook" lanes were killer! Seriously, it was a beautiful trip full of memorable moments, like coming across herds of cattle wandering across the highway, seeing a 3' tall barn owl strolling across the road snatching up the mice that were hording about, seeing the Southern Cross (is that the idea behind Subaru's logo?) for the first time, and chancing upon a beautiful 50m outdoor pool in some interior town (Goolamera?) on a 100+ degree day. A true lap swimmer's delight to provide some relief from a surprisingly long (3+ days) trip. Am looking forward to getting back down under soon!
John
-Dave
-mike
To answer Ken's question, as written in the story: "For this issue, we tested five models that span the market."
Finally, the inconsistency between the June issue and the April auto issue is because the results for the newly tested Forester weren't available in time for publishing.
All opinions my own, not CRs.
Tom
IMHO, it would make more sense to group it seperately with the XTerra and Rodeo. Maybe the Grand Vitara too.
I read it FWIW, literally. I have to admit, it seems like the audience they write for is a soccer mom with 3 kids. They evaluate a vehicle mostly for family use.
-juice
It's typical of reviewers, not just CR, to start a review with "this vehicle really doesn't belong here because..." and then proceed to slap the vehicle around for being what it is.
If the Sorrento was to be in this test, then there should have been a trailer towing evaluation, a rock-crawling evaluation, etc.
Then, at least they wouldn't be doing the vehicle a dis-service.
BTW, Paisan and I are Trooper owners. Remember what CR did to the Trooper?
And they do climb a rock hill, though it's pretty mild and doesn't nearly challenge the limits of a truck-based SUV.
But I agree, had the Sorento been tested under these circumstances, it would have a chance to shine.
-juice
As for the Sorento, the problem here is that without reading the story, an incomplete picture is being painted. From the article:
Highs: Off-road ability, controls and displays, towing capacity, interior features.
Lows: Ride, fuel economy.
Seems to me (mind you, I don't test the cars) that CR told the whole story. We do test all SUVs for off-road capability (we have one heck of an off-road course to do it, not just the rock hill but a muddy course as well - it was designed by a former Land Rover development engineer who now heads Auto Test at CR) and we test acceleration while towing a trailer - indeed, that statistic is mentioned in the Sorento review ("the Sorento easily pulled a 3500 pound trailer from 0-60 in a respectable 20.5 seconds.")
Tom
