Toyota Highlander: Suspension Modifications
No one seems to have made any attempts to change the basic Highlander suspension. As these cars get older they will need new struts and other suspension components. Can we start a list of modifications that will work, interchangable parts with Camry/Lexus, ect? There must be room for interesting improvements.
This only applies to the V6. On the I-4, the mounts are different--it uses the more common and aftermarket-available D-type bushings; the V6 uses the O-type ones.
Regards, BGood
So given this information -- and absent any good reason NOT to use a weight distribution hitch on my Highlander -- the Equal-i-zer Hitch solution for easing the excessive rear end sag seems to be in my future.
Michael
Replying to: webgood (Dec 12, 2007 12:04 pm)
BGood,
The Toyota Highlander is more of a car than a SUV and does not have a suspension system suitable for the use of Air Lift products. I am considering the Equalizer hitch. However, if you have any luck with your inquiries, please advise the forum; I'll track the thread. Meanwhile here is a copy of my correspondence with the Equal-i-zer people, who responded within a day to my inquiry. Right away I like their product.
Michael
Your Question:
“I have a small vintage 1955 Airstream-type aluminum airframe trailer, I think gross vehicle weight is 2000 lbs, could be higher after I finish modernizing the systems. My tow vehicle is a 2004 Toyota Highlander which is rated by Toyota (with tow package) at 3500 lbs. However, the coil over shock independent rear suspension disallows the installation of an Air Lift product. And I am suffering some rear end sag on the vehicle (which is really a car, not an SUV, irrespective of it's profile.) Would your lightest duty weight distribution hitch be a good solution for relieving the rear end sag on my Highlander whilst under tow? I appreciate that most Equal-i-zer hitches are used on bigger, heavier trailers. But is there a compelling reason why not to use one on a much smaller, lighter trailer such as mine?
Thanks.”
Answer:
The Equal-i-zer hitch would provide you with sway control and the weight distribution you are seeking. However, the Equal-i-zer hitch has a minimum tongue weight requirement of 250 lbs. As long as you loaded tongue weight is at or over this 250 lb limit, you should be fine to use our 6,000/600 lb rated Equal-i-zer hitch. There is no downside to using an Equal-i-zer hitch on a smaller trailer. All it can do is give you good weight distribution, and the sway control goes a long way in keeping you safe while towing.
Let me know if you have any more questions.
Progress Mfg Inc.
533 S. 500 W.
Provo, Utah 84601
The 250 lb tongue weight limit is a critical component in the way that the Equal-i-zer hitch provides sway control. The Equal-i-zer hitch uses steel on steel friction to provide sway control, and our engineers have stated (through testing) that you need to have at least 250 lbs of tongue weight in order to have enough friction occurring to provide you with sway control. If you have less than 250 lbs the hitch will still give you good weight distribution, but we cannot guarantee what kind of sway control you will receive from it. Let me know if you have any other questions. Thanks,
Alternatively, you might consider changing the rear coil springs from the standard (5 person seating) to the uprated springs (7 person seating), as these have about 300 lbs more load capacity with payload going from ~850 lbs to 1,150 lbs. Therefore, the stiffer coils will likely raise the rear suspension significantly on a 5 seat Highlander, or at the very least, will have reduced sag under load.
I have a Toyota 2007 Highlander AWD V6, recently I installed a trailer hitch (factory) to this vehicle, and having difficult time with the rear sagging down. I was on multiple websites and saw some very interesting products , but none that are made for the Highlander. I would like some help in this situation since Toyota Dealer has been no help, to them the Highlander is what it is..
