Pontiac Vibe Suspension Questions
Have an issue or question about the suspension on your Vibe? This is the place to ask about it.
Is this a problem others have experienced? What could be the issue? Anything I should do or check out with the car or should I just take it back to Pontiac Service? Is something like this covered under the warranty?
Mike
Waukesha WI
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm
Make : PONTIAC Model : VIBE Year : 2005
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 3801 Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10018911
Component: TIRES
Technical Service Bulletins Summary
Make: PONTIAC
Model: VIBE
Year: 2005
Type: ANY
Service Bulletin Number: 3801
Summary Description:
PREMATURE OR IRREGULAR REAR TIRE WEAR. *TT :sick:
Thank you scrappy d I had not checked on a bulletin for this problem. Knowledge is power. When we first got the car A/c became impaired they tried a quick fix(weld I think) when that didn't work I notified saleswoman I bought from & she got them to install a new compressor & provide a free rental car. She no longer works at the dealers.
We have an ongoing problem the gas tank will not fill quickly there is a bulletin on this they tried to repair but no go. This one I chose to live with I must choose my battles.
Roy15
