Regular vs Premium gas - what's the consensus?
maxcattum
Member Posts: 3
Disco II and LR3 are specified to require premium gas (92). I have a 96 Disco I and have been using regular (87) for the last 8 years without problems. What's the experience in the community running Disco IIs and LR3s on regular?
MaxCattum
MaxCattum
/DA
Fuel
The LR3 does have variable cam phasing but not variable valve timing. Using higher octane gas is not going to cause any problems but you probably aren't getting much of a benefit out of it.
Thanks for your feedback - MaxCattum
I just switched to regular gas. I get about 19-19.5 mpg with regular, the same as premium. Mostly highway, 73 mph. I would switch back to premium if I towed a trailer or needed full throttle acceleration.
No drivability problems at all with regular.
Hector
Austin, TX.
So you could look at the difference between using premium and regular gas the same as gettin 25 vs 23mpg, but for some, that difference is enough to buy another vehicle. I guess if everything else were equal between two vehicles except one costs $160 more per year to operate because it's less fuel efficient or requires premium gas, then I'd go for the one not costing the extra $160/year, but there are usually a lot of other differences between vehicles (in my opinion) more significant than this issue.
Unfortunately our Discos don't get 23-25 mpg but rather 12-14mpg. Being in California, the delta between regular and premium is more along the $0.35 / gal. So we're looking at $400-500 / year. My question was: can I pocket that without damaging the engine in my 2003 Discovery? (I know I'm ok doing that with my 96 Disco - have been driving on regular for 8 years without problems)
Thanks for all the replies - looks like nobody has had a real bad experience going that route.
MaxCattum
Try it out for a few tanks and see how your mpg drops.
The knock sensor will retard timing if necessary so that should protect your engine.
If you are going to tow or use the Disco off-road you should put premium in it as you are straning the engine more.
http://tech.vtxoa.com/index.php?action=artikel&cat=3&id=22&artlang=en
