Scion xB Tire/Wheel Questions
Discuss tire and wheel issue with your xB here.
Are there all season tires you would recommend? I would prefer NOT to have dedicated snows, although I could if need be
thanks for your help
John
i have seen people selling stock steel wheels on ebay for as cheap as $15 each
hope this helps
I'm just reading over all the posts and taking into consideration what everyone has been saying. My wife and I are looking at trading in a '01 Escape XLT 4wd for a new vehicle soon. The xB jumped up onto our list after we went to a local dealer Sun 3/26/06 and found all three xB's they had on the lot UNLOCKED. It was nice to actually get in at see how well it fit and the amount of room it has (compared to the Escape).
Vehicles we are looking at (not in any order),
1. '06 Scion xB
2. '06 Ford Freestyle SEL
3. '06 Saturn Vue Redline
4. '06 Mazda 5 Touring
5. '06 Mazda MPV LX Sport
The main question I have for anyone with the '06 xB is who got the 18" tires and are they better than the 15" alloys (I refuse to buy wheel covers). And next question to those who got the TRD Sport Muffler, is it worth the extra?
Odie
Better in what way?
Do they hold up better to road punishment (potholes)? How are they in both rain, snow, and ice? Are they quieter than the 15" tires?
I live in Central Pennsylvania and we don't have the normal 4 seasons (spring, summer, fall, winter), we have the PA 4 seasons (almost winter, winter, still winter , and construction), and not to mention some of the lousiest roads around.
Odie
You must be buying a used xB where the P.O. sold the steelies. Try eBay for used OEM steel wheels that people have removed from their xBs.
Bridgestone Blizzak and Bridgestone Winterforce (cheaper) and Michelin x-Ice are popular winter tires. If you don't get the special rubber and tread of winter tires, all-season tires won't work as well in snow and ice.
Look around Tire Rack http://www.tirerack.com and TireSavings.com.
If you have 18" rims, then you're going to pay high $$$ for whatever tire you put on the XB. You may want to consider moving down in rim size. 15 and 16 inches will be fine for the XB.
The best all season tires that I've ever driven were the BF Goodrich Traction T/A's in 205/50/16 size on my 02' Ford Focus ZX3. The tread is more aggressive than most tires and the grip is better in the snow. Handling was good. The only issue that I had with them was the amount of road noise that they generated, but then I turned up the audio.
God luck with your shopping and keep us posted on what you buy.
Do you use one set of rims? If you put the Blizzaks on separate rims, where did you get the rims?
I would THINK either could be moved to a new wheel, but if the band type is used the band would not go around a +1, +2, or +3 rim. The one made onto the valve should work on another wheel.
Ask the service manager at your local Scion dealership and see what they say.
There is actually a 3rd type of system - one the measures the pulses from the ABS system. It does not check the actual pressure of the tires - it just checks all the pulses against the others. If one tire is too low the pulse rate from that ABS sensor will be faster than the other three. If if gets enough off, the TPM light will come on. It will not tell you which tire is low (or high) just that something is wrong. With this type of system you can replace the wheels and tires and not worry - as long as all four have the same diameter.
Dennis
The Kumhos really improve the ride a great deal. They have much more cushion than the Falkens and thus more of a comfort ride. They grip well in the rain as well as in tight, sweeping curves. The sidewalls feel like they are flexing more than the Falkens but they feel like they track better. The Kumhos are twitchy though. You turn the wheel slightly and these tires go there immediately. I'm hoping that as they wear they'll settle down a bit, but overall I'm pleased with them.
So far MPG has been on a par with the Falkens-about 325 miles out of a tank. MPG has gone down in the last 2 weeks due to the high temps here in the DC area, and my use of the defroster in the morning annd the A/C on the drive home.
My 2005 Scion rides rough. I want to purchase tires to make a smoother ride. Hoping you have found them. It is now almost one year since you purchased them. How goes it?
I agree the steering on these is very touchy. I replaced a small steering wheel with a larger one on a toyota I had once and it helped immensely. What do you think?
Do shocks need replaced frequently on the 2005 XB? I have been wondering what is the widest/ largest tire I can go? I thought it would look really cute with the fat tires.
I now have 100k on the 05 XB and 15k on the Kumho's. They ride great still and the wear is relatively low on them. I rotate them every 6k miles. For the price the 195 60 15's are a good buy.
As far as the widest you could go in size--I'm not sure. I've read that some members have 205 series tires on their XB's but I'm not sure what size rim they're running with that tire. I stayed with the 15 inch tires due to lower replacement cost.
Gary
After that I always ran the pressure 5-6 psi higher than stated on the door for better fuel economy and handling.
