thanks oilcanman
But, if I were to start troubleshooting someplace, it would be looking for a bad ground on the instrument cluster.
Thanks for any and all help.
The problems left are: (1) No drivers side low beam on the headlight (2) the remote door lock fobs are not working.
Sorry can't be more specific, but these problems are a real bear to track down.
I have accessed the wiring harness under the steering column and if I move wires I can make the inst. lights go on and off sometimes but not the headlights. Ive read about the CTM but not sure my 98 without power windows or locks has one? I plan on checking grounds any suggestions on where most likely grounds affecting this are located? I will also check individual wires and connectors. Any suggestions on which connectors to focus on?
Any general suggestions appreciated!
Did you replace the ignition switch module? Was the the problem? I am having the same issue now, turn signal and radio only in my 2001. Do you have a part number and is this the correct name for the part?
Thanks for everyone's help and for this web site.
Any Ideas in Dakota Land?
I found a blown fusable link over left shock tower. (very heavy gauge black wire). Cut out the link and with switch in on position, if I connect the two ends of the wire, still nothing. I even tested the plug on the switch with this wire connected and there is no power to any of the pins in the harness. This tells me that there is something going on between the switch and the battery, but what?
Any ideas would be helpful.
Branden :confuse:
